| BRZ First-Gen (2012+) General Topics All discussions about the first-gen Subaru BRZ coupe |
Remote unlock not working. Key needs new battery? How?
Not keyless start.
I turn the key to start car. But door and trunk unlock not working every time. New battery Video below Got it done. Did both keys. 5 for $4.40
| The Following User Says Thank You to daniloneil8 For This Useful Post: | humfrz (12-03-2024) |
#2 | |
My 2013 key has a small slot near the top of the FOB, on the seam, that will open up the two halves by putting a flat tipped screwdriver in it and twisting.
#3 |
Famous Potatoes
Drives: '15 ultramarine
The car is totalled. You are done.
Or, maybe you could read the manual? |
| The Following User Says Thank You to Sapphireho For This Useful Post: | humfrz (12-03-2024) |
#4 |
Drives: 1993 Caterham HPC Evo
Living life on the edge, less crowded, better view!
2018 tS Still in the family. |
| The Following 2 Users Say Thank You to Stephen W. For This Useful Post: | daniloneil8 (12-04-2024), humfrz (12-04-2024) |
#5 | |
Drives: 2017 GT86
It wouldn't surprise me if this key (or the one the OP is actually using) is missing the recess for a screwdriver to wedge apart the halves. If that's the key, the halves still need to be pried apart, and a knife would be a better tool to start attacking the seam than a screwdriver. |
| The Following User Says Thank You to Luns For This Useful Post: | humfrz (12-04-2024) |
#6 |
#7 |
Drives: 2013 frs base
| The Following 3 Users Say Thank You to blsfrs For This Useful Post: |
#8 | |
Drives: 2013 Subaru BRZ
"Experience is a bitch. The test usually comes before the lesson."
| The Following User Says Thank You to RT-BRZ For This Useful Post: | blsfrs (12-04-2024) |
#10 | |
#11 |
#12 | |
I have BRZ |
#13 |
Rust bucket enthusiast
Why does your profile say you drive an FRS?
Why have you not split the casing in half yet and replaced the battery? Why are we still here
| The Following User Says Thank You to DarkPira7e For This Useful Post: | humfrz (12-04-2024) |
#14 |
| The Following User Says Thank You to humfrz For This Useful Post: | DarkPira7e (12-06-2024) |
| SOS button and Remote Services not working | Robotaz | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 11 | 03-30-2022 04:33 PM |
| Remote Lock/Unlock Issues | STIMAN | Issues | Warranty | Recalls / TSB | 13 | 09-20-2021 07:01 PM |
| Remote won't unlock doors. Need help diagnosing problem. | DeviantBlue | Issues | Warranty | Recalls / TSB | 21 | 06-05-2018 02:23 AM |
| Remote lock/unlock not working | zdaughtry1 | Electronics | Audio | NAV | Infotainment | 2 | 03-16-2017 10:16 AM |
| Key fob battery died. Can I manually unlock without alarm going off? | Stu L Tissimus | Electronics | Audio | NAV | Infotainment | 3 | 05-28-2016 06:06 PM |
