Old 11-25-2024, 11:50 AM   #127
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Designed some new rear swaybar mounts to get rid of the ridiculous stock rear swaybar subframe and optimize the rear swaybar geometry. My printer ran out of filament, but the parts were still usable for test fitment at least. I'll get them done in aluminum now
Silly stock rear swaybar subframe and its mounting location:
My design:
I also swapped to 3.73 gearing from the stock 4.10, I was tired of ~59 mph in 2nd being my top speed. I was abusing the rev limiter a LOT this year. I bought a used 2014 IS250 diff and swapped my OS Giken into. The Lexus diff appeared to have never been serviced, it smelled AWFUL and was full of sludge. Truly so bad smelling that while I was working on it in the garage, my wife came outside to ask me a question about dinner and she stopped dead in her tracks to ask what the smell was, haha. Gearing is much better now! ~65 mph in 2nd and it's a more calm cruise on the highway. There's definitely a bit of loss of acceleration but honestly it feels totally fine. I really wish Subaru had used 3.91 gearing in the 2022+ cars, the automatic got 3.91s but the manual was 4.10s like early first gen twins.
The Lexus diff when I opened it:
Wiped off one section of the diff cover, you can see how gross it was with a line of sludge showing the fill level.
Much better!
New diff assembled, backlash and pattern checked out perfectly. I love how well made the OS Gikens are, I've not needed to adjust shims once on any of them, they just drop in perfectly like an OEM diff.
The Following 4 Users Say Thank You to DocWalt For This Useful Post:
bcj (11-26-2024), cueball89 (11-26-2024), DarkSunrise (11-26-2024), KMA KiCKz (02-26-2025)
Old 11-25-2024, 01:32 PM   #128
Racecomp Engineering
I like it. Is this last pic at ride height or in the air? How long are your endlinks? Is the middle setting on your rear bar about where the OEM bar hole is located?
I'd been toying with ideas for a new swaybar mount for 1st gen and GR86 but it's not easy to do it the way I want to without cutting anything. The BRZ mount is much easier to replace.
- Andrew
DocWalt (11-25-2024)
Old 11-25-2024, 03:09 PM   #129
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
- Andrew
That was in the air, I've tweaked the design to move the bar up a little more and get the bar a bit more level.
The middle hole is where the OEM bar lands, I did test that but neglected to take pics (was too busy dropping the diff on my face )
End links are custom ones I made out of McMaster parts, I didn't measure them, but they're about as short as you can make without getting custom heims/rod ends or modifying stuff.
The Revolution rear swaybar mount for first gens/GR86 is a pretty decent bolt on solution, but it could definitely be tweaked a bit to be more ideal. https://www.rhdjapan.com/revolution-...-gr86-zn8.html
The Following User Says Thank You to DocWalt For This Useful Post:
Racecomp Engineering (11-25-2024)
Old 11-25-2024, 08:34 PM   #130
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Wow nice work Ken. Had no idea this was even a thing
autoracer86 is offline   Reply With Quote
The Following User Says Thank You to autoracer86 For This Useful Post:
Old 11-26-2024, 03:12 PM   #131
DarkSunrise
DarkSunrise's Avatar
Nice driving! Car looks like a blast and sounds great.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
DocWalt (11-26-2024)
Old 12-09-2024, 05:13 PM   #132
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
This is definitely the coolest car project I've done yet, IMO. I designed new rear swaybar mounts to correct the rear swaybar geometry when lowered and stiffen the mounts. I sent the design off to be 3D printed in aluminum and they arrived today. The whole process was great, the printer communicated with me the whole time and confirmed some aspects of my design. For example, they 3D printed the threads into the mount so I didn't have to tap the holes. So cool!
The design ended up being perfect and everything went together smoothly.
This is the stock geometry, you can see how the swaybar isn't perpendicular to the end link or the ground but it's also not centered on the control arm so it can torque the arm.
My design fixes that
The Following 7 Users Say Thank You to DocWalt For This Useful Post:
autoracer86 (12-10-2024), cueball89 (12-09-2024), MrSkubi (12-10-2024), RedReplicant (12-10-2024), T-Steve (03-17-2025), villainous_frx (12-10-2024), whataboutbob (03-17-2025)
Old 12-10-2024, 02:15 PM   #133
autoracer86
Drives: Toyota GT86
Amazing work !
DocWalt (12-10-2024)
Old 12-19-2024, 01:44 PM   #134
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Installed underglow, silly but fun.
villainous_frx (12-23-2024)
Old 12-19-2024, 07:37 PM   #135
cueball89
Drives: 15 Impreza
Do you have any driving impressions on the rear sway bar relocation? Are you anticipating more predictability and less of a chance of binding?
cueball89 is offline   Reply With Quote
Old 12-19-2024, 09:19 PM   #136
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
It feels a bit softer/more compliant on the street, which is interesting. A little more understeer maybe?
I'm expecting more predictability as the big benefit.
cueball89 (12-22-2024)
Old 02-25-2025, 04:04 PM   #137
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I've been bored and spending time on some aero improvements. Started with a nice rounded/extended nose for my splitter, designed it to snuggly fit to my Racebred splitter (which is mounted upside down) and printed it out in ASA-CF
The Following 6 Users Say Thank You to DocWalt For This Useful Post:
autoracer86 (02-28-2025), KMA KiCKz (02-26-2025), RedReplicant (03-03-2025), RT-BRZ (02-25-2025), villainous_frx (02-26-2025), ZC6_STi (02-25-2025)
Old 03-17-2025, 01:35 PM   #138
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Worked on stiffening up my splitter mounting for when I add splitter diffusers. The Racebred mounting is totally fine for the diffuser when it's totally flat. The ends/sides are less stiff and if I'm cutting out a big piece of material to put in a diffuser I needed to support it properly. This was ~$35, used OEM holes in the chassis and only required light trimming of the fender liner and drilling the splitter for the elevator bolts. Plus it's all hidden so I don't look like *too* much of a ricer driving to work
Old 03-18-2025, 02:10 PM   #139
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Excited to be doing KOTM!
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
RT-BRZ (03-18-2025), ZC6_STi (03-18-2025)
Old 03-19-2025, 03:58 PM   #140
autoracer86
Drives: Toyota GT86
What is KOTM all about ??
MA86 ANNUAL CAR SHOW - PUB DOG: THE BIG ONE 2022 - September 18, 2022 in Columbia, MD JakeRogue Mid-Atlantic 41 10-03-2022 08:37 AM
2022 GR86 Premium Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku GR86 General Topics (2nd Gen 2022+ Toyota 86) 13 02-13-2022 12:44 AM
2022 BRZ Limited Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku BRZ Second-Gen (2022+) — General Topics 20 02-10-2022 12:44 PM
2022 BRZ g e BRZ Second-Gen (2022+) — General Topics 110 11-18-2020 10:15 AM
DocWalt's WRB BRZ DocWalt Member's Car Journals 72 10-27-2016 10:50 PM
