Old 10-29-2024, 10:21 AM   #1
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Swapping ECUs
In trying to rule out my code problem, I swapped my ECU. I did the whole 30 minute thing with the jumper from 4 to 13. Everything went fine. Car started. Runs fine. P0341 came right back. Fine. ECU ruled out as problem.
RSM is coming out in November to fix what ever is wrong.
Now, I want to put my original ECU back in the car as it has my ECUTEK license on it.
Do I need to go back through the whole install procedure or just plug it in and go?
blsfrs is online now   Reply With Quote
Old 10-29-2024, 03:34 PM   #2
tomm.brz
Drives: brz 2017 hksv2
go back through same procedure again
blsfrs (10-29-2024)
Old 10-29-2024, 10:50 PM   #3
blsfrs
blsfrs's Avatar
Thanks. Just curious. How many times can you swap ECUs?
Old 10-30-2024, 03:44 AM   #4
tomm.brz
i dont think there is a limit
ive swapped on mine 6 times and flashed the ecu 985 times..still working
The Following 4 Users Say Thank You to tomm.brz For This Useful Post:
blsfrs (10-30-2024), DarkPira7e (10-31-2024), Teseo (10-30-2024), Ultramaroon (10-30-2024)
Old 10-30-2024, 01:16 PM   #5
lol 985
blsfrs (10-31-2024)
Old 10-30-2024, 09:29 PM   #6
Teseo
Drives: frs
lol 985
And counting. The guy just hit plateau
The Following 2 Users Say Thank You to Teseo For This Useful Post:
blsfrs (10-31-2024), Ultramaroon (10-30-2024)
Old 10-30-2024, 10:02 PM   #7
That poor OBDII connector. I don't think my ignition switch has seen that much action.
blsfrs (10-31-2024), Teseo (10-31-2024)
Old 10-31-2024, 08:02 PM   #8
tomm.brz
actually my.obd port is in good shape..it s the ecutek bluetooth interface that is shittier poorest quality on earth and they sell this plastic cheap crappy thing for 400 usd
i ll update when i hit 1000 flashes lol
The Following 3 Users Say Thank You to tomm.brz For This Useful Post:
blsfrs (11-01-2024), Teseo (11-01-2024), Ultramaroon (11-01-2024)
Old 11-01-2024, 06:01 PM   #9
blsfrs
blsfrs's Avatar
Because of crappy fit of the ECUTEK obd connector, I found this cable extension. I can't remember the brand (ithink maybe). It has a very snug fit for both ends. Just the way she likes it.
The Following User Says Thank You to blsfrs For This Useful Post:
Old 11-01-2024, 06:23 PM   #10
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I got a extender like that and still had issues with it dropping connection when trying to log.
Just made it harder to disconnect and restart
The Following 3 Users Say Thank You to RToyo86 For This Useful Post:
blsfrs (11-02-2024), DarkPira7e (11-02-2024), Ultramaroon (11-01-2024)
Red intake ECUs and the new Primary Open Loop Fueling tables callisto Software Tuning 3 04-08-2023 01:07 AM
RB26 Swapping a BRZ Kūsho BRZ First-Gen (2012+) — General Topics 10 02-23-2022 12:30 PM
spoiler swapping?? help? Justinyuen16 FR-S / BRZ vs.... 2 07-10-2014 11:04 AM
What does it take to program your own ECUs? BuBlake Other Vehicles & General Automotive Discussions 14 10-17-2012 01:52 PM
New ECUs being installed jpit Engine, Exhaust, Transmission 13 10-08-2012 04:00 AM
