Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Running 255s (17") vs 275 (18")
Does anyone have any experience with this in terms of lap times?
These are my two choices due to available sizes for a spec tire. I can't help but think bumping up to a 275 on an 18 wheel but "people say" the extra weight and drag isn't offset by the extra grip for a 200hp car. Bonus points: Who makes the cheapest 18x10 40mm offset wheel that I can trust in an endurance race? Also, as an aside, anyone have any idea what my car will roughly dyno (I'm asking because I need to adjust weight) 93 Tune, EL headers, intake, intake manifold riser, catback, lightweight flywheel 180? 185?
2014 BRZ: WRL Build (GP2) Gutted, caged, coilovers, AP enduro, etc-
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1992 NA Spec Miata: 1.6 + 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. |
#2 |
Drives: Fr-s
Searching the Nasa database could give you a pretty good power estimation. https://airtable.com/appERehieevbzLk...gWtC3AQ0QAJPI0
#3 | ||
Drives: '23 BRZ
I would not bet against 255/35-18 on 18x10 being quicker around some, (maybe most) tracks vs. taller and heavier and draggier 275/35-18 on the same wheel! If you get a weight break with the 255s, no question, I'd go that route for sure. Quote:
| The Following User Says Thank You to ZDan For This Useful Post: | GrandSport (10-10-2024) |
#4 |
Drives: None
10 isn't enough wheel for a 275
| The Following User Says Thank You to RedReplicant For This Useful Post: | ZDan (10-11-2024) |
#5 |
what makes you say that. 10 inches = 255mm.
From the tire manufacturer: Rim Width Range: 9-11". Dead middle.
#6 | |
Drives: '23 BRZ
In any case, at your weight and power level I would bet that even 255s on 10s is already getting past the point of diminishing returns for race track (autoX may be different). Even if you could get them at the same diameter, which you can't. If spec tires and 255/35s or 275/35s are the only choice, I'd go 255 on 10s... |
#7 | |
Drives: 2018 BRZ
| The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | ZDan (10-11-2024) |
#8 | |
Drives: '23 BRZ
Would have been more informative to see 225/45-17 vs. 235/40-17 vs. 235/45-17 vs. 245/40-17. But it's impossible to have a perfect test, I really appreciate all the testing Tire Rack does! I always try to buy from them because of all the testing they do. |
| The Following User Says Thank You to ZDan For This Useful Post: | RT-BRZ (10-12-2024) |
#9 | |
Drives: None
You do you though.
#10 | |
Drives: '22 BRZ
245/45/17 on 7.5" is commonly used in DS. It's the perfect blend of higher top speed and not overly pinched with the taller sidewall. 235/45/17 would be my second choice.
2022 BRZ
#11 | |
Also, narrower tire on a wider wheel is harder to drive, even if it's faster. That's an issue for a 16 hour race. Regarding the actual test results, it looks like 225 on 9" wheel is the fastest, but 245 on 9 is just a hair behind it and the 245 on 9 had the fastest lap (just not averaged out). 275 on 10 is basically the same as 245 on 9 (1 inch is 25, so it's almost exactly 270 on 10). Given this is enduro, it's hard to see why those test results do not support 245 +9 which would say 275 on 10. It does support running a 245 over a 255 though. IDK, can we fit a 10.5 or 11 inch wide wheel? 295/30/18 is really the "best" size because of gearing/height. The 275/35/18 is more than half an inch taller than the 255 and nearly an inch taller than the 245. The 255 might be the worst size.
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1992 NA Spec Miata: 1.6 + 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. Last edited by GrandSport; 10-12-2024 at 09:06 PM. |
| The Following User Says Thank You to GrandSport For This Useful Post: | ZDan (10-13-2024) |
#12 |
So they now have 275/35/17 which resolved this issue. I can't imagine a 245/40 or 255/40 is faster on a 275/35 as it is much wider and shorter than the other two.
As far as 245 vs 255, hard to tell on grip going from one day to another (I didn't even drive on them that day, another driver just did 1 session to scrub in) but he definitely noticed the height. If he noticed the bog more, it's hard to imagine the extra grip helped enough. All on a 9.5" wheel. BTW: It rained and we ran rains both days. So I have 2 sets of 255 and 1.5 sets of 245s (because the conti extremes are made of forged steel) to mess around with.
#13 | |
Drives: 2017 BRZ series.yellow
For example the RE-71RS 245 and 255 have the same tread width, the 255 is just a little taller. Whereas on the A052 the 255 has a good bit more tread width then the 245 and is a little bit taller as well. |
| The Following User Says Thank You to Breezio For This Useful Post: | RT-BRZ (12-19-2024) |
#14 | |
Drives: 2013 Subaru BRZ
| The Following User Says Thank You to RT-BRZ For This Useful Post: | Breezio (12-20-2024) |
| Running light "Tail" fuse in foot well keeps blowing **Fixed** | paintdude258 | Electronics | Audio | NAV | Infotainment | 0 | 04-12-2017 04:59 PM |
| "LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" | F-T | Exterior Parts - Lighting | 169 | 08-20-2016 02:15 PM |
| Anyone running "on-axis" components up front? | Vmax911 | Electronics | Audio | NAV | Infotainment | 25 | 08-31-2015 01:20 AM |
| "LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" | F-T | Exterior Parts - Lighting | 187 | 05-15-2013 02:07 AM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 01:59 PM |
