Old 10-09-2024, 06:56 PM   #1
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Running 255s (17") vs 275 (18")
Does anyone have any experience with this in terms of lap times?
These are my two choices due to available sizes for a spec tire.
I can't help but think bumping up to a 275 on an 18 wheel but "people say" the extra weight and drag isn't offset by the extra grip for a 200hp car.
Bonus points: Who makes the cheapest 18x10 40mm offset wheel that I can trust in an endurance race?
Also, as an aside, anyone have any idea what my car will roughly dyno (I'm asking because I need to adjust weight)
93 Tune, EL headers, intake, intake manifold riser, catback, lightweight flywheel
180? 185?
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 10-09-2024, 08:22 PM   #2
redlined600
redlined600's Avatar
Drives: Fr-s
Searching the Nasa database could give you a pretty good power estimation. https://airtable.com/appERehieevbzLk...gWtC3AQ0QAJPI0
redlined600 is offline   Reply With Quote
Old 10-10-2024, 01:14 PM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
Don't have any lap time data on 275 vs 255 on an FT86, but I didn't lose much if anything in terms of lap times going from 245/40-17 on 17x9 to 225/45-17 on 17x9...
I would not bet against 255/35-18 on 18x10 being quicker around some, (maybe most) tracks vs. taller and heavier and draggier 275/35-18 on the same wheel!
If you get a weight break with the 255s, no question, I'd go that route for sure.
180? 185?
Depends a lot on buncha factors. Could be anywhere from maybe 165 to 185 max?
GrandSport (10-10-2024)
Old 10-10-2024, 02:00 PM   #4
RedReplicant
Drives: None
10 isn't enough wheel for a 275
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
ZDan (10-11-2024)
Old 10-10-2024, 05:08 PM   #5
GrandSport
GrandSport's Avatar
what makes you say that. 10 inches = 255mm.
From the tire manufacturer: Rim Width Range: 9-11". Dead middle.
The Following 2 Users Say Thank You to GrandSport For This Useful Post:
Breezio (10-11-2024), RT-BRZ (10-11-2024)
Old 10-11-2024, 06:54 AM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yeah it's a fine fitment for normies. If you're looking for tenths of a second, 10s are narrowish for 275s. I've run 225/45s on 9" and on 8" and it does make a difference in terms of feel and I would bet lap times (no back to back data on that though).
In any case, at your weight and power level I would bet that even 255s on 10s is already getting past the point of diminishing returns for race track (autoX may be different). Even if you could get them at the same diameter, which you can't. If spec tires and 255/35s or 275/35s are the only choice, I'd go 255 on 10s...
Old 10-11-2024, 07:47 AM   #7
Ohio Enthusiast
Drives: 2018 BRZ
TireRack did a fairly good test on tire width vs. wheel width and more stretch did result in better times, sometimes more than putting a wider tire.
Ohio Enthusiast is online now   Reply With Quote
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
ZDan (10-11-2024)
Old 10-11-2024, 08:18 AM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
Great test, but I have to wonder if the 225/45-17 advantage might be partially due to gearing. 215/45-17 and 245/40-17 are the same diameter, 225/45-17 is taller. If the course favored taller gearing it would make a real difference on a short course like Tire Rack test track...
Would have been more informative to see 225/45-17 vs. 235/40-17 vs. 235/45-17 vs. 245/40-17.
But it's impossible to have a perfect test, I really appreciate all the testing Tire Rack does! I always try to buy from them because of all the testing they do.
RT-BRZ (10-12-2024)
Old 10-11-2024, 12:56 PM   #9
RedReplicant
Drives: None
Match section width (that is not the number on the side of the tire) to wheel width if you want to maximize a tire (other than Hoosier / non-DOT), going wider tire wise generally is not faster on track (autocross is probably different). It is what Andy Hollis and 949 have been saying for over a decade backed up by data and what GRM and Tire Rack have been trying to make more known over the last few.
You do you though.
Old 10-11-2024, 11:20 PM   #10
dave99rt
Drives: '22 BRZ
You do you though.
Yep, for autocross most go wider or widest tire when restricted to narrow OEM wheels. Height for higher peak speed is also important. Bigger tires help with heat management also.
245/45/17 on 7.5" is commonly used in DS. It's the perfect blend of higher top speed and not overly pinched with the taller sidewall. 235/45/17 would be my second choice.
2022 BRZ
dave99rt is offline   Reply With Quote
Old 10-12-2024, 07:51 PM   #11
GrandSport
GrandSport's Avatar
Heat and wear management are the biggest reasons as its endurance racing (WRL). 8% more tire, 8% more thermal mass. 8% more surface area to cool down the tire. Plus, less sidewall is nice.
Also, narrower tire on a wider wheel is harder to drive, even if it's faster. That's an issue for a 16 hour race.
Regarding the actual test results, it looks like 225 on 9" wheel is the fastest, but 245 on 9 is just a hair behind it and the 245 on 9 had the fastest lap (just not averaged out). 275 on 10 is basically the same as 245 on 9 (1 inch is 25, so it's almost exactly 270 on 10). Given this is enduro, it's hard to see why those test results do not support 245 +9 which would say 275 on 10.
It does support running a 245 over a 255 though.
IDK, can we fit a 10.5 or 11 inch wide wheel? 295/30/18 is really the "best" size because of gearing/height. The 275/35/18 is more than half an inch taller than the 255 and nearly an inch taller than the 245.
The 255 might be the worst size.
The Following User Says Thank You to GrandSport For This Useful Post:
ZDan (10-13-2024)
Old 12-18-2024, 08:23 PM   #12
GrandSport
GrandSport's Avatar
So they now have 275/35/17 which resolved this issue. I can't imagine a 245/40 or 255/40 is faster on a 275/35 as it is much wider and shorter than the other two.
As far as 245 vs 255, hard to tell on grip going from one day to another (I didn't even drive on them that day, another driver just did 1 session to scrub in) but he definitely noticed the height. If he noticed the bog more, it's hard to imagine the extra grip helped enough.
All on a 9.5" wheel.
BTW: It rained and we ran rains both days. So I have 2 sets of 255 and 1.5 sets of 245s (because the conti extremes are made of forged steel) to mess around with.
Old 12-19-2024, 09:17 AM   #13
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Also have to consider the brand/model when making that comparison.
For example the RE-71RS 245 and 255 have the same tread width, the 255 is just a little taller. Whereas on the A052 the 255 has a good bit more tread width then the 245 and is a little bit taller as well.
Breezio is offline   Reply With Quote
The Following User Says Thank You to Breezio For This Useful Post:
RT-BRZ (12-19-2024)
Old 12-19-2024, 10:09 AM   #14
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
It is absolutely the little details like this that matter. Thanks for pointing it out.
RT-BRZ is offline   Reply With Quote
The Following User Says Thank You to RT-BRZ For This Useful Post:
Breezio (12-20-2024)
Running light "Tail" fuse in foot well keeps blowing **Fixed** paintdude258 Electronics | Audio | NAV | Infotainment 0 04-12-2017 03:59 PM
"LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" F-T Exterior Parts - Lighting 169 08-20-2016 01:15 PM
Anyone running "on-axis" components up front? Vmax911 Electronics | Audio | NAV | Infotainment 25 08-31-2015 12:20 AM
"LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" F-T Exterior Parts - Lighting 187 05-15-2013 01:07 AM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
