Southern California SoCal
Old 10-09-2024, 02:27 PM   #1
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
Car for sale 2014 FRs - part list
Taking offers
Read post for information thank you.
Gutted 2014 FRS clean title 125k miles on chassis
2019 fa20 swap 5k miles on motor
All the parts have less then 1k
Been parked in garage for the last 2 years.
Part list
[ ] Baffled oil pan
[ ] roll center correction kit /bump steer kit SPL
[ ] Schroth Harness
[ ] Bucket seat- ergo
[ ] Rear SPL LCA
[ ] Subframes risers PBM
[ ] Short final drive 4.3 from 2019 gt86
[ ] TORRINGTON BEARINGS
[ ] Driveshaft shop aluminum 11lbs
[ ] Chassis mounts splitter battle aero
[ ] Hood vents verus
[ ] FT 86camber plates
[ ] 17 x 9+35 rpf1
[ ] Radium catch can mastercylinderbrace
[ ] Rce t2 coilovers
[ ] Perrin inlet tube
[ ] Perrin steering rack lockdown
[ ] M tech shifter spring
[ ] Perrin white line transmission bushing
[ ] 1320 UEL & overpipe
[ ] Oft tablet
[ ] Berk test pipe
[ ] Berk muffler delete
[ ] Perrin front 22mm sway bar
[ ] Exedy OEM Clutch Kit
[ ] Velox Billet Clutch Fork
[ ] Velox Billet Clutch Fork Pivot
[ ] Perrin 22mm rear sway bar
[ ] Oil cooler
[ ] Sparco base side mount
[ ] Sparco CHAMPION Steering Wheel
[ ] Splash 540S Short Boss Steering Wheel Hub Kit
[ ] NRG Generation 2.5 Quick Release
[ ] Koyo Aluminum Racing Radiator
[ ] MTEC Stainless Steel Clutch Line
[ ] Koyorad All Aluminum Radiator Filler Neck
[ ] Koyorad 1.3 Bar High Pressure Radiator Cap
[ ] Fluid dampener Crank pulley
[ ] Radiator hoses
[ ] Greddy oil baffle plate
[ ] Killer b oil pickup tube
[ ] Velox bell housing trans cover
[ ] Velox pedal spacer
[ ] SuperStik Performance Dip Stick
[ ] Spl traction arms
[ ] Spl toe arms
[ ] JDL front bash bar
[ ] AP Racing Competition Front Brake System
[ ] Diff cradle bushings super pro
[ ] Perrin CAÍ
[ ] Front lower control arm SPL
[ ] Professional Awesome Racing Aluminum Fender Louvers $
[ ] 2019 fa20 5k miles
[ ] Rear upper control arm bushing super pro
[ ] Swift Coilover Springs
[ ] IRP shifter
[ ] Light weight flywheel
Probably missing a few things
el-92 is offline   Reply With Quote
My special 2014 FRS mod list with some pictures. BrakeCheck BRZ First-Gen (2012+) — General Topics 11 12-08-2023 01:16 PM
FS: big aftermarket part out list 949 Racing Cars for Sale/Trade 13 06-10-2022 08:50 PM
GT86 Part List and Exploded Views (PDF file) + other stuff... Harvey Scion FR-S / Toyota 86 GT86 General Forum 32 03-12-2020 11:11 AM
Part list for Eibach/Koni combo install? Chuckable Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-03-2019 12:41 PM
[2014 FR-S] Top Exhaust List Mash-Up Mikeez Engine, Exhaust, Transmission 34 01-29-2014 04:51 AM
