Old 05-01-2019, 11:49 PM   #1
Chuckable
Drives: 2017 Toyota 86
Part list for Eibach/Koni combo install?
About to order the Eibach/Koni combo and want to build them to be ready to bolt in so that the stock struts remain fully assembled. Based on the tutorials I’ve read and watched, I believe I need the following parts.
Can anyone please confirm or tell me where I’ve gone wrong? Thanks!
Chuckable is offline   Reply With Quote
Old 05-02-2019, 09:52 AM   #2
Chuckable
I called Koni for clarification and this is what you need to make a complete front assembly.
Old 05-02-2019, 10:28 AM   #3
Chuckable
And here for the rear.
Old 05-02-2019, 10:29 AM   #4
wparsons
wparsons's Avatar
3/4/5 don't need to be ordered, they're the bolts/nuts that hold the strut to the knuckle and need to come off to get the old assembly out. Not sure why it shows two top nuts, there's definitely only one. You need the rest though.
You'll also need the parts for the rear too
*edit* - you snuck in the post for the rear while I was typing.
I'd check to see if your springs come with bump stops before ordering new ones, they're like $20 each IIRC.
flickr
Old 05-02-2019, 12:05 PM   #5
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
12 is the nuts which attach the top of the strut mount to the strut tower, I'm not sure why they don't show the analogous one in the rear parts breakout. 3/4 are strut to knuckle and as you mentioned not needed, so as the same they show 12 for strut to strut tower. 2 is the top nut on the front and 9 is the top nut in the rear. 2/3 in the rear is for connecting the strut to the rear lca.
Tristor is offline   Reply With Quote
The Following User Says Thank You to Tristor For This Useful Post:
wparsons (05-02-2019)
Old 05-02-2019, 07:44 PM   #6
Chuckable
Thanks wparsons and Tristor for the feedback. Yup, the diagrams aren’t the best but all I could find online. The second nut on the front strut is actually just a dust cap apparently.
Old 05-03-2019, 11:41 AM   #7
wparsons
wparsons's Avatar
13 is the dust cap, 2 and 12 are definitely nuts.
flickr
FS: NJ/NY Koni yellow with Eibach Pro Kit springs. Joon525 Brakes, Suspension, Chassis 12 06-10-2019 12:12 PM
Koni Yellows + Eibach Springs [OH] RavioliG Brakes, Suspension, Chassis 4 01-14-2017 08:07 PM
Eibach Pro Kit + Koni Yellows. What else? Stang70Fastback Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 10-07-2015 03:00 PM
Koni Yellows + Swift Sport Mach Springs **COMBO DEAL** $890 SHIPPED!!! Kami Speed Brakes, Suspension, Chassis 13 07-27-2014 06:15 AM
