Old 10-04-2024, 07:02 PM   #1
Shadow6
Drives: 2014 Scion FR-S
Direct injector seals?
https://youtube.com/shorts/uk093vMmA...Z47zsr6crJdqoT
Would this be the direct injector seals? I just had them cleaned (CSG) so I’m inclined to think I messed one up in reinstallation. But, mine sounds like rocks hitting the firewall and examples of the direct injector seal noise sound much louder.
2014 Scion FR-S M/T
DD, autocrosser, track day car
Shadow6 is offline   Reply With Quote
Old 10-05-2024, 01:08 PM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I would think that bad DI seals would have a more rhythmical and less a mechanical sound. What does it sound like under the hood?
Old 10-05-2024, 09:02 PM   #3
Shadow6
It’s hard to get it to make the sound without a load, so I’ve yet to hear it from under the hood.
I do think it’s getting worse, so I guess maybe I’ll be able to hear it while revving without a load soon.
2014 Scion FR-S M/T
Old 10-06-2024, 09:12 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, sounds like DI seal.
Old 10-07-2024, 12:31 PM   #5
Shadow6
Gracias. I think it’s gotten worse so I’m going to try to confirm this week with my stethoscope thing.
Any advice before I start the job? I put the injectors in, but they were redone by CSG, so I didn’t have to mess with seals last time.
Also, I’m pretty sure I screwed something up, because I just put the redone injectors in around mid-June and I’m already having this issue.
2014 Scion FR-S M/T
Old 10-07-2024, 07:58 PM   #6
blsfrs
blsfrs's Avatar
Before you installed them, did you put the injectors in the freezer?
Old 10-07-2024, 10:15 PM   #7
If freezer is good, would dry ice be better? Do you think it could make the seals too brittle?
blsfrs (10-09-2024)
Old 10-08-2024, 09:43 PM   #8
Shadow6
Nope. I read about that, but they went in pretty easy at room temperature. I’ll do the freezer trick next time.
2014 Scion FR-S M/T
The Following 2 Users Say Thank You to Shadow6 For This Useful Post:
Ultramaroon (10-09-2024)
Old 10-09-2024, 01:23 PM   #9
The seals are supposed to stay low on the injector and ride up into the tapered area only after installation. The freezer trick hardens them long enough to keep them in place during insertion. If they get nicked even a bit, game over.
It's an extremely delicate operation normally performed with a special tool.
Shadow6 (10-11-2024)
Old 10-09-2024, 02:59 PM   #10
Shadow6
Huh, can you direct me to that special tool? Might be worth picking up.
2014 Scion FR-S M/T
Old 10-09-2024, 05:21 PM   #11
https://gt86stuff.onrender.com/t3Por...00Q4608BX.html
Shadow6 (10-09-2024)
Old 10-09-2024, 09:29 PM   #12
Shadow6
This is where I get confused. Is there a special tool for inserting the assembled injector into the cylinder head? Or are you talking about the SST for installing the seals to the injectors?
I had the injectors cleaned and new seals and o-rings installed. I did not install the seal to the injectors. In fact I had all eight cleaned because I ran E85 in the car for about 70k miles.
Can you recommend a good video on the process? Without the visual I keep getting confused about what part of the process is being discussed.
2014 Scion FR-S M/T
Old 10-10-2024, 08:49 AM   #13
blsfrs
blsfrs's Avatar
Google around. There a plenty of threads like this one on this subject.
https://www.ft86club.com/forums/show....php?p=3458349
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
Shadow6 (10-10-2024), Ultramaroon (10-10-2024)
Old 10-10-2024, 12:20 PM   #14
The tool aids installation onto the injector. I see how I wasn't clear about describing that.
Shadow6 (10-10-2024), strat61caster (10-13-2024)
Issues with direct injector seals, 2017 model lwvyruz Issues | Warranty | Recalls / TSB 2 09-02-2020 07:47 PM
Another Direct Injector Seals thread AndyBRZ Engine, Exhaust, Transmission 14 10-23-2018 06:22 AM
Is there a Subaru TSB for the direct injector seals? armstrom Issues | Warranty | Recalls / TSB 5 06-13-2016 02:37 PM
do the direct injector seals need to be replaced? Astroboy Engine, Exhaust, Transmission 17 04-15-2015 06:01 AM
Injector Seals went Bad while tuning my car whitefrs Forced Induction 128 08-20-2013 12:19 PM
