Old 10-02-2024, 05:39 AM   #1331
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by zeal86 View Post
Sorry for the late response...I must have missed the notification.
I used an 80 grit nylon wheel to clean it up and knock off the heavier texture...then 320, 400, 600, 800, 1000, and 1500. I used a DA where I could from 320 to 600 and finished up the tighter spots by hand. I used abrasive buffing wheels on my rotary tool up to 800 for the nooks and crannies. Took it to 1500 from 800 by hand only.
I didn't want little chunks of the polishing bars making their way into the alternator openings so my final polish was ONLY with Mother's metal polish. I went over each section 4 times...3 with felt wheels and one with a loose cotton wheel. I only used large buffing wheels on the center strip area that I ended up painting red. I used the white and red bars from my Harbor Freight polishing kits. It was easy to get to and the surface was uniform. I covered the alternator openings with blue tape.
The paint is Metal Cast Anodized Red from Dupli-Color...I sprayed it directly over polished metal. During this process, I used 91% alcohol to clean the strip in preparation for paint.
That about covers the process for the alternator. For most other less irregular surfaces...I use buffing bars after sanding then finish with a metal polish.
www.instagram.com/zeal.eightsix
Thank you for the detailed response! Do you have any idea how many hours went into it? I was thinking that you had to take it apart to get it polished this well. There's lots of nooks and crannies.
Old 10-02-2024, 06:06 AM   #1332
zeal86
zeal86's Avatar
Drives:
I did not take it apart...that's why I only sanded it then used Mother's Metal Polish...the polishing bars will shoot off bits and pieces here and there that could get trapped inside the alternator housing.
I vacuumed and blew out any sanding dust that I created.
zeal86 is offline   Reply With Quote
Old 10-13-2024, 03:04 PM   #1333
zeal86
zeal86's Avatar
Drives:
I finally painted the engine but I still need to paint the oil pan black.
I primered, painted aluminum, and gloss cleared the engine using Dupli-Color high heat engine enamel line of paints. I degreased engine surface prior to paint with Spray Nine.
I need to order a bunch of seals, o-rings, etc. Also, I did install my Fumoto valve on the oil pan.
I will be doing some more polishing and painting of engine parts...those pics will follow soon.
Project turned out pretty good...I can't wait to start putting everything back together!
Old 10-23-2024, 03:37 PM   #1334
zeal86
zeal86's Avatar
Drives:
Here I've mocked up my red aluminum intake manifold, polished throttle body, polished fuel rails, polished coolant x-over pipe and painted and cleared engine. Next up is polishing the alternator cradle and the A/C compressor. I will also be painting the direct injector fuel rails anodized red.
I will be ordering a bunch of seals and o-rings for the installation of all the removed components...after those are installed I will put together the engine minus the red intake manifold. I'll wait until the engine is back in the car for that because I don't want to scratch it up with the engine hoist chains.
Also, I previously primered the oil pan when I primered the engine, the last pic shows the final results.
I will be building another rolling table with mounts that mate up with the engine. I need to get the engine off the stand in order to work on the Exedy clutch and flywheel.
Old 10-23-2024, 03:41 PM   #1335
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Amazing work on this!
Looks great!
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
Old 10-26-2024, 12:50 AM   #1336
zeal86
zeal86's Avatar
Drives:
Here are a few pics of some components temp installed. I'll reinstall the alternator and intake manifold once the engine is back in the RS1 to avoid damage from joist chains. Verus cam plate is installed and torqued.
I will start installing all the brackets and such that don't require o-rings and seals. I still need to clear coat 3 polished pulleys then clean and paint the tensioner pulley gloss black. Also, I will be installing the painted Verus fuel rail covers.
Old 11-14-2024, 04:32 AM   #1337
zeal86
zeal86's Avatar
Drives:
Can't do nice wheels any justice without a big brake kit peeking through the spokes!
A/C Compressor is polished...I'll post pics soon.
Also, I just received a bunch of seals, o-rings, grommets, nuts and bolts, etc. for the build. I hope to have the engine put together by the end of the weekend.
Next up will be building an engine stand that allows me access to the clutch and flywheel.
After that is complete, I will tackle the transmission. I have a Cusco reinforced clutch fork and pivot to install along with a new OEM throwout bearing and other bits. I will be prepping the transmission for paint just like the engine.
Old 11-15-2024, 07:21 AM   #1338
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Did you go Blitz because of MF ghost ?
autoracer86 is offline   Reply With Quote
Old 11-27-2024, 10:22 PM   #1339
zeal86
zeal86's Avatar
Drives:
I don't know what MF Ghost is so no. What is MF Ghost? Sounds like an anime title.
Old 11-28-2024, 12:01 PM   #1340
zeal86
zeal86's Avatar
Drives:
Btw...I finally posted a bunch of parts for sale...see them here...
https://r.tapatalk.com/shareLink/top...ink_source=app
I'll be prepping some more items for sale soon...
Old 11-28-2024, 08:45 PM   #1341
autoracer86
Drives: Toyota GT86
Haha yup. It’s the extra brakes they install on his 86. Probably a more common bbk in Japan
Old 02-11-2025, 01:52 AM   #1342
zeal86
zeal86's Avatar
Drives:
Made a couple changes to my builds.
Build # 2 will now be my (new to me) 2015 Subaru BRZ Limited in CWP (K1X). RS1 will stay yellow, keep the Robot Craftsman widebody kit, and be sold. Engine from RS1 will go into the BRZ.
Also, I will keep the BRZ narrow body and install the pictured AimGain GT-S kit (on order) . I will not be running the pictured wing though. The wing or spoiler I will run is yet to be determined.
I will be ordering Work CR 2P Emotions for this build. I will be selling my near mint Work S1 3-piece wheels...if anyone is interested DM me about it.
Work S1 3-piece
18x9.5 +3 5x100 4.5” lips 5” barrel A-DISK
18x11.5 -35 5x100 6.5 lips and 5” barrel A-DISK
More to come...
Old 02-11-2025, 01:53 AM   #1343
zeal86
zeal86's Avatar
Drives:
A little cleanup needed for this future show car first though...
(I will be putting all these parts up for sell soon)
- OFT Stage 2 tune + 93
- OFT Tablet included
- CNT Racing Headers
- MXP Comp RS Catback exhaust
- Clear tail lights
- Apex Flow Formed Wheels (17x9)
- Brand new Continental tires (245/40/17)
- Lowering springs
- Lightweight crank pulley
Old 02-12-2025, 08:40 AM   #1344
zeal86
zeal86's Avatar
Drives:
I've been collecting cheap and used Cusco suspension parts so I can strip them and prepare them for powder coating. Some will be powder coated chrome/polished and others anodized red.
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
Kylefrs Build Thread kylefrs Member's Car Journals 14 01-28-2015 08:27 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 07:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 07:34 PM
