Old 09-27-2024, 10:02 AM   #99
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Bit of an update during my alignment with div88 he was telling me my rear toe arms were a pain to work with so I used that as an excuse to order SPL rear toe arms they will sit in the box till closer to the new year when I get my next alignment done.
I also went ahead and did my 3rd oil analysis which consisted of my two UK road trip and the drive there and back. All came back fine as you would hope to expect from basically new oil.
And finally my car has passed its first NCT with me as its owner NCT is what Ireland uses for road inspection and unlike in the states its pretty serious and failures are common. I mean sure I know my car is fine but now so does the Irish government lol
autoracer86 is offline   Reply With Quote
Old 09-27-2024, 10:22 AM   #100
autoracer86
Drives: Toyota GT86
Wednesday was probably my last track day of the year and it was a good one ! I set a new personal best and lap record for a stock power 86. Oh and get what is now my new favorite photo of the 86
Things to note I finally broke hard enough to get some proper heat into the front brakes. Those temp stickers that never moved have nearly maxed out in the front... The rears still don't register ha.
Comparing my previous 2:05.4 to 2:03.5 it's clear I am using a more brake pressure everywhere especially into T1 and the last corner. So Braking harder and later.
I am not sure if the tires just needed a heat cycle or if I needed to step up my game to maximum gains from the Potenza race tires but I had loads of confidence Wednesday and was putting down 2:05s with ease and 2:04s without much struggle. Colder track temps I am sure played in my favor
I was definitely pushing to get that 2:03.5 but the data shows a 2:02.9 was possible and honestly once I did the 2:03.5 I started my cool down lap and then rain came so who knows how much faster I could have gone.
At least now I have a good reference lap to build on for next year as I shoot for 2:02s. Will need power mods if I ever want to go sub 2s for sure
The 0.5L overfill which worked well at Donington/Oulton Park also helped at Mondello Park. So for my grip level and speed I am not seeing a need for a baffle or pickup mod.
In stock form with PS4 tires the best I did was a 2:07.9 and now with upgraded wheels tires and suspension I am doing 2:03.5 both done in similar weather conditions.
The Following User Says Thank You to autoracer86 For This Useful Post:
RToyo86 (03-19-2025)
Old 09-27-2024, 10:23 AM   #101
autoracer86
Drives: Toyota GT86
September 25th Track day
Track Temp 47.8F/8.7C
Max Speed: 93.3MPH/150KMH Down from 95MPH/152KMH
Max RPM: 7436 Up from 7417
Max Brake Pressure: 1326PSI Up from 966PSI
Max Oil Temp: 251F/121.6C
Max Coolant Temp: 195.8F/961C
Oil Pressure: 32.1PSI - 52.9PSI AVG 46.4 Up from 27.2 min
RedReplicant (02-05-2025)
Old 09-27-2024, 11:37 AM   #102
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Really solid lap!
Glad to see the oil pressure improved even with the "high" oil temps!
The Following User Says Thank You to DocWalt For This Useful Post:
autoracer86 (09-27-2024)
Old 09-27-2024, 12:26 PM   #103
autoracer86
Drives: Toyota GT86
Originally Posted by DocWalt View Post
Really solid lap!
Thanks man and yeah happy to see I don't have to spend money on oil mods that I don't even believe work haha
Old 02-05-2025, 12:08 PM   #104
autoracer86
Drives: Toyota GT86
With my off season sorta coming to a close and my UK 2025 track days booked I figured it's time to update the thread
Back in December I installed a Aim MXS Strada digital dash. I have always wanted one and finally convinced myself to get one under the pretence that having alarms for things like oil pressure was mandatory on track
Total overkill but I do enjoy finally getting to see my temps and pressure when I am driving on the street. Previously I only saw these on track as I didn't leave the solo 2 in the car... Plus alarms! ha
Install was pretty simple Can bus data come from OBD2 port power from the fuse box and ground from the nut that holds on the fuse box. I haven't used the display on track yet but on the street it has been great. Not a single issue and puts a smile on my face.
My first track day of 2025 will be in April at Mondello so come March I will doing my normal Trans/Diff/Brake/Engine oil change plus coolant for the first time since my ownership and probably since the car was new. Also have the alignment and corner weight checked at Division88.
2025 will also be my first time at Anglesey and my first time driving the 86 in a competition via a Javelin Sprint event. I will also be returning to Oulton Park and Donington.
Planned upgrades for the year are a BBK and A052s for my UK track days.
The Following 5 Users Say Thank You to autoracer86 For This Useful Post:
DocWalt (02-05-2025), KMA KiCKz (02-06-2025), RedReplicant (02-05-2025), RT-BRZ (02-05-2025), villainous_frx (02-07-2025)
Old 02-05-2025, 12:10 PM   #105
autoracer86
Drives: Toyota GT86
If you wanted to know more about setting up the display I posted a video about it
The Following 6 Users Say Thank You to autoracer86 For This Useful Post:
2.2Lude (02-11-2025), DocWalt (02-05-2025), KMA KiCKz (02-06-2025), RedReplicant (02-05-2025), Teseo (02-05-2025), villainous_frx (02-07-2025)
Old 02-11-2025, 08:23 AM   #106
Prodigalson
ThisGuyLoves86's
Prodigalson's Avatar
Drives: 2013 Scion FRS
Following along!
2013 Scion FRS (current car)
1991 Mazda Miata MX5 (current car)
2003 Nissan Pathfinder (R50) (current car)
2018 Lexus GX460 (current car)
2023 GR86 Neptune M6 Premium (Leased)
Prodigalson is offline   Reply With Quote
The Following User Says Thank You to Prodigalson For This Useful Post:
autoracer86 (02-11-2025)
Old 03-19-2025, 02:12 PM   #107
autoracer86
Drives: Toyota GT86
First track day of 2025 in the books. Had a pretty good morning session was a lot of fun dealing with the traffic... The afternoon not so much unfortunately my friend who was driving the car in the afternoon had an off so I never got back on track. All the damage is being repaired and I hope to be back on track for the circuit social on April 2nd
I did manage to get a somewhat entertaining video of me chasing down a buggy 350z and s2000 so enjoy
The Following 4 Users Say Thank You to autoracer86 For This Useful Post:
Code Monkey (03-23-2025), DocWalt (03-19-2025), KMA KiCKz (03-30-2025), villainous_frx (03-22-2025)
Old 04-08-2025, 06:37 AM   #108
autoracer86
Drives: Toyota GT86
The car had its first alignment of the year and installed some SPL toe arms as well.
Mechanically everything checked out after the off just needed an inner/outer tie rod. Full body repair will happen towards the end of the month.
I was able to make the April 2nd track day and all went well enough. Managed to match/slightly beat my current personal best. I have one more track day on the 21 before the car goes down for the body work.
Also planning to order a Brembo bbk from godspeed along with hardrace control arms and the Jacksonracing anti dive kit. So another alignment/install incoming before my UK trackdays
The Following 3 Users Say Thank You to autoracer86 For This Useful Post:
DocWalt (04-08-2025), villainous_frx (04-11-2025), ZC6_STi (04-08-2025)
Old 04-29-2025, 05:40 AM   #109
autoracer86
Drives: Toyota GT86
Took a little advantage of a trip to the states to bring back some parts When the car was getting aligned last he noted that the front control arm bushings were starting to go.... So seeing as I was ordering new control arms might as well get the anti dive kit from jackson racing haha.
Was getting time to replace my 949racing lug nuts so ordered a fresh set. Its 100bucks cheaper to get them in the US vs Ireland
The 3d printed part was done my friend and fellow ft86club member much easier for him being in the US to ship to a US address plus no issues with customs! It's a bracket for my AIM MXS strada. He printed one in purple as well I am using as a test. I got a new steering column hood as well which I will be using with the black one you see in the photo
And the tiny piece of metal is to fix the bumper sag. I got that along with the revised plastic bumper/fender clips. The car has been dropped off to the body shop to repair the damage so might as well finally fix the bumper sag. This part is actually from Australia though haha
The Following 2 Users Say Thank You to autoracer86 For This Useful Post:
DocWalt (04-29-2025), villainous_frx (04-29-2025)
Old 04-29-2025, 05:44 AM   #110
autoracer86
Drives: Toyota GT86
Highlights from the trackdays.ie action day. Traffic and weather was crazy! I don't think I ever got a full 20 mins in the dry... Was raining off and on while on track all day. One session got so bad towards the end everyone came in and a few mins later it started to hail. Of course then the sun comes back out 5 mins later haha.
Traffic in our group was pretty bad as you will see. I think we got a lot of first timer mostly car show people so they had zero clue. I guess we all have to start somewhere but I would be shocked to see them again lol
DocWalt (04-29-2025), RToyo86 (04-29-2025)
Old 05-04-2025, 02:23 PM   #111
autoracer86
Drives: Toyota GT86
Really happy with the 3D printed bracket for the Aim dash. Looks great if you ask me
DocWalt (05-04-2025), jcaserta (05-05-2025), KMA KiCKz (05-14-2025), villainous_frx (05-08-2025), whataboutbob (05-04-2025)
Old 05-04-2025, 07:38 PM   #112
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Dang that looks fantastic!
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
autoracer86 (05-05-2025), villainous_frx (05-08-2025)
Scratchy Noise and Peddle vibration Sovereign Issues | Warranty | Recalls / TSB 7 07-19-2022 06:36 PM
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
JC's hot lava/burnt orange 2014 GT86 build thread GT86NZID Member's Car Journals 11 08-25-2016 11:41 PM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 05:00 PM
Orange you glad you checked this thread?!? BlaineWasHere FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 23 04-09-2013 06:02 PM
