Old 07-27-2022, 10:42 AM   #141
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ
Gen2 Brake bias - square pads
Stonehorsw is offline   Reply With Quote
Old 09-30-2022, 04:22 PM   #142
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Originally Posted by Will_ View Post
On track, do the front and rear brakes typically run at similar temps, or is there enough of a difference to justify different pad compounds?
On my previous track car (MK7 GTI) the rear brakes were practically disconnected, they ran about 300f cooler than the fronts and after 55k miles and 20 track days the rear rotor was only worn about .5mm. I assume on this platform however it is more evenly distributed.
My car will be dailied and see 8-12 track days a year. Since I live in an apartment and don’t have much space to work on my car, ideally what I would like to do is run the same rear pads year round (probably DS2500 or similar) and just swap fronts at the track same day. So my track setup would be DS3.12 front and DS2500 rear. Will be running at most a 245 200tw tire, but likely 225/40/18 street tires for the first 6-10 track days. Feasible? Or do I just suck it up and get to the track earlier to swap both front/rear pads?
MK7 GTI is such a different vehicle compared to the BRZ/86. The way it distributes the braking is very...modern Euro so that has to be taken into account. This is often why people used to setting up old Japanese cars will have an insanely difficult time setting up Euros.
At 8-12 trackdays, the focus should really be to run track focused brake pads. Commuting heavily means you should just throw in street specific pads. In terms of 200TW tires, the grip range varies heavily so finding a pad that can manage in those tire application range is important. A pad with heavy bite could be incredibly challenging on mitigating ABS activation on lower grip 200TW tires. Likewise, some better controlling budget pad could be great for low grip 200TW tires, but would be easily overwhelmed with high grip 200TW tires.
If you're dead set on Ferodos, focus on running towards the race spectrum of the pad setup. We can help provide some options!
CounterSpace Garage is offline   Reply With Quote
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
Will_ (09-30-2022)
Old 11-03-2022, 11:04 PM   #143
afishl1
Drives: Raven FRS MT
Ceramic pads
Probably a dumb question, but can you run ceramic pads on the stick rotors or would you have to change the rotors as well?
Also, anyone know if the Bosch Quiet Cast are any good?
afishl1 is offline   Reply With Quote
Old 12-31-2022, 01:07 PM   #144
Smurfette_BRZ
Drives: Blue 2020 Subaru BRZ
Hey guys, new to this whole brake upgrade situation.
So I have 2020 BRZ limited with coilovers, 18x9.5 +35 rims , 255/35R18 tires, stock brake setup.
My stock pads are finally wearing down so looking to upgrade to something better.
I use the car for DD (@ 42k miles already - bought with 50) and alot of weekend cruises / spirited driving on the backroads.
Looking to hopefully get into the occasional autox/track by this summer once I can buy another car and use this car mostly as a weekend warrior.
Looking to upgrade the pads/rotors for now. I saw a lot of people say Project Mu on another forum.
Any suggestions?
Thanks !
Smurfette_BRZ is offline   Reply With Quote
Old 12-31-2022, 02:44 PM   #145
Jdmjunkie
Drives: Scion FR-S 10 Series
Any suggestions?
Thanks !
What is you budget?
Jdmjunkie is offline   Reply With Quote
Old 12-31-2022, 03:54 PM   #146
Smurfette_BRZ
I would say no more than 300-400 if doable . I can throw down more if the upgrade is worth it
Old 12-31-2022, 07:23 PM   #147
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
If you know you will be doing HPDE on road courses, skip hybrid pads; they won't keep up (Hawk HP and HP+ street pads for example are notorious for melting down at track days, but their track-dedicated DTC line fare just fine).
Most entry level dedicated track pads have a pretty wide usable temperature range, so you can daily them as well (with some compromises). Serious track pads shouldn't be used on a daily basis because they don't get up to nominal operating temperature and wear out brake components very quickly
Dedicated track pads are $400 for a front and rear on their own already (unless you go ultra budget with something like Power Stop SPEC Pads).
  • If you're set on Project Mu, the Club Racer/Advance are a good choice. I drove on them for sometime dual duty daily and track.
  • Carbotech XP8 or XP10 are also well enjoyed entry level pads
  • People have had good success with Power Stop SPEC race pads. They are quite inexpensive and hold up well during track use, but they wear out and need replacing frequently. They might be a good choice if you are having a hard time deciding on a higher end set and just want to get your feet wet ASAP.
As for rotors, stick to OEM or OEM replacement blank rotors. You don't need anything more, but don't forget to add that to your brake budget (about ~$200 for front and rear). If you are looking for something high end, I have spoken to people that have had good success and satisfaction with DBA rotors; good quality and longevity.
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
SCFD (01-01-2023)
Old 05-17-2023, 12:42 AM   #148
Jibbin
Minghag
Jibbin's Avatar
Drives: 2014 WRB BRZ
Trying to figure out what brake fluid to go with, has anyone experienced any noticeable difference in the ABS behavior switching to a higher viscosity DOT4 fluid? I do some autox and have roads near me that put a hurtin' on the stock brakes so I want to do a pad/fluid upgrade, but I also drive the car throughout the winter in 15-30 degree F temps. Should I be going with a 5.1 fluid or am I worrying about nothing?
Jibbin is offline   Reply With Quote
Old 06-02-2023, 10:29 AM   #149
Mr_Brian
I'm curious about this as well I'm thinking of going with Endless RF650 or Pagid RBF anyone have any comment on either fluid? The pagid stuff is 1/2 the price so I'll probably end up going with that. https://www.pagidracing.com/en/produ...ake-fluid.html
Mr_Brian is offline   Reply With Quote
Old 09-24-2024, 11:52 PM   #150
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
I just tried Endless RF650 this season. Love that stuff. Brake pedal feel is way better, and consistent throughout all my hot laps at the track when compared to previous fluids I’ve tried. Highly recommend.
kevaughan is offline   Reply With Quote
The Following User Says Thank You to kevaughan For This Useful Post:
Mr_Brian (10-20-2024)
Old 01-03-2025, 10:14 PM   #151
NoGoodNames
Drives: Toyota GT86
@JRitt
I currently have the Competition Sprint Brake Kit (Front CP8350/299) and want to upgrade to the Endurance Brake (Front CP8350/325mm). Can you sell me the required hardware such as the bracket, disc, hat, and bolts?
NoGoodNames is offline   Reply With Quote
Old 02-23-2025, 08:22 PM   #152
snuff58
snuff58's Avatar
Drives: 2014 Subaru BRZ Limited MTblue
Carbotech part numbers
I've been running Carbotech's for a while and I really like them! OE calipers and rotors, (292mm front). '14 Ltd. NA, 225/40-R18, 200TW, XP12 front, XP10 rear.
So, I'm due to buy some new pads and am in a quandary.
My last several orders have been CT929-XP12. Not sure of the rears, because they last forever.
Anyway, I went on Carbotech's website, and they specify CT1539-XP12, front and CT1124-XP10, rear.
Would someone like to chime in on why I have this part number discrepancy??
Please.
snuff58 is offline   Reply With Quote
Old 03-04-2025, 12:38 PM   #153
StraightOuttaCanadaEh
Wes
My OEM rotors (from 2017 with 140 km on them!) are finally due to be changed. I'm very confused about 2 piece rotors. According to google they're only a little bit lighter than the oem pieces, but not sure if that means brembo or non-brembo. I have the latter, so anyone know if there is a weight reduction there? Are those 17 lb or is that for the brembo rotors?
Instagram: @gt86ws
Old 03-05-2025, 09:39 AM   #154
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I am not aware of any 2 piece stock/non-Brembo rotors. Do you have a link?
brake, discs, lines, pads, rotors
R1 Concepts Brakes upgrade carlossanchez89 Brakes, Suspension, Chassis 1 01-13-2014 09:28 PM
Brakes for Turbo Upgrade? wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 08-29-2013 07:49 PM
HELP with understanding Brakes upgrade path bear89103 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 07-17-2013 08:08 PM
[StreetFX] 86 GT HID upgrade kit with DIY GUIDE! (including parking lights) WTF Australia Classifieds 12 08-14-2012 04:10 AM
[StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) WTF Australia Classifieds 0 07-11-2012 12:27 PM
