| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 |
Drives: 2018 BRZ
Final update (I hope) - after 100 miles, the left side boot indeed started leaking at the big clamp (flinging blobs of good grease around), and the small clamps continued to seep a bit of liquified grease.
Took the axles off the diff, disassembled the diff side CV joint, replaced the boot and clamps with the Subaru kit and used Redline CV-2 instead of the Subaru grease. I was lazy and did it on the car (without removing the axle nut and pulling the axle from the hub), but that was just fine and saved me the hassle of dealing with the axle nut. I started from trying to drop the diff, but that didn't work out so well and started leaking diff fluid (as I couldn't keep the diff level). Bolted the diff back to the car and instead went from the hubs - two bolts removed and it was pretty easy taking the axles out of the diff. The biggest struggle was actually getting the axles back into the diff. At first I hammered on the hub side (piece of wood on the axle nut), but that didn't do much. Then I hammered a large screwdriver on the small lip on the axle at the diff side and that went right in. Last edited by Ohio Enthusiast; 09-08-2024 at 08:51 AM. |
#16 | |
Drives: 2020 GMC Canyon Denali Diesel
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
#17 | |
Drives: 2018 BRZ
Edit: now that you mention it, the repair manual specifies 80-90 grams on the CV joint itself, and an additional 20-30 grams in the boot. I think I probably did less on the CV joint and more in the boot, but hopefully that'll even out when driving. Note to self - thoroughly read the instructions in the repair manual instead of trying to figure stuff on my own... |
#18 | |
| The Following User Says Thank You to Opie For This Useful Post: | Ohio Enthusiast (09-13-2024) |
#20 |
is it the grease, or air trapped in with it? I don't get grease expanding to the point of squeezing out. Trapped air, however... o.0
| The Following User Says Thank You to Ultramaroon For This Useful Post: | blsfrs (09-16-2024) |
#21 |
I think it's the amount of grease, too much and the rotation forces a clump into one side, making the boot flex until it comes out.
| The Following User Says Thank You to Opie For This Useful Post: | Ultramaroon (09-16-2024) |
#22 |
Drives: 2013 frs base
Prolly too much grease. I did the vent tube trick and it still blew. I was the left one. I wrapped my exhaust pipe after the last issue and have been good.
| The Following User Says Thank You to blsfrs For This Useful Post: | Ultramaroon (09-16-2024) |
| Diff Fluid Leaking after Axle and Axle Seal Replacement | jaygushi | Engine, Exhaust, Transmission | 3 | 12-21-2023 01:53 PM |
| Best source for axle boots | blsfrs | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 09-28-2022 03:58 PM |
| Dss axle boots riped | IsaiahW | Engine, Exhaust, Transmission | 0 | 07-09-2022 10:42 AM |
| AutoStyled - Hand-Crafted Shift Knobs/Shift Boots/Brake Boots Are Now Here! | RallySport Direct | Interior Parts (Incl. Lighting) | 4 | 06-23-2017 01:37 PM |
