Old 09-02-2024, 01:50 PM   #1
tcu_brz
Drives: Subaru Brz
2013 Brz Limited Limp Mode
We scanned the car and the pending code was P0137
Checked permanent codes and it has
P1235
P2096
P0087
I’m assuming it could the injectors or hpfp? Anyone have experience with these codes or suggestions on what I should do first?
tcu_brz is offline   Reply With Quote
Old 09-11-2024, 02:22 PM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I'd start troubleshooting with the fuel pump in the tank unless you are hearing really bad sounds in the engine bay.
How many miles are on the car?
Where's the last place you stopped for gas?
Any mods?
Also: "Build Thread"
Old 09-16-2024, 03:01 PM   #3
ojuniour
ojuniour's Avatar
Drives: Subaru BRZ 2017
One of three things 99% due to these codes:
Last gas you put in
HFPF
Fuel pump assembly (basically the regulator, fuel pump,..within the assembly..usually easier and cheaper to get used one from ebay and replaced who assembly).
Easiest way of course is to test for the Fuel pressure by unplugging one of the fuel lines and plug it in to a fuel pressure gauge, turn the car to ACC Mode and wait for a minute if it's holding pressure.
Good luck
ojuniour is offline   Reply With Quote
How to Fix Limp Mode? MidnightFumes Issues | Warranty | Recalls / TSB 7 01-20-2021 05:18 PM
Limp mode at 2K rpm NEED HELP!! Arthur_frs Engine, Exhaust, Transmission 5 04-13-2020 10:22 PM
Limp mode GTBOY Issues | Warranty | Recalls / TSB 4 06-07-2018 12:58 PM
Valet mode / limp mode? radroach Software Tuning 1 09-18-2017 11:34 AM
Car in Limp mode... No CEL Sportsguy83 Issues | Warranty | Recalls / TSB 60 08-20-2014 03:35 AM
