Cracked Ace A350 - anyone else?
Anyone else run into similar issue?
The topside O2 bung welds cracked open during a track day @ NJMP Thunderbolt (NASA Summer Sizzle). Had to apply high heat JBweld and safety wire it shut to limp it home. I bought this unit second hand - the header has been on the car for a little over 2 yrs, ~9,000 miles (50/50 highway, track miles). Stamping: NA-421-425063 86-0201 |
#2 |
Drives: 2013 Subaru BRZ SWP
Haha, yes. I've had had it crack there once, and then again after a washer was melted to reinforce the weld. I've also had cracks at the 4-2 merge and at various flanges. I've lost way too much track time with mine and have given up on repairing it. What's the point having great performance if it leaves you stranded?
I've been running the stock header again while deciding what to do next. |
| The Following 2 Users Say Thank You to ArCha For This Useful Post: | norcalpb (09-12-2024), waterpanda (09-11-2024) |
#3 | |
Working on getting my hands on a second set of A350 and repairing this one as backup. |
#4 |
Drives: Many
I've had mine for 7? years now, also purchased use. Autocross use, not track.
Wondering who has upgraded motor mounts? I have STI mounts and have always had. Wondering with a little less movement if that's part of the reason it survives. |
#5 |
I've been running STI engine and transmission mounts since I installed the header, I don't think that's a contributor here. I am running a Harrop supercharger though so maybe some extra load.
#6 |
Drives: Many
I figured, but wanted to ask.
I have expected mine to crack haha. |
#7 |
I have Cusco engine mounts and Cusco transmission collar installed *♂️
Another theory - the water leaking down onto the header from hood vents potentially cause thermal shocks to the welds |
#8 |
I don't have hood vents. I'm thinking this is more likely cycle fatigue. The material is too thin to have the strength to survive over a long period of abuse.
| The Following 2 Users Say Thank You to ArCha For This Useful Post: | norcalpb (09-12-2024), waterpanda (09-12-2024) |
#9 |
86 Challenge
Drives: 2017 BRZ
Yep, also had mine fail the exact same way. Ace makes their headers too thin with the wrong alloy of stainless steel so it happens to all with enough use. Sad because they would be amazing headers otherwise.
I switched to JDL and it’s already lasted significantly more track days. Last edited by mkodama; 11-16-2024 at 12:04 AM. |
| The Following User Says Thank You to mkodama For This Useful Post: | waterpanda (05-19-2025) |
#10 | |
Drives: 17 Asphalt 86
Latest iteration seems to have addressed most of the issues. I Massaged the understray where the one runner passes close during initial install. Does require a retune but process is pretty straightforward. Zak at CSG had mine done within 5 revisions. |
| Ace A350 header | iDriveProjects | Engine, Exhaust, Bolt-Ons | 1 | 05-06-2022 02:17 PM |
| FS: ACE A350 Header | Chris_ | Engine, Exhaust, Bolt-Ons | 1 | 01-10-2022 12:55 PM |
| Wtb ace a350 headers | Chriswongbrz | Want-To-Buy Requests | 0 | 05-26-2019 02:47 AM |
| WTH Ace A350 Header | ionbomb | Want-To-Buy Requests | 0 | 02-18-2019 11:51 AM |
| FS ACE Header A350 | mtsound | Engine, Exhaust, Bolt-Ons | 0 | 09-14-2018 12:44 PM |
