Old 09-10-2024, 12:25 PM   #1
waterpanda
Cracked Ace A350 - anyone else?
Anyone else run into similar issue?
The topside O2 bung welds cracked open during a track day @ NJMP Thunderbolt (NASA Summer Sizzle). Had to apply high heat JBweld and safety wire it shut to limp it home.
I bought this unit second hand - the header has been on the car for a little over 2 yrs, ~9,000 miles (50/50 highway, track miles).
Stamping:
NA-421-425063
86-0201
waterpanda is offline   Reply With Quote
Old 09-10-2024, 06:20 PM   #2
ArCha
Drives: 2013 Subaru BRZ SWP
Haha, yes. I've had had it crack there once, and then again after a washer was melted to reinforce the weld. I've also had cracks at the 4-2 merge and at various flanges. I've lost way too much track time with mine and have given up on repairing it. What's the point having great performance if it leaves you stranded?
I've been running the stock header again while deciding what to do next.
ArCha is offline   Reply With Quote
The Following 2 Users Say Thank You to ArCha For This Useful Post:
norcalpb (09-12-2024), waterpanda (09-11-2024)
Old 09-11-2024, 01:48 PM   #3
waterpanda
I too am hugely concerned about losing track time - I considered the JDL header, but it's not free of issues either based on some forum posts. It would also mean having to get a new tune.
Working on getting my hands on a second set of A350 and repairing this one as backup.
Old 09-11-2024, 09:41 PM   #4
e1_griego
e1_griego's Avatar
Drives: Many
I've had mine for 7? years now, also purchased use. Autocross use, not track.
Wondering who has upgraded motor mounts? I have STI mounts and have always had. Wondering with a little less movement if that's part of the reason it survives.
e1_griego is offline   Reply With Quote
Old 09-11-2024, 10:04 PM   #5
ArCha
I've been running STI engine and transmission mounts since I installed the header, I don't think that's a contributor here. I am running a Harrop supercharger though so maybe some extra load.
Old 09-11-2024, 10:23 PM   #6
e1_griego
e1_griego's Avatar
Drives: Many
I figured, but wanted to ask.
I have expected mine to crack haha.
Old 09-12-2024, 11:15 AM   #7
waterpanda
I have Cusco engine mounts and Cusco transmission collar installed ����*♂️
Another theory - the water leaking down onto the header from hood vents potentially cause thermal shocks to the welds
Old 09-12-2024, 03:30 PM   #8
ArCha
I don't have hood vents. I'm thinking this is more likely cycle fatigue. The material is too thin to have the strength to survive over a long period of abuse.
norcalpb (09-12-2024), waterpanda (09-12-2024)
Old 11-15-2024, 09:46 PM   #9
mkodama
86 Challenge
Drives: 2017 BRZ
Yep, also had mine fail the exact same way. Ace makes their headers too thin with the wrong alloy of stainless steel so it happens to all with enough use. Sad because they would be amazing headers otherwise.
I switched to JDL and it’s already lasted significantly more track days.
mkodama is offline   Reply With Quote
The Following User Says Thank You to mkodama For This Useful Post:
waterpanda (05-19-2025)
Old 11-15-2024, 10:58 PM   #10
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I've had JDL installed for 2y, 45,000km. Daily use, bit of light track duty, so far no issues. Snow, summer etc. also running STi engine/trans mounts.
Latest iteration seems to have addressed most of the issues. I Massaged the understray where the one runner passes close during initial install.
Does require a retune but process is pretty straightforward. Zak at CSG had mine done within 5 revisions.
Ace A350 header iDriveProjects Engine, Exhaust, Bolt-Ons 1 05-06-2022 02:17 PM
FS: ACE A350 Header Chris_ Engine, Exhaust, Bolt-Ons 1 01-10-2022 12:55 PM
Wtb ace a350 headers Chriswongbrz Want-To-Buy Requests 0 05-26-2019 02:47 AM
WTH Ace A350 Header ionbomb Want-To-Buy Requests 0 02-18-2019 11:51 AM
FS ACE Header A350 mtsound Engine, Exhaust, Bolt-Ons 0 09-14-2018 12:44 PM
