Old 06-04-2021, 02:04 PM   #29
RayRay88
Drives: 2017 86 860 Special Edition
Originally Posted by yEEt42069 View Post
Hey sorry for the super late response. I did get the extended wire harness and it was very easy, plug and play. You do have to play around a little with fitting the airbag back on because there is a little more wire sitting around.
Thanks for getting back to me. I actually installed it this past weekend with zero issues. It was a lot easier than I thought. I'm always hesitant with the clock spring and the airbag but I made sure the clock spring was held down as I pulled the steering wheel so it didn't move. Took me no more than 20 mins taking my time and with the extender there was tons of wire.
All that said and done, it's a totally different experience driving the car. I can sit back comfortably, and the steering wheel is positioned perfectly, not to mention it no longer hits my knees so I have full rotation and can apply proper torque while driving. I kind of wish I got it ages ago.
Any one on the fence about getting this should buy it immediately. If you've never quite been comfortable and felt the steering wheel was too far or you were leaning forward to wrestle the steering wheel this is the answer!
Great job @949 Racing!
RayRay88 is offline   Reply With Quote
The Following 2 Users Say Thank You to RayRay88 For This Useful Post:
949 Racing (06-11-2021), Thefalls (06-07-2021)
Old 04-24-2022, 06:53 PM   #30
George Rosebush
Drives: 2015 Scion FRS
Originally Posted by Capt Spaulding View Post
2. The added distance puts a serious stretch in the horn wire. I battled mine for quite a while and ultimately admitted defeat and fabbed a 2" jumper wire. [949 guys - including a short jumper would help those of use with big clumsy mitts]
I had the same issue, it would unplug when trying to install the airbag, how do you fab up this extension? What parts needed?
George Rosebush is offline   Reply With Quote
Old 07-15-2024, 09:22 PM   #31
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
This is a great thread. It's too bad the large versions of the images no longer works. That would be been super helpful.
I'll be installing mine tomorrow. I hope I can get my big mitts in there to handle some of the wiring tricks.
RT-BRZ is offline   Reply With Quote
Old 07-17-2024, 07:41 AM   #32
RT-BRZ
RT-BRZ's Avatar
For anyone still reading this, I worked this out. I went to the trouble of getting all the images from the unreliable image host and combined all of this into a single document. There have also been changes with the 949 hub extender. If there is any interest in having this in a single doc, just message me and I can update the doc a bit and make it into a PDF and send it to you.
Old 08-19-2024, 06:24 AM   #33
RT-BRZ
RT-BRZ's Avatar
To everyone, I have converted this into a document you can download and print. I made the images larger so they are easier to see.
Keep in mind that 949Racing has made revisions to their product but it's not hard to understand the minor differences.
@Clutch Dog thanks for putting this together in the first place.
@daskaman here is the document you messaged me about.
File Type: pdf 949 Steering Wheel Spacer Installation.pdf (4.62 MB, 177 views)
The Following User Says Thank You to RT-BRZ For This Useful Post:
daskaman (08-23-2024)
Old 08-23-2024, 11:37 PM   #34
daskaman
Drives: Burz
Thanks a bunch! Doing my 2016 BRZ no realistic way to keep the horn attached seems like a few others ran into needed to secure/extend.
daskaman is offline   Reply With Quote
The Following User Says Thank You to daskaman For This Useful Post:
RT-BRZ (08-24-2024)
Old 08-24-2024, 07:11 AM   #35
RT-BRZ
RT-BRZ's Avatar
I found it to be a bit of a stretch by it worked OK for me. The horn is definitely functional. I also swapped steering wheels while I was at it because I didn't want to take this apart again later.
949 Racing 50mm Steering Spacer 86 - GR86 949 Racing Tracking / Autocross / HPDE / Drifting 195 04-18-2022 11:45 AM
Spacer install EzyBrzy Northern California 1 03-05-2016 03:52 PM
Vibrations After Spacer Install Wyattkb Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 09-08-2015 12:20 PM
RAYS RACING DURA NUTS EXTENDED 50MM RED WITH LOCK 20 PCS 12X1.25MM ???? 20valvewynn83 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 04-07-2013 04:33 PM
