Old 08-21-2024, 11:07 PM   #29
renfield90
The Stig's German cousin
I am pretty sure jackets have been won on a square setup (heck, Heitkotter won with off the shelf V3s which I think are inferior to the T2). People who really want to maximize their setup are not going to stay there but it is a good predictable package for people who want to bolt on an upgrade and not think about it too much. RCE needs to make money and they can do that by appealing to the widest range of customers possible. Having worked with an aftermarket shop before, let me tell you it's way harder than it looks.
The Following User Says Thank You to renfield90 For This Useful Post:
Racecomp Engineering (08-22-2024)
Old 08-22-2024, 12:22 PM   #30
Originally Posted by ruturaj001 View Post
Hmm, looking up, this looks right, it is squared. I just started researching in to the topic and I agree that square spring rate doesn't make sense on twins. I was using @900BRZ 's blog.
https://900brz.com/posts/gr86-vs-brz
Looking at your numbers, we would be staggered by a much larger margin when trying to have square wheel rate. 60% stiffer in the rear.
Yes it's squared, but the motion ratio for a 2nd gen is not 0.75, it's closer to 0.78. Either way, what some are aiming for is called "flat ride" which is in reference to natural frequencies. I wrote this little thing to help explain that:
https://www.instagram.com/p/B6TKG6Un...RlODBiNWFlZA==
Flat ride or even wheel rates is one approach to setting up a car's suspension, one that was developed initially for comfort on cars with soft springs/dampers and lots of travel. It is definitely considered by actual motorsports engineers, but it's not the only consideration. These cars have very different front and rear suspension designs and geometries and limitations and some odd quirks. Formulas are guides, or starting points with which we try to work through a whole bunch of other compromises with the car and application.
There are advantages and disadvantages to square spring set ups for these cars, and a big advantage is that for most people they are easy to drive fast on track with stock swaybars and reasonable alignments. For some, stiffer rear spring rates feels good and works better for their application. And that's totally cool, there's never going be 1 set up that works for every car and every driver and application.
Heck, I run 5k/6k on my car and it kicks ass for a fun primarily street car...but it would be faster around a track with 6k front springs, even if that throws off the formula.
- Andrew
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
RToyo86 (08-26-2024), ruturaj001 (08-22-2024), ZDan (08-22-2024)
Old 08-22-2024, 06:49 PM   #31
ruturaj001
Drives: BRZ 2023
- Andrew
Thank you, I went trough it and would look up older posts as well. My goal is to have a best setup for learning if that makes me slow even then it's not a problem. I think I do not want to go very fast, that's why I am using 225 SX2s and moderate camber (no coilovers yet). I am just understanding things and might ask stupid questions. I plan to get coilovers in future but still time isn't the goal, feel is.
ruturaj001 is offline   Reply With Quote
The Following User Says Thank You to ruturaj001 For This Useful Post:
Racecomp Engineering (08-23-2024)
Old 08-25-2024, 11:17 AM   #32
Tomyyyu
Drives:
- Andrew
Got it. So I ended up following 949’s suggestion on ride height and rake. Granted my wheel diameter is smaller than the one he mentions in the article. https://www.949racing.com/supermiata...lignment-info/
I’m now on:
- 7/9k springs
- Ride height (floor to futhermost) part of jack points
- Front Right: 5 9/16”
- Front Left: 5 7/16”
- Rear Left: 5 12/16”
- Rear Right: 5 14/26”
- Rake: 5/16” or ~8MM
- Measured with:
- No driver
- A052 (245/40/17)
- 17x9 +45 RPF1
- 8/12 gallons of gas
Question for @for preload, I just used the spring perch and moved it my desired ride heights. So what has me confused is if preload, droop, and bump travel need to be adjusted on these KWs? Does preload need to be adjusted too?
It seems based on this article:
https://suspensionsecrets.co.uk/coil...ght-correctly/ they mention that KWs use just spring perch adjustments so preload, bump, and droop are all already factored in when they are built. Which if true, that’s a cool feature, sure does make the end users life easier.
Tomyyyu is offline   Reply With Quote
Old 08-26-2024, 10:25 AM   #33
I’m now on:
- 7/9k springs
- Measured with:
- No driver
- A052 (245/40/17)
- 17x9 +45 RPF1
Correct, adjust ride height with the spring perch. This adjusts preload + bump + droop. You don't really have to worry about preload. As you adjust ride height, you're trading bump between droop travel.
You have a range of ride heights that work and KW + RCE and other coilovers that don't have the adjustable lower mount tend to have more total travel. You can think of them as already preset to a proper length. Nothing inherently wrong with coilovers that let you adjust the lower mount, just have to do it right (many don't and even some manufacturer's don't know how to do it right).
- Andrew
Tomyyyu (08-26-2024)
Old 08-26-2024, 02:30 PM   #34
Tokay444
Be sure to also corner balance.
Old 08-26-2024, 03:44 PM   #35
Tomyyyu
Drives:
I’m going to do an event first. So was thinking let’s just align and go for it. Before I spend ever more cash corner balancing. I don’t have scales.
Old 08-26-2024, 04:16 PM   #36
Tokay444
To get that far and then not complete the puzzle seems like doing yourself a disservice if you ask me.
Old 08-26-2024, 04:52 PM   #37
Tomyyyu
Drives:
Fair enough. Just gotta find a place that does both.
Old 08-26-2024, 05:01 PM   #38
Tokay444
If your alignment shop doesn't corner balance, I wouldn't waste your money on their alignment.
The Following User Says Thank You to Tokay444 For This Useful Post:
Ohio Enthusiast (08-26-2024)
Old 08-26-2024, 05:10 PM   #39
Tomyyyu
Drives:
Yeah was reading around that you should disconnect end links when you align. And when you align you shift weight around (?). So corner balance is naturally part of the process.
Old 08-26-2024, 07:32 PM   #40
Gearhead23
Autoxer
Drives: 2024 BRZ tS / 2005 WRX Sedan.
You should be sitting in the drivers seat when the alignment is done. That is what my guy requires. That 130 to 200 lbs of driver weight does make a difference.
Gearhead23 is offline   Reply With Quote
The Following User Says Thank You to Gearhead23 For This Useful Post:
ZDan (08-29-2024)
Old 08-26-2024, 10:56 PM   #41
Tomyyyu
Drives:
Yup. Found a place that will align and corner balance. They will use gym weights to get my weight in the drivers seat.
Old 08-28-2024, 04:45 PM   #42
ruturaj001
Drives: BRZ 2023
How much is the quote estimate?
DarkSunrise (09-06-2024)
Understeer on '22 BRZ Fletch Tracking / Autocross / HPDE / Drifting 29 12-20-2022 10:09 PM
oversteer and understeer orc BRZ Second-Gen (2022+) — General Topics 76 10-05-2021 04:08 PM
Why does car understeer when going downhill? hpde_addict Tracking / Autocross / HPDE / Drifting 20 01-15-2018 10:42 AM
Understeer after new wheels carsebuco Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 12-04-2017 06:49 PM
understeer on 17 brz alex.s Suspension | Chassis | Brakes -- Sponsored by 949 Racing 37 09-11-2017 05:05 AM
