go_a_way1, MisterSheep
Old 06-25-2024, 12:05 PM   #24613
JD001
JD001's Avatar
Drives: Subaru BRZ
They are an investment. Back when I started, gold was $32 an ounce; now it's about $2,338 an ounce. How about that for an ROI -
So, how is the investment realised? Who benefits and when?
The Following User Says Thank You to JD001 For This Useful Post:
humfrz (06-25-2024)
Old 06-25-2024, 12:50 PM   #24614
The first one there, that has a pair of pliers -
The Following 4 Users Say Thank You to humfrz For This Useful Post:
JD001 (06-26-2024), pope (06-25-2024), Stephen W. (06-25-2024), Ultramaroon (06-27-2024)
Old 06-25-2024, 07:58 PM   #24615
Spairo
Drives: 2013 FR-S 6 spd in Halo
Before he switched everything over to modern porcelain, my old man would say to shake his urn. If there was no metallic rattling, we should hunt down the mortician.
Go fast, take chances.
Spairo is offline   Reply With Quote
The Following 2 Users Say Thank You to Spairo For This Useful Post:
humfrz (06-26-2024), JD001 (06-26-2024)
Old 06-26-2024, 11:49 AM   #24616
JD001
JD001's Avatar
Drives: Subaru BRZ
It is such a strange thing .. mouth full of gold, take it to your grave.. I suppose archaeologist in the future will strike gold in the literal sense.. unless you've been cremated.
humfrz (06-26-2024)
Old 06-26-2024, 01:05 PM   #24617
What you mean ....... in the future ........? -
JD001 (06-26-2024), pope (06-26-2024)
Old 06-27-2024, 07:26 PM   #24618
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Did some wet sanding to quarter panel and door to get the orange peel out from the body shops reclearing most of that side, then polished and ceramic coated. Not bad for a car about to cross 100k miles!
The Following 5 Users Say Thank You to RToyo86 For This Useful Post:
humfrz (06-28-2024), JD001 (07-03-2024), MJones_RB (07-01-2024), overd0sed (07-05-2024), Stephen W. (06-28-2024)
Old 07-03-2024, 12:20 PM   #24619
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Changed the filters and oil yesterday. Got it jacked up and all secured.
Placed the fumoto drain and empty jug, then knocked the tube into the jug when I went to open it.
Oil all over. Moved the jug to catch what's left, then that filled and overflowed as well.
Argh!
Deployed the kitty litter to soak it up.
Definitely much easier to change the air filter if you unbolt it all to give enough slack.
At least the garage has a smooth concrete floor that was easy to de-grease and wash down once I got the car out of the way.
Two hours instead of 30 minutes this time. Slow is fast.
The Following 2 Users Say Thank You to bcj For This Useful Post:
humfrz (07-03-2024), overd0sed (07-05-2024)
Old 07-03-2024, 04:47 PM   #24620
Argh!
bcj (07-04-2024), Dadhawk (07-03-2024)
Old 07-04-2024, 12:55 PM   #24621
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Argh!
I heard a similar story about a guy who was asked to pee in a cup for a drug test.
Old 07-05-2024, 07:17 PM   #24622
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
Not really what I did, but learned that my 86 will be totaled due to extensive hail damage. Just trying to negotiate a little better payout before finalizing things.
This post sent using 100% recycled electrons.
bucketfoot is offline   Reply With Quote
The Following 4 Users Say Thank You to bucketfoot For This Useful Post:
bcj (07-06-2024), Dadhawk (07-08-2024), humfrz (07-06-2024), RToyo86 (07-08-2024)
Old 07-06-2024, 06:28 PM   #24623
Too bad -
Old 07-07-2024, 07:48 PM   #24624
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
Installed the TRD intake
- My 2015 Scion FR-S OEM+ Build Thread -
TRD | Brembo | RAYS
KMA KiCKz is offline   Reply With Quote
The Following 3 Users Say Thank You to KMA KiCKz For This Useful Post:
Busybee (07-08-2024), RToyo86 (07-08-2024), Wally86 (07-08-2024)
Old 07-08-2024, 04:32 PM   #24625
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Sold it yesterday. It was a sad moment letting go of a car with which we have tons of good memories, and which has been present through many important moments of my life, but I felt after seven years it was time. I have a good feeling the next owner will take good care of it.
These are awesome cars, with an awesome community. I've rarely seen a forum where everyone was just so nice and willing to help each other, and take things easy. It's sad though that there's less & less activity on the board.
I'll stick to the 911 for a few months, and then will probably replace it with something that has four doors. Living the dad life .
alex87f is offline   Reply With Quote
The Following 4 Users Say Thank You to alex87f For This Useful Post:
bcj (07-10-2024), Busybee (07-08-2024), Dadhawk (07-11-2024), humfrz (07-08-2024)
Old 07-08-2024, 04:55 PM   #24626
Well, although you are sad to see it go, the "dad life" can be even more rewarding.
I remember when I had to give up my 1970 BGB-GT for a 4 door car, (dad life).
However, after the kids were grown, I got a miata and drove it for 10 years.
Then, when my granddad life started, I discovered I couldn't get all three granddaughters in the miata, so I traded it for my FR-S. Yep, all three would fit -
Now that they are older (and much bigger), I found they all fit better in our Honda CR-V.
However, I do keep the FR-S for running to the doctor's office, the dentist's office, the pharmacy the smoke shop -
You too can come full circle -
alex87f (07-09-2024), Busybee (07-08-2024), Dadhawk (07-11-2024), Teseo (07-16-2024)
