Old 07-13-2023, 06:25 PM   #15
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Originally Posted by chipmunk View Post
Can't find it anywhere! Called local shops... none! I'm probably gonna have to get large sheets and cut them myself! Or just use RTV again! :/
Amazon
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
The Following User Says Thank You to Muskoka800 For This Useful Post:
chipmunk (07-14-2023)
Old 06-26-2024, 03:48 PM   #16
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Yes, replace the OEM RTV. It's overuse at the factory will drop beads into your oilpan and eventually collect at the oil inlet and block the screen and cost you an engine due to it causing low oil pressure. This is the main way these engines fail. I got 115k on mine before it did this to me.
Tuning shop installed my replacement engine in said this is common with the FRS/BRZ/86 platform. He opened pulled the pan on the replacement motor to remove the excess RTV and used less RTV putting it back together. Surgeline shop in south Portland, OR area.
jeepmor is offline   Reply With Quote
Chasing an exhaust leak -Donut gasket or gasket exhaust came with? xZAMx Engine, Exhaust, Transmission 7 08-28-2019 10:47 AM
SOLD: Brand New 2 Sets Of Gasket Ninja Tailight Gasket Kit With 3M Adhesive el-guapin Exterior Parts (Aero, Lighting, Etc.) 5 12-27-2018 03:54 AM
Subaru BRZ complete engine gasket & seal kit 2.0L JPxM0Dz Engine, Exhaust, Transmission 0 12-18-2012 12:11 PM
BRZ Donut Gasket same part as WRX STi Gasket? Zadkiel Engine, Exhaust, Transmission 0 10-06-2012 08:22 AM
Engine Gasket Set Ishii Motors Engine, Exhaust, Transmission 4 06-22-2012 05:33 AM
