Old 05-28-2024, 01:26 AM   #1
Walldodger
Walldodger's Avatar
Drives: Four wheels, two seats, etc
Can't find rear upper ball joints
I feel like I've searched around as far as can but can't find any replacement ball joints. I can find plenty of rear upper arm assemblies, and front ball joints.
Does anyone out there know if any are available?
Bonus speculation, has any one tried seeing if the front lower, and rear upper are interchangeable/the same part? If so, front ones are easy to find.
Thanks
Walldodger is offline   Reply With Quote
Old 06-02-2024, 04:58 AM   #2
grippgoat
Drives: 2023 BRZ, 2018 Golf R 6MT
They won't be interchangeable, I don't think. I'm not sure if the rear upper is tapered or not. However, I do know it has a groove for a bolt that goes through the upright, and the edge of the bolt sits in that groove so the stud can't pull out. And then when the bolt is tightened, the knuckle pinches and grips the stud. It's a totally different connection mechanism to the front lowers.
RockAuto has Dorman rear upper control arms for under $100 ea. Maybe just go that route? Then you get new bushings, too.
grippgoat is offline   Reply With Quote
Old 06-03-2024, 02:29 PM   #3
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Everything I've read requires the entire assembly to be replaced instead of just the joints. I'm sure there's parts out there, but how much is your time worth vs the money to replace the entire arm?
B T is offline   Reply With Quote
Old 06-10-2024, 05:25 AM   #4
Walldodger
Walldodger's Avatar
That's a good point, might settle for saving some time rather than money.
STi ball joints? norcalpb Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-13-2023 12:51 PM
What inner tie rods and ball joints should I get? kev0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 01-13-2019 11:08 PM
Upgrade ball joints??? Fred Flintstone Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 04-11-2018 09:35 PM
Rear upper control arm ball joint? wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-06-2015 08:17 AM
Extended ball joints.. tech4pdx Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-01-2013 10:53 AM
