Old 05-07-2024, 05:32 PM   #85
ruturaj001
Drives: BRZ 2023
Originally Posted by RToyo86 View Post
What offset are the wheels.
Two bolts will push the tire closer to the lower spring perch.
You should be fine but it'll be close.
With 2 bolts I had 6-7mm clearance between tire and spring. For these wheels, offset is 38, so it will add 10mm and subtract 5mm(?) for tires. So I think it should be good, I have 3mm spacers that I will keep in car for just in case.
ruturaj001 is offline   Reply With Quote
Old 05-07-2024, 05:37 PM   #86
ruturaj001
Drives: BRZ 2023
Originally Posted by jflogerzi View Post
Camber plates are safer for sure and not super expensive. Also really enjoying my C21/C11 combo. With stock calipers and the CSG pads I have better pedal feel and bite than my old RR racing BBK and Carbotech. Way less pedal force needed. This is with Lowerend 200TW tires IE v730 levels of grip
Thank, I am not sure which ones to get. Raceseng stopped making those. Found a interesting way to do the job without spring compressor.
https://www. gr86 . org/threads/folks-who-have-done-coilovers-did-you-install-them-or-have-a-shop-do-it.11582/?post_id=195720#post-195720
Old 05-07-2024, 09:09 PM   #87
smoltz
Drives: 01 911 Turbo, 03 G500
Originally Posted by ruturaj001 View Post
Ordered 225 sx2 and 17x8 ultragrams wheels. I am not sure if I should get camber plates instead of using 2 camber bolts.
I run 225/45/17 RE71RS on 17x9 ARC8 ET42 with 2 Camber Bolts. But I needed 3mm spacer in front to clear. I have 2.7 degrees. YMMV but this setup works fine and in the time trial series I run there is a penalty for camber plates as opposed to camber bolts.
smoltz is offline   Reply With Quote
Old 05-08-2024, 12:00 AM   #88
ruturaj001
Drives: BRZ 2023
Thanks, I didn't clarify, I am thinking about camber plates due to risk of bottom bolt breaking. Offset of my wheels is 4mm less, so wheels are 4mm out, so I would have more clearance than you (2.7 degree > 2.4 degree and 4mm > 3mm), that wasn't my worry.
Old 05-08-2024, 12:39 AM   #89
2.2Lude
2.2Lude's Avatar
-2.8 upfront with PP Sach's TRD springs here. From what I've read the Sach's a marginally thicker than the base set up.
Pedders top hats, SPC lower bolts, and OEM lower bolts on the top position. Pretty much maxed out clearance wise. 17x9 +35 Apex ARC8's on 225/45/17 RT615k+'s.
The added caster + clearance makes the Pedders top hats a no brainier unless you're going full camber/caster plates.
2.2Lude is offline   Reply With Quote
Old 05-09-2024, 09:03 PM   #90
smoltz
I have never heard of the bottom bolt breaking. I go out every other weekend and hit every piece of curbing at the track. I've heard of them coming loose and I've had one come loose myself (although I question if the shop had tightened things down properly). Now I keep mine torqud to spec (125 in top 100 in bottom) and marked with paint so that I can look quickly and tell if they have moved. No movement yet after 2 weekends of abuse.
The Following 2 Users Say Thank You to smoltz For This Useful Post:
ruturaj001 (05-14-2024), strat61caster (05-10-2024)
Old 05-13-2024, 07:52 PM   #91
jflogerzi
jflogerzi's Avatar
I have used The Peddlers great budget top to get some camber. Add 1 set of bolts and you should see close to -3 up front. Rear just need LCAs to dial it in. Cheap SPC ones work just fine.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
2.2Lude (05-13-2024)
Old 05-13-2024, 11:09 PM   #92
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I managed -3° both sides with pedders, SPC lower, crash bolt upper on yellows with B6 dampers. With a 18x8 +35 215/40 PS4.
Old 05-14-2024, 01:56 AM   #93
ruturaj001
Drives: BRZ 2023
I think if I am doing the job of replacement might as well spend some more and set it with more adjustability, that's why I have been thinking about camber plates.
I am planning to keep rear stock for now, so -1.4.
Old 05-14-2024, 10:56 AM   #94
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Cheap Moog camber bolts work just fine in the rear too, I was able to get +/- about 0.3 degrees with them.
Old 05-14-2024, 11:36 AM   #95
jflogerzi
jflogerzi's Avatar
I believe its the same OEM as the cheap SPCs ones on rock auto but cheaper.
DocWalt (05-14-2024)
Old 05-16-2024, 03:46 PM   #96
ruturaj001
Drives: BRZ 2023
Got wheels and tires installed yesterday
Edit: details, 17x8 konig ultragrams and 225 sx2
The Following 4 Users Say Thank You to ruturaj001 For This Useful Post:
2.2Lude (05-16-2024), autoracer86 (05-16-2024), CSG Mike (05-16-2024), NoHaveMSG (05-17-2024)
Old 05-16-2024, 06:54 PM   #97
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Looks great! I went with the same wheel and tire size as well. Nice happy medium
autoracer86 is offline   Reply With Quote
The Following User Says Thank You to autoracer86 For This Useful Post:
ruturaj001 (05-16-2024)
Old 05-16-2024, 08:20 PM   #98
RToyo86
RToyo86's Avatar
Sx2s fit wide. I wish they were not so expensive in Canada. I priced them and ended up being more expensive than RS4s
Wheels setup advice to learn drifting ShadowTS Tracking / Autocross / HPDE / Drifting 2 03-22-2016 03:26 PM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 06:36 AM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring NY / NJ / CT / PA 0 10-20-2014 10:48 AM
How does the ECU learn? boredom.is.me Software Tuning 19 10-10-2013 08:29 PM
