Old 04-23-2024, 02:04 PM   #1
Devante
Crescent fresh at best.
Devante's Avatar
Drives: 2016 Scion FR-S - Asphalt
GF ran over median. Smooshed front jack point.
Hey everyone.
Long story short, she drove over the median at an intersection head on.
Surprisingly the bumper somehow didn't get hurt but she did some pretty bad damage to the part that is the front jack point.
Seems this is connected to the hood latch above because now the hood latches but has enough play I'm scared to drive on the highway.
She also demolished the large metal plate protecting the catalytic converter and oilpan.
I had to get a new one. The catalytic converter itself has a big dent in it but nothing is rattling inside.
I took a look and the best way I can describe it is that the jack point is smooshed up.
Please see the image here: https://i.imgur.com/hqgqJsX.png
So my question is kinda... what would you guys do?
I've already jacked it up by that point since and it SEEMS strong still.
My friend says my options are basically have a body shop try and pull that part down again to fix the hood issue. Or else see if they can get a new one and spot weld it (wouldn't fix the hood problem though).
I don't even really know what to call that part. I just call it jack point but it's spot welded to the body itself it seems.
Just looking for some advice guys. Thank yoU!
Devante is offline   Reply With Quote
Old 04-24-2024, 08:03 AM   #2
alphasaur
friendly
Drives: 17' 86
the hood latch is not directly connected to that piece. If you open the hood you'll see a bracket that goes down behind the radiator that connects near there and that is what the latch mounts on to. Check the bottom of the bracket the hood latch is on and see if it's still on/damaged. Also see if you can adjust the latch a bit, it's only like two or three bolts (12s I think?).
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 04-24-2024, 09:25 AM   #3
LRNAD90
Drives: X5 35d, D90, CX-5 Turbo
Ouch, sorry to hear of your bad luck...
I suspect there is more damage than you are seeing with the 'naked eye' The front subframe and radiator support is likely 'tweaked' if you now have play in the hood when latched.
It's going to need to go on a frame machine that can take specific accurate measurements to determine how bad the damage is. I'm sure it is fixable, not sure the cost.
I'm going to guess you are also going to have alignment issues unless properly repaired..
~Scott T.
'95 NAS D-90 ST
'13 BMW X5 35d
'22 CX-5 Turbo
'?? 86 one day soon?
LRNAD90 is offline   Reply With Quote
Old 04-26-2024, 01:40 PM   #4
Ernest72
Check if the subframe and alignment are good, if they are it’s likely not as big an issue - more cosmetic. I would check everything to get a real feel on the damage.
Old 05-05-2024, 11:32 PM   #5
First off, I'd suggest you find all kinds of reasons NOT to let your GF drive your car anymore -
Second off, like ol @alphasaur suggests, try to adjust the hood latch.
Iffen that don't work, Bubba says to do an aggressive hood latch adjustment with a crowbar and a BFH.
Pinch weld jack point protector Pat BRZ Second-Gen (2022+) — General Topics 14 01-05-2023 01:14 AM
Changing oils by myself, are these a recommended jack+jack stand? btan219 BRZ First-Gen (2012+) — General Topics 67 10-23-2021 03:54 PM
Pinch weld jack point paint damage? Ingen Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 10-12-2015 08:43 AM
Modding your DD - where's the sweet median? Scubaru Scion FR-S / Toyota 86 GT86 General Forum 55 02-06-2015 10:03 AM
Front jacking point dsgerbc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-30-2012 05:19 PM
