Old 04-15-2024, 04:08 PM   #323
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
Yesterday's best run, now in STX trim. Just RCE Superstreet-1's, 6k springs front and rear, RLCAs, camber bolts, -4/2.2 for camber, 1/6" toe in the rear. Apex ARC-9 wheels 17x9, 245/40/17 A052's. No power mods.
Definitely relearning the car after driving the last 4 years in DS. I did end up 26/119 in PAX. I was expecting a little better, but the A052's still had the mold release on them. They're now scrubbed in though!
cmiovino is online now   Reply With Quote
Old 04-18-2024, 08:17 AM   #324
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Originally Posted by cmiovino View Post
-4/2.2 for camber, 1/6" toe out in the rear.
Toe out ? I thought Toe in was the way to go for these cars
autoracer86 is offline   Reply With Quote
Old 04-18-2024, 11:01 AM   #325
cmiovino
cmiovino's Avatar
Edited. That's the second time I've typed 'toe out' here. It's 1/16" toe in for stability, per RCE's recommendations.
I used to toe out the front of my WRX 1/8", so that's probably where it keeps coming from lol.
Old 04-18-2024, 12:45 PM   #326
autoracer86
Drives: Toyota GT86
haha no worries !
Old 04-23-2024, 09:24 AM   #327
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Have you thought about running 255/40 tires? I do on my 17+ to get back some of the lost speed at the top of second because of the 4.3 rear gears.
Breezio is offline   Reply With Quote
Old 04-23-2024, 10:04 AM   #328
cmiovino
cmiovino's Avatar
Yes, I'll likely be going that route. First time setting the car up on 245's with coilovers and wanted to make sure everything fit and how much clearance I had all around.
The extra mph would certainly help at our local SCCA site. I was bouncing off the the limiter in DS trim many places.
Old 04-23-2024, 07:04 PM   #329
Breezio
Breezio's Avatar
Yeah, with your alignment and wheel choice, if you move to 255's you'll probably get a very tiny amount of rubbing on the tab for the rear bumper cover, but that should be it.
There is a chance for a very small amount of rub on the inside at full steering lock in the front.
I'm running the same wheels as you, alignment is:
F: -4.3 camber, 0 toe, 7.2 caster
R: -2.1 camber, 0 toe
Old 04-30-2024, 05:45 PM   #330
cmiovino
cmiovino's Avatar
This past weekend's best runs. Saturday was an SCCA event, Sunday was non-SCCA group. I tend to have better luck at the lot with hills for some reason. First two events in STX trim (coilovers, RLCAs, wheels/tires) that the car was actually working correctly. I was probably getting up to speed with the car Saturday. I definitely overcooked it a bit into the back corner on this run. Should have been tighter to the cones as I did in the morning - came in too hot. Sunday's run seemed to be pretty good overall. Could have pushed more here and there, but overall happy with that one. 19/120 in PAX.
Ran the car 4 years in DS trim with 225's and a swaybar. In STX, the inputs needed feel much quicker. It's fun, but challenging. No power mods yet, so still dealing with the torque dip.
Old 05-01-2024, 11:01 AM   #331
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
Need to be closer to the cones and more aggressive :P
Autocross nut
AustinTX is offline   Reply With Quote
Old 05-01-2024, 11:42 PM   #332
Breezio
Breezio's Avatar
Is it just me or does your car's mid-corner balance seem to be a bit on the understeer side of things?
May need to soften the front or stiffen the rear a bit.
Old 05-02-2024, 09:59 AM   #333
cmiovino
cmiovino's Avatar
It is. The rear end isn't loose at all like I expected it to be from seeing some other STX runs. I drove two STX cars year ago and you basically steered with the rear end twitching around.
Diving into those left hand sweepers, you'd turn the wheel and keep going straight for a second and then it would hook up and turn. If anything it was early/mid corner understeer and then neutrals out exiting.
It's not an ideal setup by any means. 6k/6k spring rates, 19mm Perrin front swaybar. Damper settings were 10/10 from full stiff out of 20 clicks. I actually lowered the front two clicks from the morning runs thinking the same thing you were.
Would you suggest more of a 8/12 (to full stiff) split? Softer front, stiffer rear. I was chasing issues during our test and tune events, so I haven't been able to mess with the settings much.
I ran it at 12/12 (stiffer) in the smaller lot with hills and that netted a quicker time there because the car felt more stable and I was able to keep on power more.
Old 05-02-2024, 11:19 AM   #334
autoracer86
Drives: Toyota GT86
I would be curious to know what sway bars RCE recommends with the SS1.
Generally damper settings are for fine tuning so you might be looking at either a spring or sway bar change.
Old 05-04-2024, 09:44 AM   #335
Breezio
Breezio's Avatar
Take my advice with a grain of salt as I'm not expert on suspension tuning.
I think it would depend on if the front is understeering because it doesn't have enough traction, or because the rear has too much traction.
I'm on RCE T2's, so my damper settings probably aren't too relevant.
However, I am also on a square spring setup (400lb/400lb) with the Hotchkiss 1" hollow bar in the front on soft. Should be similar to the Perrin 22mm bar on soft.
Factory rear PP bar.
When I first started running the car in STX it felt like the rear had too much traction, vs. the front having too little. I stiffened up the rear dampers a bit. That helped but wasn't full what I wanted.
I thought about putting a bigger bar in the rear or maybe adding stiff tophats to the rear shocks (on OEM currently).
Ended up putting rear subframe bushing inserts in and have really enjoyed the setup since then.
Old 05-04-2024, 07:43 PM   #336
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
I would suggest trying a stiffer rear bar like the Perrin 16mm adjustable. Not a ton stiffer, but will really make a difference if you having trouble balancing the car.
BlueWhelan is offline   Reply With Quote
Track Videos - Directory and Discussion Dave-ROR Tracking / Autocross / HPDE / Drifting 709 09-22-2025 08:12 PM
*Groupbuy: Invidia N1 and Q300 Cat-Back Exhausts (SS tips, T.I. tips) -fteightysix* 86SPEED Groupbuys 74 11-09-2016 01:45 PM
Feldys Autocross videos feldy Tracking / Autocross / HPDE / Drifting 25 06-13-2013 02:58 PM
Need help with some tips for autocross Toyota GT 86 Tracking / Autocross / HPDE / Drifting 10 04-30-2013 06:43 AM
2012 BRZ/FR-S Stock Class Autocross Discussion EMguy Tracking / Autocross / HPDE / Drifting 183 01-04-2013 03:17 AM
