Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 04-02-2024, 05:43 PM   #1499
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Over the weekend I installed Pedders tophats on the Trueno edition. Incredibly easy on this car, no need for a spring compressor!
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
The Following User Says Thank You to nextcar For This Useful Post:
DocWalt (04-03-2024)
Old 04-07-2024, 11:21 PM   #1500
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Removed the sway bars, one of the end links will need to be replaced (rusty bolt). I will have to drive slowly until the links arrive to install new ones.
Stonehorsw is offline   Reply With Quote
Old 04-07-2024, 11:21 PM   #1501
Stonehorsw
Stonehorsw's Avatar
How did you do?
Old 04-07-2024, 11:38 PM   #1502
nextcar
Originally Posted by Stonehorsw View Post
How did you do?
There is very little preload on the springs. If you remove the nut on the top of the struts whlie the car is on the ground and jack up the front end slowly, the tophats separate easily. You will have to remove one endlink to swaybar connection, then you can simply line up the strut with the new tophat and slowly lower the vehicle and start the top nut...
Pull out
The Following 3 Users Say Thank You to nextcar For This Useful Post:
Jianlun (07-06-2024), Ohio Enthusiast (04-08-2024), Stonehorsw (04-11-2024)
Old 04-11-2024, 03:22 PM   #1503
Stonehorsw
Stonehorsw's Avatar
Thanks. I wish I knew before, competing the front sway bar change today.
Old 04-26-2024, 09:03 PM   #1504
Stonehorsw
Stonehorsw's Avatar
Installed RCE sway bars. Front 20mm dia and rear 16mm dia.
Front on hardest and rear on middle.
Added camber bolts.
Now, need to take to a good alignment shop.
Old 05-01-2024, 12:12 AM   #1505
eyeballs
Drives: '22 BRZ
Originally Posted by Pat View Post
Ha. I had the same experience when going to my parents' house at 700 feet. Wild. I'm hoping a header and tune will get me close to the sea level feeling after this race season.
I wouldn't get your hopes up. I had the exact same thought when I bought the car....just want to feel "stock sea level". I'm tuned on 91 with JDL EL header/OP/catted&resonated FP, and CSG 70mm touring catback. Intake charcoal filter removed with grimmspeed drop in filter. Granted I requested a conservative tune, but it really doesn't feel much quicker. Higher rev limit has been super handy though. If I had to do it again, I'd just get a tune and an axle-back.
On a brighter note, I finally moved on from the V601 to a 615k+ this season and somehow managed to drop nearly 2 full seconds on a 1 mile course. Insanity!
eyeballs is offline   Reply With Quote
The Following User Says Thank You to eyeballs For This Useful Post:
Pat (05-01-2024)
Old 06-21-2024, 10:53 AM   #1506
mr.whiskers
Drives: '22 BRZ
Got a 3rd set of wheels for summer. Original plan was just to daily drive my autocross set of RE-71s on stock rims during the summer because I drive often but not much in terms of miles. But I didn't realize that these sticky tires pick up all the sand and stones and sandblast the car every time I drive around town. Super annoying and probably bad for the paint. So I had to pull the trigger on a third set.
Logical choice would be to get RPF1s for the autocross set, but since this purchase wasn't planned I just couldn't justify the price ($370 CAD per rim and no choice of color). Had to look for a more budget oriented option, and here in Canada we don't have much choice at all. After many hours of research settled on Motegi MR-147 in bronze. Couple lb lighter than stock, decent price. Offset is like 10mm less than stock, which I kinda like tbh. Fills out the arches more.
For tires just went with some cheap Falkens A/S in 225/45R17 sizing. They are actually much quieter than the stock Premacies HP, which tbh I didnt like at all. Yes they have a bit more grip than your typical A/S tire, they were good to learn how to autocross but that doesn't justify the noise in my opinion. Even Bridgestone RE-71RS and my winter tires are much quieter than those things. Also they are surprisingly narrow. 215 is supposed to be a correct size for a 7.5" wide rim but even from factory it looks like the tire is too narrow and it always low key annoyed me how it looked.
I know the car would look so much better lowered and inch or so and with 18" rims but I am just not willing to sacrifice driveability for the looks since this is my daily/autox car
mr.whiskers is offline   Reply With Quote
Old 07-05-2024, 03:15 PM   #1507
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Installed some side markers. Unsure if I love the totally clear look but I much prefer this style LED strip light.
Old 07-08-2024, 09:18 AM   #1508
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
I like the strip light better than the JDM OEM option.
I discovered the strip light you have after buying the JDM markers. Had I taken a bit more time looking at options, I probably would have gone with what you have.
Desertnate is offline   Reply With Quote
Old 07-08-2024, 09:35 AM   #1509
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Yeah having seen the JDM option in person, not a big fan. I might lightly tint these lights, not a huge fan of how "bright" they look
Old 07-09-2024, 07:24 PM   #1510
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Weighed stock base model seats since I hadn't seen anybody weigh them yet.
Driver's side seat:
Passenger's side seat:
Old 07-09-2024, 08:33 PM   #1511
bourmb
Drives: Bourmb
Originally Posted by MikeNSX2 View Post
Ordered a stainless steel WC Lathewerks shift knob.
Chris makes outstanding shift knobs, and I have one in my Focus ST and had one in my just sold Miata ND.
I love his workmanship. I had one installed in my 2017 Chevy SS.
bourmb is offline   Reply With Quote
Old 11-12-2024, 08:52 PM   #1512
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
"Quick" alignment at lunch (and finished post work) with my new coilovers
WHAT DID YOU DO TO YOUR FRS TODAY? KalbiCool88 Scion FR-S / Toyota 86 GT86 General Forum 1 11-04-2015 10:36 PM
Do you know what today is? Yruyur Off-Topic Lounge [WARNING: NO POLITICS] 26 01-21-2015 02:51 PM
just got my OFT today...help please! carlitosway6891 Software Tuning 9 02-20-2014 10:05 PM
TODAY, TODAY, I GET IT TODAY!!!! :D Trashed675 Scion FR-S / Toyota 86 GT86 General Forum 54 02-14-2013 01:16 AM
