| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
Keep ICE alive+manuals
Drives: 2015 Hot Lava 6 spd
Who else?
Who else does and enjoys(most of the time anyway) doing all the work on their own vehicles besides me? Both Custom work and maintenance of course. I also think that the 86/BRZ platform is quite easy to work on, kind of reminds me of working on 60s/70s American Muscle.
If your not first your last - Ricky Bobby
#2 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
Most routine maintenance jobs, no problem, I enjoy them and the twins were indeed great to work on. Some repairs though as an amateur mechanic without all the necessary tools can be infuriating...our 2011 Prius has a problem with the hvac blend door, service manual says to basically take apart the whole dash and here I am trying to avoid that by using all sorts of small offset screwdrivers and probably looking pretty silly squeezing underneath everything
needless to say it has been a real pita
#3 | |
#4 |
Drives: '12 C63 P31, '23 GRC
I do most of own work as well. (expensive) tool dependent, but I'll tackle most anything on the difficulty scale up to a 7.
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
| The Following 2 Users Say Thank You to WolfpackS2k For This Useful Post: | HKz (03-11-2024), HotlavaFRSGT86 (03-12-2024) |
#5 | |
Reformed
at least problem is temporarily fixed for my wife since I am able to physically turn the flap so that the AC properly blows only cold air while the engine runs.
| The Following User Says Thank You to HKz For This Useful Post: | Wally86 (03-13-2024) |
#6 | |
| The Following User Says Thank You to HotlavaFRSGT86 For This Useful Post: | HKz (03-13-2024) |
#7 |
Be Kind
Drives: 2020 86
It's a nice, fun, and easy to work on car so far.
![]() ![]() It helps to have a bike to screw around with and build that mechanic confidence muscle with. ![]() A driveway lift helps too. ![]() (having some tools helps too, I suppose)
| The Following 4 Users Say Thank You to Wally86 For This Useful Post: |
#8 |
Drives: 2017 BRZ PP, 2004 WRX
Depends on the condition of the car.
I did coilovers, rear control arms, and camber bolts on my BRZ that's stored over winter and doesn't have an ounce of rust on it. Every bolt came out with zero issues. Everything went right together with no issues. Doing just brakes on my SO's Sentra is a chore. Rust, seized slide pins, ordering parts you didn't think you'd need. Using heat, drilling out snapped bolts, etc. Everything is seized and caked on. Generally though, doing any type of maintenance, fluid changes, replacement parts, feels like you're giving the vehicle new life. Super satisfying.
#9 |
Drives: Crapcan
You guys work on your own cars ?!?
| The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
#10 | |
All that was needed was a spark plug wrench, a screwdriver, a 9/16-1\2" wrench, a thin dime (to set the points), a fingernail file (to file the points), a good ear (to set the timing), a pair of pliers and a socket set if you were going to overhaul the engine. However, today, I feel lucky to find the dipstick to check the oil -
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
#11 | |
Drives: 2013 frs base
| The Following User Says Thank You to blsfrs For This Useful Post: | humfrz (03-23-2024) |
#12 |
#13 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I am weederr33 by name. My car easy to work on.
