Old 01-14-2024, 12:15 AM   #19839
dpfarr
Drives: BRZ ts
Yea, the process for brembos is new to me. 30k miles and about 3mm of pad left. Very reasonable to be able to swap track pads in while switching wheels.
dpfarr is offline   Reply With Quote
Old 01-17-2024, 08:41 PM   #19840
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
It's quicker, but not exactly like "swap at a pitstop" quick.
Depending on thickness differences between the two sets of pads, you do have to move the pistons back in and the fronts take a decent amount of force. You can do it with a pad and wiggle it back and forth, but it takes some effort... especially going from a thin pad to a full one.
Pins take some effort in the front too. Best to pull them out from the rear rather than tapping from the front as you can scratch the caliper this way.
The rears being much smaller are simple all around.
... so when you think about traditional sliding calipers, there isn't a ton of advantages actually. It's just about the same effort removing one bolt, swinging the caliper away, swapping pads and/or moving only two pistons vs four, and you're good.
I've had both. They're not hard by any means, but not like half the time or anything.
cmiovino is offline   Reply With Quote
Old 01-18-2024, 10:34 PM   #19841
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Need the right tools for the job. With a cheap or homemade pad spreading tool it takes minutes.
Old 01-18-2024, 10:48 PM   #19842
If it needs to be faster than a c-clamp, I need to examine my priorities.
Old 01-20-2024, 01:02 AM   #19843
dpfarr
Drives: BRZ ts
I had a Jetta that needed a tool that simultaneously spread and rotated the piston.
Old 01-20-2024, 09:57 AM   #19844
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I had a Passat with the same type calipers. I spent an hour trying to push and screw the piston in (the video said it would be easy) then got the loaner tool and finished each one in 3 minutes.
Old 01-20-2024, 05:44 PM   #19845
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
My favorite tool for it is actually a clutch basket holder for a motorcycle.
Old 01-20-2024, 07:04 PM   #19846
OMG, yes.
I've been doing it wrong all these years.
Old 01-21-2024, 10:16 AM   #19847
blsfrs
blsfrs's Avatar
Can you post a picture of the one you use. I googled around and saw some tools but I can't get my brain to see how they would work on brake calipers.
Old 01-21-2024, 05:05 PM   #19848
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Like this. Tons of leverage, quick to adjust.
Old 03-14-2024, 10:25 PM   #19849
Kit Kat
Kit Kat's Avatar
Drives: 2017 Subaru BRZ w/ PP
Today, I installed my new head unit cover. The fitment was absolutely perfect
Name:  Head Unit Cover.jpg
Kit Kat is offline   Reply With Quote
Old 03-16-2024, 01:59 AM   #19850
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
Got fresh fluids front to back
Oxyg3n is offline   Reply With Quote
Old 03-16-2024, 06:18 AM   #19851
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Coolant, brake and clutch fluid?
Old 03-16-2024, 03:13 PM   #19852
Oxyg3n
Oxyg3n's Avatar
I probably should be thinking about those next tbh. Brake fluid and spark plugs are next up on my list. Might pay someone to do those though since I'm getting old ��
