| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#19839 |
Drives: BRZ ts
Yea, the process for brembos is new to me. 30k miles and about 3mm of pad left. Very reasonable to be able to swap track pads in while switching wheels.
#19840 | |
Drives: 2017 BRZ PP, 2004 WRX
Depending on thickness differences between the two sets of pads, you do have to move the pistons back in and the fronts take a decent amount of force. You can do it with a pad and wiggle it back and forth, but it takes some effort... especially going from a thin pad to a full one. Pins take some effort in the front too. Best to pull them out from the rear rather than tapping from the front as you can scratch the caliper this way. The rears being much smaller are simple all around. ... so when you think about traditional sliding calipers, there isn't a ton of advantages actually. It's just about the same effort removing one bolt, swinging the caliper away, swapping pads and/or moving only two pistons vs four, and you're good. I've had both. They're not hard by any means, but not like half the time or anything.
| The Following 2 Users Say Thank You to cmiovino For This Useful Post: | NoHaveMSG (01-18-2024), Ohio Enthusiast (01-17-2024) |
#19841 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (01-18-2024) |
#19842 |
If it needs to be faster than a c-clamp, I need to examine my priorities.
#19843 |
Drives: BRZ ts
I had a Jetta that needed a tool that simultaneously spread and rotated the piston.
| The Following User Says Thank You to dpfarr For This Useful Post: | blsfrs (01-20-2024) |
#19844 |
Drives: 2013 frs base
I had a Passat with the same type calipers. I spent an hour trying to push and screw the piston in (the video said it would be easy) then got the loaner tool and finished each one in 3 minutes.
#19845 |
Drives: Crapcan
My favorite tool for it is actually a clutch basket holder for a motorcycle.
#19846 | |
I've been doing it wrong all these years.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (01-20-2024) |
#19847 |
#19848 |
Drives: Crapcan
Like this. Tons of leverage, quick to adjust.
#19849 |
Drives: 2017 Subaru BRZ w/ PP
Today, I installed my new head unit cover. The fitment was absolutely perfect
#19851 |
30 minute maintenance
Drives: My18 wrxsti
Coolant, brake and clutch fluid?
#19852 |
Drives: 2017 BRZ - WRB
I probably should be thinking about those next tbh. Brake fluid and spark plugs are next up on my list. Might pay someone to do those though since I'm getting old
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
| Got my new FR-S today. | Boosted2.0 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 06-03-2012 10:35 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 10:19 PM |
| sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) — General Topics | 8 | 03-31-2012 08:53 AM |
