Old 03-12-2024, 12:18 PM   #1
Alfrz
Drives: 13 Scion Frs
Temp all the way up, error codes p0125 and p0128 - Resolved
On my way in to work this morning, a minute into my drive my traction control light, and check engine came on, noticed the temp was all the way up and pulled over.
Is this just an obvious thermostat that's stuck? Bad idea to drive until it's fixed?
A few months back I had an issue with the heat not blowing but it went away after one night. Same issue happened again yesterday, didn't think anything of it
Also when I checked the codes, the engine fan is blowing louder than I've ever heard. Not sure if it's relevant but figured I'd add
Update: Car was super low on coolant. After refill it wouldn't turn over at all, tried it three times. Cleared the engine codes,radiator fan shut off immediately, and gave it another shot and everythings been working fine now. Followed how to's to get rid of the air bubbles and whatnot. Thankful this happened when it did, and it doesn't look like any engine damage happened.
Alfrz is offline   Reply With Quote
Old 03-12-2024, 12:21 PM   #2
dynarun55
dynarun55's Avatar
Drives: 2015 midnight blue limited edition.
If the heat is not blowing then the water pump is done!! So probably leading to overheating issues. Yeah stop driving and get it checked before you blow the heads.
Sent from my Pixel 6 Pro using Tapatalk
dynarun55 is offline   Reply With Quote
Old 03-12-2024, 01:10 PM   #3
Alfrz
How sure are you here? I was driving for at least an hour, to the point that I just turned off the AC since it would only blow cold. The engine temp was fine all through that and yesterday, and the lights/temp only went high today after literally just a minute of driving
Old 03-12-2024, 06:39 PM   #4
Alfrz
Update, went and added some coolant, but now the car won't turn over. Haven't done anything else since I turned the car off this morning
Old 03-12-2024, 07:40 PM   #5
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
If you remove the oil cap what color is the oil ?
autoracer86 is offline   Reply With Quote
Old 03-12-2024, 08:35 PM   #6
Alfrz
Problems solved, but you mean like not just checking from the dipstick? I'm probably about due for a change so was getting that done soon anyway
Old 03-12-2024, 09:11 PM   #7
autoracer86
Drives: Toyota GT86
Glad to hear your issue is solved but no.... If coolant mixes with your oil it will look like a milkshake. This could happen from overheating the motor. Normally at that point you need a new head gasket and the heads resurfaced
So what fixed your problem ?
Old 03-12-2024, 11:23 PM   #8
whataboutbob
AutoX-10/10ths every run
Where did the coolant go should be your question. You need to answer this, before you need a motor.
Build thread:Here
Old 03-13-2024, 01:27 AM   #9
Alfrz
Yeah I'll be checking it daily for a long while
Old 03-13-2024, 01:53 AM   #10
This!
Wow
Old 03-13-2024, 03:12 PM   #11
Alfrz
Just looked like normal oil that was probably about due for a change, so just dropped it off for a change while I'm workin
Header, Error Codes, Emissions FT86OLDMAN Engine, Exhaust, Transmission 2 08-19-2019 09:42 AM
Car throwing error codes and goes into limp mode Yehia23 Issues | Warranty | Recalls / TSB 9 09-06-2018 09:28 AM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 12:35 PM
P0128 CEL Slow_86 Issues | Warranty | Recalls / TSB 3 08-31-2015 11:55 AM
Error codes + traction light after body shop Drewbie Issues | Warranty | Recalls / TSB 46 05-04-2015 10:08 PM
