#29 | ||
Drives: 2013 FR-S, 2017 BRZ
Can you post photo of the wing mounts/adjuster? on both of the APR wings I've owned, the hex tube adjuster was too long to get to the correct AOA, so I had to trim it down a bunch. I think I cut 3/4" off the universal bracket kit on my 240SX, and maybe 1/2" on the one for my FRS and I'm just now about +1 or +2deg AOA. Last edited by Matt93SE; 03-07-2024 at 02:12 PM. Reason: APC-->APR. (damn autocorrect. haha) |
| The Following User Says Thank You to Matt93SE For This Useful Post: | NoHaveMSG (03-07-2024) |
#30 | |
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
The 2D wing can go down on AOA by the way. My best result was -3 degrees but since they are chamfered and will still produce downforce. Past 5 years have been on the 2D wing running 0-degree AOA with a gurney flap. Standard side plates that came with the kit. Hope this helps. Lutfy
2015 FRS NASA ST/TT5
2022 LR Defender 2023 BMW M2 |
| The Following 2 Users Say Thank You to lutfy For This Useful Post: | Code Monkey (03-07-2024), SCFD (02-27-2024) |
#31 |
Another thing that comes across my mind is ride heights and roll center. Any pics of your car on track? how's the body roll?
If you are still on stock control arms and have the car lowered enough, you put the roll center below the car's center of gravity and then it leans like a pig in the turns. all that negative camber goes away when the whole car is leaning.
#32 | |
Drives: 22 BRZ limited
#33 |
There are hard numbers for all this, but I'm just an electrical engineer and play with security systems, not CAD and geometry. it's not that hard tho.
essentially, look at the angle of the control arm inner pivot to the pivot in the ball joint. if that is past horizontal and pointing "up" from inside to outside, then you have roll center problems. with most street cars, that's roughly around 1-1.5" lower than stock, but I've never actually done the measurements and maths on a Twin. it's likely that some of the more academic racers have done it. I just knew my car handled like crapola and was understeering with tire wear issues and I couldn't get enough camber in the car to reduce the front wear. Sooo I put on a set of SPL arms with roll correction about the same vertical offset as my lowering, then reset the bumpsteer. next race I went 2 seconds faster on the same track and had WAY better turn in response and tire wear. can't help with much more specifics than that cause it was 2 yrs ago. |
#34 | |
Drives: Crapcan
#35 |
Drives: None
Below 140mm front pinchweld to ground, per 949
| The Following User Says Thank You to RedReplicant For This Useful Post: | dragoontwo (03-08-2024) |
#36 |
Soon I should have APR GTC Wing on, Verus Splitter, end plates and dive planes installed with track spec hood vents. Springs will be 7K front/8K rear on RCE T2s. I will report progress and performance at a variety of tracks
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | autoracer86 (03-13-2024) |
#37 |
Drives: TRD Supercharged 2016 FR-S
FWIW V730s are known to like less camber than a traditional setup due to their super stiff sidewall. I forgot where I read that specifically, but to me it is apparent because I have so much wear on the inside and very very little on the outside. Camber was -3.5 front and -2.5 rear, rear was fine but going to -3 front this year.
My setup consists (at that time) TRD lip, skirts, canards. Verus UCW (mid to full AOA), hood vents, diffuser, spats. APR splitter (for the TRD lip) that is properly flat. AST 5100 suspension with 6k/6k Swift springs. TRD RLCA, toe arms, trailing arms. I have a few other things to predominantly reduce drag too, but that isnt as important in this discussion. By no means am i a specialist in any of this, this is just what I have concluded based on what I have found and what I have experienced.
"Ooh, hang on. That is the throb of a turbocharged flat four engine. A sound which, all over the world, heralds the imminent arrival of a moran" -Jeremy Clarkson
T RD, Verus, Ace |
#38 | |
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. |
#39 |
That is what is strange and what makes me think you might have a different issue. I daily the car so I understand there would be more wear on the inside, but to the extent I have it is clear I am running too much camber for the setup. 5k miles, three track days, and two autocross events and the fronts are toast on the inside. Rear at -2.5 looks like almost perfect wear to me
T RD, Verus, Ace |
#40 |
Drives: '22 BRZ
What's your toe? Inner edge wear is almost always from toe and not camber.
| The Following User Says Thank You to DocWalt For This Useful Post: | RedReplicant (03-19-2024) |
#41 |
Drives: None
Get out the pyrometer....
#42 |
A hair over zero. It's pretty close to zero.
| FS: SARD LSR Style Carbon wing **wing only* | brzzy | Canada Classifieds | 3 | 03-23-2017 09:58 PM |
| Does anybody have seibon gt wing or apr gtc200 universal wing on their car? | spicyricecake | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 03-17-2016 08:38 AM |
| FS: Used OEM Limited Wing - Dark Grey Metallic - with STi wing gurney | Enalband24 | Exterior Parts (Aero, Lighting, Etc.) | 10 | 01-03-2016 12:24 PM |
| Gauging Interest: Wing or GT Wing?! | awang0528 | Exterior Parts (Aero, Lighting, Etc.) | 3 | 05-01-2013 12:12 AM |
