Old 02-28-2024, 09:21 AM   #15
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
If over 60k, why not just drop the pan, replace the strainer, clean off the magnets and then refill. That way you'd be getting all the fluid except what was in the torque converter.
If you are worried about pressure flushing...and want to get all the fluid. An alternative way to "flush" would be to disconnect the lines from the transmission fluid cooler, put the output line to your drain pan and the input line to your new fluid container and let the transmission pump transfer the fluid. Just watch until the fluid is clean....
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 02-28-2024, 05:14 PM   #16
Brilliant. I'm using that from now on.
Old 03-07-2024, 12:36 AM   #17
pope
has a funny hat
Drives: 2014 BRZ Limited
This has been the diy trans flush method for decades. The big thing to be aware of, you generally want to use a large volume of fresh fluid (think gallons) to avoid accidentally sucking air.
pope is offline   Reply With Quote
Old 03-07-2024, 01:22 AM   #18
I figured it's an old method. I've picked up a few great ones here. Thanks for cautioning about the amount required. Makes sense.
I love learning new tricks, especially the forehead slappers like this one. Keeps me humble.
FRS main airbag G-Man Interior Parts (Incl. Lighting) 7 03-04-2019 09:04 PM
Any Scion / Toyota service techs here? Main Body ECU replacment question. boomslang Scion FR-S / Toyota 86 GT86 General Forum 4 08-30-2014 01:56 AM
summit point main 9-14 -9-15 subaruferrucci Tracking / Autocross / HPDE / Drifting 15 09-17-2013 05:48 AM
Summit Main 9/14-9/15 fredk Mid-Atlantic 2 09-02-2013 11:59 AM
WTB Main Body ECU Acree Interior Parts (Incl. Lighting) 2 03-05-2013 05:31 PM
