Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 02-09-2024, 07:20 PM   #1471
Ohio Enthusiast
Drives: 2018 BRZ
Originally Posted by arxm View Post
would you say that the oem oil/water cooler on the 2nd gens is a failure point? why would subaru design the engine with a better *barely better* and more complex oil cooling system than before if its not beneficial?
AFAIK the gen 2 OEM oil cooler is actually an oil warmer meant to eke out a little better emissions by warming the oil faster on cold start. The fact that it also acts as a cooler is an added benefit.
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
arxm (02-13-2024)
Old 02-10-2024, 09:24 PM   #1472
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Installed the Racebred splitter.
The Following 3 Users Say Thank You to DocWalt For This Useful Post:
arxm (02-13-2024), pope (02-16-2024), ZDan (02-12-2024)
Old 02-12-2024, 11:34 AM   #1473
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
Swapped out the OEM side markers for JDM. Big improvement.
Sent from my Pixel 7 using Tapatalk
Desertnate is offline   Reply With Quote
Old 02-13-2024, 08:52 PM   #1474
EZLVN
Drives: 2022 BRZ Premium, 1990 Miata
Those clear side markers look great!
It’s on my short list.
EZLVN is offline   Reply With Quote
Old 02-14-2024, 10:26 AM   #1475
Desertnate
Spelling Impaired
Thanks!
It's a really easy job for the most part. The only problem I encountered was the nuts holding the assemblies in place was really tight and did not come off as easily as the Youtube videos seem to indicate. My 10mm box end wrench was the best tool for the job due to the available space, but it wasn't long enough to get the leverage needed to break the nuts loose. I had to wedge my small socket wrench in there to get things started. Once loose, I easily spun it off with my fingers and replaced it by hand and the box end wrench.
Old 02-14-2024, 01:49 PM   #1476
EZLVN
Do you mind sharing which ones you purchased?
I see aftermarket selling for about 50.00 and OEM JDM’s going for about 150.00
Old 02-14-2024, 05:21 PM   #1477
Desertnate
Spelling Impaired
I went with the OEM JDM's.
They are a lot more than some aftermarket options, but I felt going with the OEM reduced the risk of the fit not being quite right or other quality problems like bad wiring or leaks.
The Following User Says Thank You to Desertnate For This Useful Post:
EZLVN (02-14-2024)
Old 02-16-2024, 09:47 AM   #1478
Lelandjt
Drives: '04 STi, '12 Mazda 3 Hatch
I wonder what happens to the air when it hits those 4 different lips stacked on top of each other, but with 1cm gaps between each. Nothing productive I'm guessing...
To be clear my criticism is more of the stock design than your mod. You just made a bad thing a tiny bit worse.
Lelandjt is offline   Reply With Quote
Old 02-16-2024, 09:50 AM   #1479
Lelandjt
I got the cheap ones from Amazon. They fit fine and look like the ones pictured above. Big improvement on a silver car, probably any color.
The Following User Says Thank You to Lelandjt For This Useful Post:
Desertnate (02-22-2024)
Old 02-16-2024, 10:00 AM   #1480
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
There are no gaps between any of them? They're all sealed together, the air can't go through the "gaps" so it just creates a high pressure bubble and and the air moves smoothly.
Old 02-21-2024, 08:13 PM   #1481
MikeNSX2
Drives: Ice Silver 2022 BRZ Limited
Installed an MBRP axle back with Carbon Fiber tips.
Now I have three aftermarket axle backs to swap between (HKS Legamax Premium, Nameless Performance with dual 5" mufflers and the MBRP).
MikeNSX2 is offline   Reply With Quote
Old 02-22-2024, 10:41 AM   #1482
Desertnate
Spelling Impaired
Could you do a quick (i.e. only a sentence or two) comparison of the three?
The only one I've heard in person is the MBRP, but I'm leaning towards the HKS. Mostly because the owner of the MBRP mentioned the drone inside the cabin wasn't "too bad". We did have a bit of a language barrier, so I'm not totally confident in how well we were communicating.
I'd really like to improve the sound without making the car much louder internally or externally. I admit I'm not a fan of the blued tips on the HKS.
Old 02-22-2024, 11:00 AM   #1483
Desertnate
Spelling Impaired
Old 02-22-2024, 01:09 PM   #1484
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I have nothing to add here except that with ACE catless headers, stock exhaust and Verus diffuser the stock cat back does drone.
WHAT DID YOU DO TO YOUR FRS TODAY? KalbiCool88 Scion FR-S / Toyota 86 GT86 General Forum 1 11-04-2015 11:36 PM
Do you know what today is? Yruyur Off-Topic Lounge [WARNING: NO POLITICS] 26 01-21-2015 03:51 PM
just got my OFT today...help please! carlitosway6891 Software Tuning 9 02-20-2014 11:05 PM
TODAY, TODAY, I GET IT TODAY!!!! :D Trashed675 Scion FR-S / Toyota 86 GT86 General Forum 54 02-14-2013 02:16 AM
