#85 |
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | RT-BRZ (02-06-2024), x808drifter (02-06-2024) |
#86 | |
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. |
#87 | |
Drives: 2013 Subaru BRZ
Honestly, I'm not the design engineer for these engines and I'm definitely not qualified to determine what's better. All I am is a caveman trying to understand the wheel. |
#88 |
Okay, I have what I bet is a really dumb question:
Higher number = thicker IE: 40weight is thicker than 50 weight oil. Okay, then why is the first number (cold temp/winter) number always lower than the hot number? 5W40 means the oil is thicker at temp than when it's cold? I dont see how the hell that is possible, and I'm damn near certain it's not unless I'm losing my mind. So why is it numbered like this?
#89 | |
Drives: 2018 BRZ
A 5W30 will behave like 5 in cold temps (W rating is at 0 degrees Fahrenheit) and like 30 in working temps. |
| The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | villainous_frx (02-19-2024) |
#90 | |
Thicker = higher number cold number is lower.
#91 |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
| The Following User Says Thank You to villainous_frx For This Useful Post: | x808drifter (02-19-2024) |
#92 | |
Drives: 2018 BRZ
A multigrade oil (like 5W30) is able to run thinner in cold temperatures while not being super thin in working temperature. So the W (Winter) number is low because the oil is pretty thin when cold, and the regular number is higher to offer protection at working temperatures and above. |
#93 | |
How is it only "5" at cold temps and "30" at 200 degrees!? Also, this not only doesn't follow my common sense test, but it doesn't follow my data either. My oil pressures are definitely lower at 200 than startup. I get a straight 30 weight would be much thicker in the cold, so they use multigrade, but shouldn't it be a higher number? Ie instead of being 100 in the cold, it's only 40.
#94 |
Drives: 2018 BRZ
The magic of viscosity index improvers. I won't claim to understand the chemistry of how they work, but they allow oil to be in the correct viscosity at 0 degrees as well as at 212 degrees.
To make it easier to think about, consider the W and regular weights to be on different scales that are un-related. Choose the W weight based on the coldest you expect the car to need a cold start, and the regular weight based on how hot you expect the engine to operate at. |
#95 |
30 minute maintenance
Drives: My18 wrxsti
A 215 35 r18 tyre is not wider than it is round. It`s a different measuring system.
#96 |
Drives: 2013 BRZ HKS Turbo
This is a great question, that I will answer with numbers pulled out of my a$$ for a simple explanation.
The oil weight is not a viscosity rating. The viscosity rating is measured in, for example, pascal-second (Pa·s). So lets lay out how to different motor weights change viscosity over temperature. 5 weight- 50 Pa·s @ 0*c ------------5 Pa·s @ 100*c 40 weight- 200 Pa·s @ 0*c------------50 Pa·s @ 100*c With these totally BS numbers, we see that if we make a 5W-40, this oil will have the same viscosity at 0*c as it does at 100*c, 50 Pa·s. In reality, you aren't going to hold the viscosity the same over the full temperature range, so you do end up with a thinner oil as it heats up, maybe something like.... 5 weight- 50 Pa·s @ 0*c ------------5 Pa·s @ 100*c 40 weight- 200 Pa·s @ 0*c------------20 Pa·s @ 100*c So at operating temp it has a viscosity rating of 20 Pa·s like a 40 weight oil, and while it's still thicker at cold temperatures with a 50 Pa·s viscosity rating, it's much thinner then a 40 weight oil would be.
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
#97 | |
Is there some rule that something for cars can't be measured in a rational way? We need to produce figures for viscosity at room temperature and operating temperature. Definitely do NOT just state viscosity at those two temperatures. The first number okay, but the second number, make it how much viscosity an oil would have at room temp, based on how much it thinned out at operating temp. How should we handle tires? Well, we will make the width in mm because metric is the standard of the world. So the wheel size in metric too? No. Will we measure the overall height in metric? No. Imperial? Also, no. What? How will people know the over diameter They won't. We will measure it making it sidewall Oh, so like 245mm/100mm/17? Heavens no. We will make it expressed as the percentage of the overall width. For the overall diameter? No just the sidewall Okay, so the number will be the amount the sidewall adds as ratio of the width. ...half the sidewall adds. Forced induction Should we measure how much air is going in? No, that can change too much based on conditions. Should we measure it, at STP? No, we will measure airflow by how much restriction the air intake system has But that doesn't tell us anything for how much air, power, fuel etc its getting. Precisely. Okay, let's just measure the power output of this car and move on. Take the transmission off first.
| The Following User Says Thank You to GrandSport For This Useful Post: | Ohio Enthusiast (02-20-2024) |
#98 | |
The average consumer also shops brake pads by mu and mot, typically, followed by price. Brake pads are so much more complex than that. |
| Best track hood for cooling (coil overheating issue) | GrandSport | Tracking / Autocross / HPDE / Drifting | 54 | 01-07-2024 06:43 PM |
| Track Car Weight | Lunatic | Tracking / Autocross / HPDE / Drifting | 83 | 03-15-2021 12:35 AM |
| Track car weight reduction | Irace86 | BRZ First-Gen (2012+) — General Topics | 17 | 06-11-2016 05:21 PM |
| Weight Reduction vs. Weight Distribution (for track use not for drag..etc) | glamcem | Tracking / Autocross / HPDE / Drifting | 21 | 07-01-2014 11:38 AM |
| NPA: APR Carbon Fiber Brake Cooling Kit with Ducts - A must for track days | 86_Insider | Brakes, Suspension, Chassis | 1 | 09-26-2013 01:39 AM |
