| Software Tuning Discuss all software tuning topics. |
#15 | |
Drives: WRB BRZ
Ok If it ran good for a while and nothing changed not tune not hardware Then the most likely issue is a hardware fault wiring fault bad sensor or similar If it started happening after a tune upbadte then it's possibly tune related Can you go back to an earlier revision and see if same issue |
#16 | |
Drives: TRD Supercharged 2016 FR-S
"Ooh, hang on. That is the throb of a turbocharged flat four engine. A sound which, all over the world, heralds the imminent arrival of a moran" -Jeremy Clarkson
T RD, Verus, Ace |
| The Following User Says Thank You to Bergycheese348 For This Useful Post: | AussieBRZ (01-10-2024) |
#17 |
@FR-S2GT86 & @AussieBRZ
Car battery died last night on a busy road. First time to see the cops behind me and not be handed a ticket lol. Got jumped, went to get a new battery, installed it (just a regular battery for the car, not a LW battery), drove away fine. Might have been right away or not but my dash looked a bit different. No TC/SC/ABS light, and it has been gone since. I will update if it returns, but might have been a battery issue...somehow.
T RD, Verus, Ace |
#18 | |
Master Collaborator
Unfortunately, the electronics in these cars are really susceptible to low voltage issues. Low voltage can sometimes even cause permanent damage. |
#19 | |
I had not fully heard of the weird things low battery numbers can do until I talked to the friend who helped me install it talking about the issues he had with a bad battery on his Cobalt a few years ago. Let's hope I can at least retain ABS haha
T RD, Verus, Ace |
#20 | |
Master Collaborator
So on the Harrop, the evap purge valve is transferred from the bottom side of the stock intake manifold, onto the underside of the supercharger. Is this the same for the TRD? Did you make sure to connect the hoses properly and have you checked it to make sure it's still connected electrically? |
#21 | |
T RD, Verus, Ace |
#22 | |
Master Collaborator
You're probably getting some raw fuel vapor smells coming from the engine bay, huh? The outlet of the purge valve normally should be routed to the OEM intake at the rear, next to the PCV hose connection. On the Harrop, it is routed up to the intake side of the supercharger after the throttle body, so that it has a vacuum on it at all times while the engine is in operation.
#23 | |
And I would not say it smells like i am getting fuel vapor smells from the engine bay. Standing outside of it there is no smell, and driving it has the same smell as before as it is catless. Now, because there is no place to run it to at all, what would you suggest I try? Would plugging it up completely solve it?
T RD, Verus, Ace |
#24 | |
Master Collaborator
You definitely don't want to plug it up completely. Take a look at this picture below of the underside of the Harrop. 1) is where the purge valve mounts. 2) is the hose end supplied by Harrop that connects to the outlet of the purge valve. 3) is where the hose routes to the intake side of the compressor, downstream of the throttle body. Your TRD supercharger should have something similar in design that you can connect to. |
#25 |
Master Collaborator
@Bergycheese348
Got your PM. So why not just tee into the brake booster hose as close to the inlet of the compressor body as possible? It should have vacuum on it at all times. If you notice in the picture I posted above, there are multiple vacuum ports. They are basically all feeding from the same point; the space between the throttle body and the inlest side of the compressor. One is for the bypass valve, one for the brake booster, one for the PCV valve, and one for the purge valve. |
#26 | |
T RD, Verus, Ace |
#27 |
Master Collaborator
Essentially, yes. But that depends entirely on where your brake booster is acquiring its vacuum source. Some of these cars use a vacuum pump for the source instead of connecting to the manifold. How was yours originally set up before the supercharger install?
#28 |
It was connected to the intake beforehand, using the pressure from that. The supercharger also has a spot for the brake booster, which is attached. It is on the adapter between the Tundra TB and the Supercharger housing (if you have seen it, it is the black piece).
T RD, Verus, Ace |
| Rear Wheel Speed Sensor | gatorac | Engine, Exhaust, Bolt-Ons | 0 | 06-20-2021 05:30 PM |
| Brz wheel rear left wheel speed sensor | 3k1n | Want-To-Buy Requests | 1 | 09-11-2020 12:11 AM |
| Wheel Speed Sensor A P0500 | imhereforthecar | Electronics | Audio | NAV | Infotainment | 2 | 09-22-2019 10:09 AM |
| So i broke my wheel speed sensor | bkblitzed | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 11-18-2016 04:04 PM |
| Ecutek; where to find Ethanol percentage w/ flexfuel | Gixxer86 | Software Tuning | 3 | 12-03-2015 05:55 AM |
