#43 |
Drives: 2015 Scion FRS - Raven
I chose to change the LSD with the final drive for two reasons. 1 everything was apart already and 2 I wasn’t sure if the taller gear would make the tires spin easier losing traction with the stock LSD. What other questions did you have?
#44 | |
Drives: Man
Sent from my LG-H872 using Tapatalk |
| The Following User Says Thank You to j5o5n For This Useful Post: | TRAKRAVN (07-28-2018) |
#45 |
It feel great aside from highway cruising at 4100rpm. But I think that’s more to do with the Tomei 60R exhaust. On the track it feels similar to a supercharged car and gets jut about the same times as well. I would recommend a diff cover with cooling fins as well, I’m using the Greddy unit.
| The Following 2 Users Say Thank You to TRAKRAVN For This Useful Post: | new2subaru (07-28-2018), SuperTom (07-28-2018) |
#46 |
Drives: swp mt '14 brz premium
#47 |
Drives: 2017 Toyota 86
#48 |
I don't know if the 5.29 ring gear is too big to fit in there with the Torsen gears. Back in the early 60's I had a bunch of different ratios in my '57 Chevy and I remember that with some of them a different carrier was required, so I was wondering if there would be any kind of problem like that with the twins.
#49 |
#50 |
Drives: 2014 scion frs
Where is the best place to get the 4.88 FD I see them on weir website but not sure if it's the one for the Supra ?
Is weir the same as spencer fabrication ? Thanks guys |
#51 |
Spence Weir (in Cal.) has the 4.88 you want. Look up Weir Performance Engineering. Spencer Fabrications (in N.H.) closed up shop last year because he got a very good job offer and took it.
#52 |
Noodleking
Drives: 2013 Firestorm FRS
Ooh snap. So I went 5.29 from Weir on my car. It’s pretty fun and goofy. Can’t actually tell if my car is faster or slower, but it feels more fun in the sense that it makes you sink into the seat more and you’ve got to shift more. I think I’ve effectively lost 6th gear and gained a low gear, like if there was a .5, 1, 2, 3, 4, 5, R. Third gear feels like 2nd gear and 4th gear feels like 3rd gear. There’s a little more room in those gears though, so I think I’ll like it a bit more when drifting. 1st gear is super short and almost makes this impossible to stall with the supercharger. I can lose traction through 1st and 2nd and the beginning of third on a straight. I don’t think it’s for everyone, but it definitely is a difference. The Kaiju Motorsports charged $1700 here in Vegas for the install and replacement of bearings, if people were still wanting a relevant piece of info for pricing. Feel free to message me if there’s any questions about this on my build.
2013 Firestorm FR-S, Kraftwerks C38 kit, FT-86 UEL Catted Headers, TRD D-Tip cat-back, Vibrant 1140 Resonator, Exedy Stage 1 Normal/smoother clutch that replaced the Stage 2 3-puck clutch, Exedy Lightweight flywheel, DSS carbon fiber driveshaft, TEIN springs on performance package Sachs dampers, Megan Racing Inner tie rods, 17x8 +35 Enkei Silver RPF1's, OS-Giken 1.5-way diff, J-Luth steering wheel and now a GKTech angle kit-- which rubs.
#53 |
Noodleking
https://www.facebook.com/mykii.liu/p...2zX14DVxCtAZml
Here's a video with the 5.3 gears installed. I'm considering dropping down to 3.5 or 3.7 gears and using 2nd gear rather than 3rd gear. Currently, it feels awesome as is-- but highway driving is nuts... it's like 5k at 75mph or something goofy like that. Definitely not made for the highway commuters-- which I'm okay with since I take this to work on the surface streets. Super fun though!
| The Following User Says Thank You to Mykii For This Useful Post: | Teseo (01-16-2024) |
#54 |
Drives: frs
Make sense because you have supercharger
#55 | |
Drives: 2015 BRZ 2004 SVT Cobra
I want to go 4.88 or 5.29 with my Sprintex car. |
| The Following User Says Thank You to EvilPenguin04 For This Useful Post: | Teseo (01-16-2024) |
#56 |
Noodleking
Ha! I would if you had a OSGiken in it :P
| 4.8 final drive | drift86 | Engine, Exhaust, Transmission | 29 | 11-28-2022 01:49 PM |
| Needed: drive line shop in Houston for 4.56 final drive install - good experiences? | Joesurf79 | Southwest | 3 | 03-10-2017 01:21 AM |
| 3.7 Final Drive | GsxrMe | Engine, Exhaust, Transmission | 9 | 09-28-2015 08:55 AM |
| FS: BNIB Weir Performance 4.56 SOLD | mrk1 | Engine, Exhaust, Bolt-Ons | 5 | 07-12-2015 03:33 PM |
| WEIR Performance 4.56 FD & IS300 LSD Rear Differential | SportInjected | Transmission and Driveline | 3 | 08-09-2014 10:36 AM |
