Old 12-19-2023, 01:12 PM   #239
ka-t_240
Originally Posted by tomm.brz View Post
Still i m not understanding how doable is this swap, fa24 short block into restyling fa20 with fa20 heads?
Did someone here figure out what s really needed?
There is a shop in MN that has done multiple of these swaps. Also complete FA24 in first gen cars.
ka-t_240 is offline   Reply With Quote
Old 12-19-2023, 05:59 PM   #240
new2subaru
Weight Weenie
Drives: 15 FR-S
Link? What is the name of the shop?
Old 12-19-2023, 06:13 PM   #241
ka-t_240
Two shops that I know with running / driving cars, both shops are owned by friends
RS Motors in MN has done a couple.
ASM in WI - I know he has one in his daily.
The Following 3 Users Say Thank You to ka-t_240 For This Useful Post:
kmbkk (12-23-2023), new2subaru (12-19-2023), Ultramaroon (12-20-2023)
Old 12-28-2023, 03:10 PM   #242
ka-t_240
You may want to check out RS Motors on FB..... posted some teasers today
The Following 2 Users Say Thank You to ka-t_240 For This Useful Post:
kmbkk (12-29-2023), RedReplicant (12-29-2023)
Old 12-29-2023, 04:57 PM   #243
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I saw that yesterday! Looks promising for those of us interested in this swap.
kmbkk is offline   Reply With Quote
Old 12-30-2023, 10:15 AM   #244
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I saw the cam reluctor wheels they posted. Kinda what I have been thinking all along with just swapping the complete engine. The crank reluctor from the first gen engine I imagine should bolt on. What I am curious about is my understanding is that the 2nd gen has the same crank and cam signal type as the 17’+ first gens. So is the new cam wheels only needed for the 13’-16’ cars or not.
Edit: RS Motors did confirm the new cam reluctor wheels are only needed for 13-16’ cars.
Old 12-30-2023, 02:46 PM   #245
FrickingReallySlow
Drives: 2015 FR-S
Now if someone could kindly provide us with head CNC program to get to the right compression ratio/cyclinder volume using those FA20 heads
FrickingReallySlow is offline   Reply With Quote
Old 12-30-2023, 03:18 PM   #246
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Or just use the entire FA24 I can’t imagine machining and rebuilding the heads and assembling them to the short block is that much cheaper. Also curious if they are using the FA20 timing cover and upper oil pan or the FA24’s.
Edit: RS is pretty responsive. I didn’t ask them for any more info since they did the work but it does appear with the FA24 short block they are using everything else from the FA20. I’d probably be best to ask them which route would be best to go with. I’d imagine for a DIY’er the complete engine would be easiest. The kit to do the complete engine is 700 bucks and they have 1st batch parts coming out.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
T-Steve (12-31-2023), Teseo (12-30-2023)
Old 12-30-2023, 06:55 PM   #247
Teseo
Drives: frs
$700 + FA24 engine ?
Old 12-31-2023, 12:32 PM   #248
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Probably factor in 2-300 bucks for incidentals on top of that too but basically that’s what it sounds like.
Teseo (12-31-2023), Ultramaroon (01-01-2024)
Old 01-02-2024, 01:00 PM   #249
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
From the pictures on their FB for the FA24 shortblock swap it appears that the timing cover, upper oil pan & oil pan are used from the FA20 engine. They show a couple of pics of the FA24 block, no idea what, if anything is done with the heads to account for the 8.0mm bore difference (94.0mm to 86.0mm)...or if that is really an issue at all....
Looks like it will be at a simialr price point as the HKS FA20 2.1L Stroker kit
Still very, very interested....
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 01-03-2024, 11:03 AM   #250
ka-t_240
I do believe that they have FA24 complete swaps completed so that cars can complete in ClubTR for Gridlife, in addition to FA24 short block with FA20 heads/etc.
The Following User Says Thank You to ka-t_240 For This Useful Post:
RedReplicant (01-03-2024)
Old 01-05-2024, 09:24 AM   #251
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
My question would be, would either generation of Harrop bolt properly into place with this FA24 block / FA20 head combination?
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 01-07-2024, 02:04 PM   #252
Arthur-A
Arthur-A's Avatar
Drives: 2020 BRZ/86, 2020 BMW 330i
Interesting, does that mean the car won't inherit the Gen2 oil pressure issues as they seem to be caused by the oil pan difference?
Arthur-A is offline   Reply With Quote
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 10:18 AM
FA24 In-Depth Look Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 36 10-11-2021 08:27 AM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 10:55 AM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 03:59 PM
Incoming... MisterSheep Off-Topic Lounge [WARNING: NO POLITICS] 19 04-02-2016 12:33 AM
