#239 |
#240 |
Weight Weenie
Drives: 15 FR-S
#241 |
#242 |
You may want to check out RS Motors on FB..... posted some teasers today
#243 |
First 86 Driver Baby!
Drives: FR-S, Flex
#244 | |
Drives: Crapcan
Edit: RS Motors did confirm the new cam reluctor wheels are only needed for 13-16’ cars.
#245 | |
Drives: 2015 FR-S
#246 | |
Drives: Crapcan
I can’t imagine machining and rebuilding the heads and assembling them to the short block is that much cheaper. Also curious if they are using the FA20 timing cover and upper oil pan or the FA24’s.Edit: RS is pretty responsive. I didn’t ask them for any more info since they did the work but it does appear with the FA24 short block they are using everything else from the FA20. I’d probably be best to ask them which route would be best to go with. I’d imagine for a DIY’er the complete engine would be easiest. The kit to do the complete engine is 700 bucks and they have 1st batch parts coming out.
#247 | |
Drives: frs
#248 |
Drives: Crapcan
Probably factor in 2-300 bucks for incidentals on top of that too but basically that’s what it sounds like.
#249 |
Drives: 2023 Toyota GR 86 Cup
From the pictures on their FB for the FA24 shortblock swap it appears that the timing cover, upper oil pan & oil pan are used from the FA20 engine. They show a couple of pics of the FA24 block, no idea what, if anything is done with the heads to account for the 8.0mm bore difference (94.0mm to 86.0mm)...or if that is really an issue at all....
Looks like it will be at a simialr price point as the HKS FA20 2.1L Stroker kit Still very, very interested....
2023 GR Cup Car
#250 |
I do believe that they have FA24 complete swaps completed so that cars can complete in ClubTR for Gridlife, in addition to FA24 short block with FA20 heads/etc.
#251 |
Master Collaborator
My question would be, would either generation of Harrop bolt properly into place with this FA24 block / FA20 head combination?
#252 |
Drives: 2020 BRZ/86, 2020 BMW 330i
Interesting, does that mean the car won't inherit the Gen2 oil pressure issues as they seem to be caused by the oil pan difference?
| FA20 vs FA24 | Zata | Engine, Exhaust, Transmission | 15 | 06-01-2023 10:18 AM |
| FA24 In-Depth Look | Kona61 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 36 | 10-11-2021 08:27 AM |
| Second Gen Swap? FA24 | AutoNewb | Engine Swaps | 86 | 07-06-2021 10:55 AM |
| FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 03:59 PM |
| Incoming... | MisterSheep | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 04-02-2016 12:33 AM |
