Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 11-29-2023, 10:33 AM   #1443
Talus1
Talus1's Avatar
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
Originally Posted by Varelco View Post
Looks like your exhaust got left behind, no one told it it needed lifting, hanging low there my friend.
Ya, that’s the downside of the subframe spacers that are needed to keep the CV joint angles reasonable with the ADM lift kit. On the 2nd gens, there isn’t enough clearance to the exhaust pipe where it goes under the diff so you have to add longer rubber hangers around the muffler. (I initially also added a longer hanger to the single point in front of the diff before realizing that particular hanger attaches to the subframe, not the chassis…)
There’s an exhaust joint right in front of the muffler, so at some point I might try to add a tapered shim there to tilt the muffler upwards to get the exhaust tips back up near where they’re supposed to be. The tricky part would actually be finding rubber hangers that are the right length(s). To make the shim work I think I’d need hangers for the rear 2 points that are just slightly longer than stock and ones at the front 2 points that are just slightly shorter than the longer ones I actually used. There just doesn’t appear to be that much choice in hanger length, nor of course do most vendors state the centre-centre hole spacing.
TBH, it doesn’t bother me much and, since I haven’t decided if I will leave the lift kit on over the summer, I don’t want to do anything rash or permanent like getting the exhaust pipe bent or bending the wire hanger mount brackets.
Anything worth doing is worth doing twice...
Talus1 is offline   Reply With Quote
Old 11-29-2023, 01:54 PM   #1444
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Ordered the Remark midpipe, pairing it with my JDL UEL, JDL Ultra Quiet front pipe, and STI muffler. Really curious how it's going to sound!
Old 11-30-2023, 02:26 PM   #1445
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by vindiesel View Post
You win the most disgusting award ha ha! I drive 12-15000 miles a year just driving to work.
What offset did you go with on your new wheels?
September of last year for my '23. Haven't crossed 3k miles yet.
But my commute is just walking from the bedroom to the other side of the house.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post:
pope (12-03-2023), vindiesel (11-30-2023)
Old 11-30-2023, 02:47 PM   #1446
eyeballs
Drives: '22 BRZ
+44. Current commute is 3.2mi one way. Tried a slightly longer route today, but it ended up taking even less time due to lack of traffic lights. New location means an even shorter drive now. Barely enough for the car to warm up with winter here.
eyeballs is offline   Reply With Quote
The Following User Says Thank You to eyeballs For This Useful Post:
Old 12-07-2023, 10:32 PM   #1447
arxm
Drives: 2013 FR-S, 2023 BRZ
i only put maybe 5000km on my first gen last year, mind you 4,999 of those were probably between 5k and 8k rpm
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 12-08-2023, 05:00 PM   #1448
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ
Winter tires on
And they are squishy…removes a little bit of the fun.Name:  IMG_8544.jpg
Stonehorsw is offline   Reply With Quote
The Following 4 Users Say Thank You to Stonehorsw For This Useful Post:
AK2112 (12-12-2023), Busybee (12-16-2023), Dzmitry (12-12-2023), Wally86 (12-12-2023)
Old 12-11-2023, 12:56 PM   #1449
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
Crash bolts installed and a proper alignment over the weekend. The car was a bit out of whack in stock form, so the difference between how it drove before/after is quite noticeable.
Desertnate is offline   Reply With Quote
The Following User Says Thank You to Desertnate For This Useful Post:
Old 12-12-2023, 05:13 PM   #1450
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Added the Verus master cylinder brace and bellhousing cover. The cover is NOT a direct bolt on like the last gen but it does fit the FA24 if you space the tube back there up so that the cover fits under the bracket. There is plenty of flex in the hose back there. And you need a bolt to go in the empty hole, also.
The Following 3 Users Say Thank You to dragoontwo For This Useful Post:
norcalpb (12-13-2023), Stonehorsw (12-12-2023), Wally86 (12-13-2023)
Old 12-13-2023, 12:11 PM   #1451
Desertnate
Spelling Impaired
How much better is the brake feel with the brace mounted?
Old 12-13-2023, 12:25 PM   #1452
dragoontwo
dragoontwo's Avatar
I was a bit apprehensive as to how it would feel, but it does add firmness to the pedal. For me the squishiness that is there was never noticed until I installed the brace. I'm not even talking about under hard braking. I noticed it right away while just driving around town and not getting into the brakes hard.
I don't think it will do any thing for the performance of the brakes as you can still lock them up without it. It just gives better and more consistent pedal feel as you have taken some flex out of the system.
Desertnate (12-13-2023), norcalpb (12-13-2023), Talus1 (12-14-2023)
Old 12-14-2023, 09:11 AM   #1453
mr.whiskers
Drives: '22 BRZ
Went for my semi-annual oil change yestarday at the dealer. After coming home and looking at the paperwork I was surprised that it says they put 5w-30.
I thought the dealer always went strictly by the book. I think next oil change in the summer I will ask them to put in 5w-30 again see what they say
mr.whiskers is offline   Reply With Quote
Old 12-14-2023, 07:25 PM   #1454
arxm
I thought my red brz looked good on first gen wheels but damn the blue pops, i like the wheel better on the new body than the old one lol
Old 12-15-2023, 12:44 PM   #1455
OkieSnuffBox
It was the same for my car last oil change, the paperwork said 5w-30.
That is an option in the manual IIRC.
I assumed they put it in since my car is lowered, wheels, exhaust so thinking I probably drive it harder than I actually do.
Old 12-20-2023, 12:25 PM   #1456
mr.whiskers
Drives: '22 BRZ
I thought the manual said to use 5W-30 when 0W-20 is not available?
Maybe the whole oil starvation issue is causing them to go safer and put in 5w-30.
WHAT DID YOU DO TO YOUR FRS TODAY? KalbiCool88 Scion FR-S / Toyota 86 GT86 General Forum 1 11-04-2015 10:36 PM
Do you know what today is? Yruyur Off-Topic Lounge [WARNING: NO POLITICS] 26 01-21-2015 02:51 PM
just got my OFT today...help please! carlitosway6891 Software Tuning 9 02-20-2014 10:05 PM
TODAY, TODAY, I GET IT TODAY!!!! :D Trashed675 Scion FR-S / Toyota 86 GT86 General Forum 54 02-14-2013 01:16 AM
