Old 12-11-2023, 07:30 AM   #1
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Clicking noise felt in clutch pedal
Just noticed this after drive into work this morning. Clutch done 1200km ago. Exedy OEM flywheel and clutch, new front bearing cover and battle garage TOB, verus fork+pivot.
Pedal is making a tick sound about 1-2inch off the floor which can be felt in the pedal. Edit only when pressing the pedal to the floor.
I also have a Forester slave cylinder installed for added information.
Any ideas as to what's happening?
Clutch Pedal is currently adjusted to same height as brake pedal. Releasing pedal from the floor, the clutch starts to grab at the end when pedal is almost fully released.
Old 12-11-2023, 08:03 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Just to confirm. It's only clicking as it goes to the floor but not at all when it comes back up right?
The Following User Says Thank You to x808drifter For This Useful Post:
RToyo86 (12-11-2023)
Old 12-11-2023, 08:14 AM   #3
RToyo86
RToyo86's Avatar
Yes, just clicks as press to the floor, no noise when I release pedal.
The Following User Says Thank You to RToyo86 For This Useful Post:
x808drifter (12-11-2023)
Old 12-11-2023, 08:43 AM   #4
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
First, I'd try adjusting the clutch rod so that it engages earlier. You could also remove the assist spring.
Old 12-11-2023, 03:22 PM   #5
Can you squeeze the fluid out of the slave cylinder by pulling the top of the fork forward? Do that before touching anything else.
Old 12-11-2023, 05:03 PM   #6
RToyo86
RToyo86's Avatar
Yes it's very quishy. And the rod has play.
To follow up, noise was gone when car was cold and returned after I drove it 35km home. Maybe air in the system?
Old 12-11-2023, 10:36 PM   #7
Not returning is ok. We're squeezing the fluid back into the reservoir the same way that clutch wear does. This test confirms that the clutch pedal linkage allows the supply port to open in the released position. The only thing pulling fluid back out of the reservoir is a dinky little spring in the slave cylinder. It will eventually take up the slack. Alternatively, the clutch pedal can be pressed a couple times. If the fluid is really squeezed out, the helper spring may hold the pedal to the floor the first time it's pressed. No biggie.
It's not air because that would have the opposite effect. Clutch would not disengage. My money's on the pressure plate.
RToyo86 (12-12-2023)
Old 12-12-2023, 01:28 AM   #8
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Cylinder rod movement looks normal to me
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
Old 12-12-2023, 06:26 AM   #9
RToyo86
RToyo86's Avatar
I was afraid of it requiring another transmission drop. Anything to look for when inspecting things?
Out of curiosity what could cause pressure plate noise only when system is hot? I noticed it doesn't make the sound wheb everything is cold after it sits for several hours.
Follow up question to that, am I okay to clean up then swap my OEM pressure plate to see if it fixes the problem?
Edit drove to work this morning.
No noise for first 15 minutes driving. Got caught in bumper to bumper on highway for 10 minutes. Noises started again.
Then it went away for the few shifts needed to get up to highway speeds. After I got off the highway noise returned for the next set of shifts to get to work.
Ultramaroon (12-12-2023)
Old 12-12-2023, 05:54 PM   #10
RToyo86
RToyo86's Avatar
Update.
Decided to fiddle around with clutch pedal height to see if I could make sense of this and I think I may have made some progress.
Previously had the cruise control switch adjusted to the same height as the brake pedal and then brought the clutch pedal height to get is as close as possible to remove slop
I made 3 adjustments on the drive home since it happens once it warms up. Ended up shortening it a few spins, enough that the pedal still sits at the same height but has some slop before anything happens on initial press.
Final adjustment was done in the driveway and took a spin around the block.
Old 12-12-2023, 11:29 PM   #11
I've been thinking that I should explain my reasoning. I'm not focused as much on the click as I am on the change in engagement point. It's not ok for the clutch to "start to grab" so late in the pedal arc. Was this gradual? How did it behave when you first installed it?
Depending on the condition of the pressure plate, it might not be crazy to consider reusing it. It should show little to no wear, nor any hot spots. I've seen both gently used, and completely neglected.
You have the Verus fork. I can only explain the click with a worn stock fork. This is a mystery.
RToyo86 (12-13-2023)
Old 12-13-2023, 06:36 AM   #12
RToyo86
RToyo86's Avatar
I think your initial diagnosis makes sense given info I provided. First drive after install felt like clutch grabbed at end of the pedal. With my old TOB so close to failure it sort of operated like a button on/off switch.
Now it feels properly gradual which might be part of the change in feel with the BG TOB?.
I also swapped back to OEM slave just to get a baseline when I adjusted the pedal. Going to keep an eye on the sound but the way it's adjusted currently it grabs more naturally.
In having adjusted it so much I may have adjusted it last time a bit too long?
I am planning to keep an eye on it and gradually start pushing the clutch more and more just to see if there's any slip during harder shifts.
Edit turned off traction control and did a few quicker shifts from 2-3. Also got rear end loose in first leaving a stop while making a turn. Pressure plate looks to be supplying enough pressure. Noise still happens at a stop when I press in pedal on occasion. Doesn't happen every time.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
blsfrs (12-13-2023), Ultramaroon (12-13-2023)
Old 12-13-2023, 01:17 PM   #13
^^^ credit ^^^ I prefer leaving the spring installed and going with the Forester slave. Gotta plug my signature mod even though I let it get out of control with the stainless braided line. That was silly.
blsfrs (12-13-2023), RToyo86 (12-13-2023)
Old 12-13-2023, 06:49 PM   #14
RToyo86
RToyo86's Avatar
Good chance I'll be swapping that slave back in. Even with the Mtec assist spring the pedal is still so very very light.
Definitely a good mod and cheap!
The Following 3 Users Say Thank You to RToyo86 For This Useful Post:
blsfrs (12-13-2023), Teseo (12-13-2023), Ultramaroon (12-13-2023)
Clicking noise from clutch when depressed/released? BaeK Issues | Warranty | Recalls / TSB 30 02-05-2025 05:20 PM
BRZ Clutch clicking noise/tick Nfsundrgrnd Issues | Warranty | Recalls / TSB 18 07-07-2021 10:23 AM
Clicking noise while Driving stops when Clutch is pressed Inteze Engine, Exhaust, Transmission 12 04-09-2020 01:07 PM
Clicking sound when Pressing Clutch Pedal Archetyp3 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 01-03-2020 11:57 AM
Clutch Pedal "Clicking" Noise on new BRZ Shizuka Engine, Exhaust, Transmission 6 05-31-2019 01:57 PM
