Old 12-09-2023, 06:33 PM   #1
Theodorable
Drives: 2015 Scion Frs
NEED HELP WITH MANUAL SWAP ASAP!
Ok so I’m manual swapping my car. A couple questions, for the vacuum pump can I leave it there and cap the vacuum hole off instead of buying a cam plate?
Also trans fluid. I know a lot of people use motul 75w-90 300 gear oil but an off the shelf one like Valvoline SynPower 75W-90 Full Synthetic Gear Oil good as well? It’s rated for both GL4 and GL5 like the motul. Is this valid?
Update: does anyone know the thread size for the abs brake line fittings?
Theodorable is offline   Reply With Quote
Old 12-09-2023, 10:40 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'd personally block off the cam plate. The factory one is just a cheap stamped piece.
Yeah, you can use an off the shelf stuff, can't be any worse than the factory fill. I actually don't like the Motul anyway and run Redline which is readily available most box stores.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Ultramaroon (12-09-2023), Wally86 (12-13-2023)
Old 12-09-2023, 10:53 PM   #3
While I'd also simplify, technically, there isn't anything wrong with just plugging the pump intake. Definitely don't leave it unplugged.
NoHaveMSG (12-09-2023), Wally86 (12-13-2023)
Old 12-18-2023, 04:34 AM   #4
Theodorable
Manual Swap ECU need help ASAP
I’m damn near done with my manual swap. The question I have is do I have to reset the ECU if I’m using the same wiring harness’ it came with? So when I plug everything back will it just turn on and start?
ECU/ECM came out the same car as the wiring harness 2013’ and the trans same year 2013’ but different car. Would I need to reset? And if so do I have to tune it? Or does the reset make it so the transmission and ECU are synced together. If not do I use my OFT and tune and if so what tune and link for said tune?
Thank you!
Old 12-18-2023, 08:39 AM   #5
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Why the fuck do you have 2 threads AGAIN?
Reported.
The Following User Says Thank You to x808drifter For This Useful Post:
Wally86 (12-22-2023)
Old 12-18-2023, 02:31 PM   #6
Theodorable
Reported.
This is an entirely different thread…
Old 12-19-2023, 06:15 PM   #7
Sasquachulator
Pavement Grey
coulda just kept it all in the one thread.
I mean you have THREE threads with the exact same topic, from the same author, with the same car about the same swap.........just at different stages of said swap.
Old 12-19-2023, 06:51 PM   #8
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
Forum etiquette & skills are learned over time through much trial and error.
HKz is offline   Reply With Quote
The Following User Says Thank You to HKz For This Useful Post:
norcalpb (12-20-2023)
Old 12-20-2023, 12:12 AM   #9
Hopefully.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
HKz (12-20-2023), norcalpb (12-20-2023), pope (12-20-2023), Wally86 (12-22-2023)
Old 12-20-2023, 11:55 AM   #10
x808drifter
LMGTFY
So am I just smart? I have never posted more than one thread on the same thing on purpose in my life.
Or is it more like I think it is. You have to be a moron to think that this kind of shit is ok?
Old 12-20-2023, 12:21 PM   #11
I mean...
The Following 5 Users Say Thank You to Dadhawk For This Useful Post:
bcj (12-20-2023), pope (12-20-2023), RedReplicant (01-01-2024), Ultramaroon (12-20-2023), Wally86 (12-22-2023)
Old 12-20-2023, 01:41 PM   #12
It's the latter, 100%. Not moron, just self-centered. The same that writes "ASAP" as in "I'm more important. Help me now."
I look at thanks stats. People who don't thank, AND start concurrent threads, well... it tells a story.
Wally86 (12-22-2023), x808drifter (12-22-2023)
Old 12-20-2023, 05:45 PM   #13
HKz
Reformed
HKz's Avatar
Lol well I was being a bit facetious with my original comment but lots of people have tunnel vision with their life
The Following 2 Users Say Thank You to HKz For This Useful Post:
Ultramaroon (12-20-2023), x808drifter (12-22-2023)
Old 12-22-2023, 12:07 PM   #14
x808drifter
LMGTFY
$5 says he makes another thread. That'll make it an even 4.
Ultramaroon (12-23-2023)
How to: Manual Swap FRS/BRZ darthfrs DIY (Do-It-Yourself) Guides 15 12-06-2023 03:32 PM
Manual swap IsaiahW Engine, Exhaust, Transmission 3 10-10-2021 02:36 AM
how to swap manual to auto gt7877 Engine, Exhaust, Transmission 17 04-05-2020 05:56 PM
Is there any complications with doing a manual swap? juniorrr Engine, Exhaust, Transmission 32 07-18-2019 09:06 PM
Change your manual transmission fluid ASAP!!! Kostamojen Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 383 12-12-2016 10:29 AM
