Old 12-05-2023, 04:01 PM   #15
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by Tokay444 View Post
What do tight tolerances have to do with anything?
Tight tolerances means that the viscosity of the lubricant determines how well it flows through things like bearing clearances. So, in the old days, the tolerances were not tight and thicker oil was required. I believe this was attributed to the design limitations that existed prior to things like computerized design. Also keep in mind that a lot of those engine designs lasted for 40+ years.
In modern times, there has been a very high emphasis on increased efficiency and reliability. Tighter tolerances have been one of the many results of that focus.
So, that means that if you had bearing clearances of .030" before and now your bearing clearances are .009" then a lubricant that is too thick over spec is going to create problems getting through those spaces and therefore could cause premature failure due to a lack of sufficient lubrication.
Things like heat do increase viscosity so using a higher viscosity lubricant is one way to address a reduction in lubrication due to heat stress.
It is also debatable that going that route is a better approach than adding greater lubricant cooling capacity. Basically, the entire point of this thread.
Sorry to be so verbose. Maybe this should be the first response to the OP.
RT-BRZ is offline   Reply With Quote
Old 12-05-2023, 10:16 PM   #16
Tokay444
No it doesn’t. A tolerance is the allowable deviation of a part from its engineered nominal size.
Old 12-05-2023, 10:35 PM   #17
blah pedantic troll bait blah blah fucky fuck fuckery
menikmati (12-06-2023), RT-BRZ (12-06-2023), x808drifter (12-06-2023)
Old 12-06-2023, 06:06 AM   #18
RT-BRZ
RT-BRZ's Avatar
Context is everything.
Old 12-06-2023, 12:11 PM   #19
Tokay444
Nothing pedantic about it. Words have meanings and those meanings matter.
Tolerance=/=clearance. You can even have a VERY tight tolerance on your clearance, and still have a very large clearance.
Old 12-06-2023, 12:26 PM   #20
You knew damn well it was a misuse of the term before asking the question. It costs nothing to be nice. Your troll is weak and annoying.
...and old. Very old.
Old 12-06-2023, 12:30 PM   #21
Tokay444
Listen here Ultramoron, none of it involved you. You interjected yourself and want to play victim. Find the block button if you're really that sensitive. This is the internet.
Old 12-06-2023, 12:44 PM   #22
RT-BRZ
RT-BRZ's Avatar
OK, to expand on "Context is everything".
I responded to the original sentiment about tolerances. In the automotive world people frequently talk about clearances and tolerances synonymously. While you may well be technically correct that those two things are independent and shouldn't be confused, the context of the point was that modern engines run tighter tolerances which I took as tighter clearances. Right or wrong, that kind of language is frequently used in the automotive world. Very much like interchanging engines with motors for cars/trucks. You know full well what any of this meant. Because of that you got labeled a pedantic troll. I didn't do that. I just made a simple reply.
By the logic you applied, you are certainly being pedantic. By the attitude and persistence you are displaying, you are certainly being a troll.
There really isn't any need for either thing. I'm sure we can all get along.
The Following 3 Users Say Thank You to RT-BRZ For This Useful Post:
autoracer86 (12-06-2023), menikmati (12-06-2023), x808drifter (12-07-2023)
Old 12-06-2023, 12:46 PM   #23
I'm a special snowflake just for you.
RT-BRZ (12-06-2023)
Old 12-06-2023, 12:56 PM   #24
It's his standard schtick. I just got tired of it this time.
autoracer86 (12-07-2023), RT-BRZ (12-06-2023)
Old 12-06-2023, 07:10 PM   #25
Tokay444
More cry.
Old 12-07-2023, 02:39 PM   #26
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
I think it's pretty obvious he means "clearances" and not "tolerances"
I'm not sure how any of this added value to the discussion.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
The Following 4 Users Say Thank You to GrandSport For This Useful Post:
menikmati (12-07-2023), RT-BRZ (12-07-2023), Ultramaroon (12-08-2023), x808drifter (12-07-2023)
Old 12-07-2023, 04:32 PM   #27
Tokay444
People should say what they mean, otherwise it looks like they have no idea what they're talking about.
Old 12-07-2023, 04:52 PM   #28
RT-BRZ
RT-BRZ's Avatar
How do you survive on the internet?
menikmati (12-07-2023), Ultramaroon (12-07-2023), x808drifter (12-07-2023)
Best track hood for cooling (coil overheating issue) GrandSport Tracking / Autocross / HPDE / Drifting 54 01-07-2024 06:43 PM
Track Car Weight Lunatic Tracking / Autocross / HPDE / Drifting 83 03-15-2021 12:35 AM
Track car weight reduction Irace86 BRZ First-Gen (2012+) — General Topics 17 06-11-2016 05:21 PM
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) glamcem Tracking / Autocross / HPDE / Drifting 21 07-01-2014 11:38 AM
NPA: APR Carbon Fiber Brake Cooling Kit with Ducts - A must for track days 86_Insider Brakes, Suspension, Chassis 1 09-26-2013 01:39 AM
