Old 11-19-2023, 08:43 PM   #1
FrickingReallySlow
Drives: 2015 FR-S
Trunk to trunk-lid gap, rain water leakage from welds?
I've been trying to tackle my water pooling in the trunk even AFTER getting new taillight gaskets. I think my car may have been in a rear end wreck that wasn't reported based on the finding below. Would appreciate any help from others to compare what your trunk looks like.
First 2 pictures are from INSIDE the trunk looking up, the two corners closest to the rear wind shield (3rd picture for reference not my car) I see a big gap where light is coming through on both sides. I'm assuming this shouldn't be happening and there should be a gap right? As I'm spraying water from the outside to see where the water is leaking in I see some smalls drops but not much even with this gap. Is this normal?
Then I look at the rear skirt to the floor pan weld (4th and 5th pic) in the spare tire area and I see water pool from the weld area on BOTH the left side and right side of the spare tire. What is that beige stuff anyway? also should it be beige or does that indicate that its a body repair
@Opie maybe you're more familiar with body work
FrickingReallySlow is offline   Reply With Quote
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
humfrz (11-20-2023)
Old 11-19-2023, 08:52 PM   #2
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
The beige stuff is seam sealer, that's normal. looks factory, sheet metal also looks fine.
But no, that trunk isn't sealing at all. looking like that from the inside, that trunk lid should be looking janky as fuk from the outside... From the other pics nothing seems bent out of shape. Look at the latch and hinge areas with bent pieces or dremeled out holes and such.
The Following 2 Users Say Thank You to RZNT4R For This Useful Post:
Opie (11-20-2023), strat61caster (01-06-2024)
Old 11-20-2023, 12:52 AM   #3
I checked with Bubba and he says to cover the edges of the inside of the lid with light oil and coat the trunk gasket with silicone. Place a strong light above the trunk. Then, with the trunk lid closed, crawl into the trunk space through the back seat and completely fill the gaps where you see light with silicone calking.
Allow to set for a couple of days, then open the trunk and spray paint the silicone stuffing with flat black paint.
FrickingReallySlow (11-20-2023)
Old 11-20-2023, 11:51 AM   #4
FrickingReallySlow
Drives: 2015 FR-S
love Bubba's ideas! will do. The trunk lid on the outside actually looks fine and don't see anything out of the ordinary with the quarter panel. it seems like the the "trunk opening metal outline" where the black trunk gasket goes over is janky if that makes any sense
humfrz (11-20-2023)
Old 11-20-2023, 05:43 PM   #5
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Both of those area look odd to me....where the orange arrow is pointing the paint appears cracked. and the entire edge the weather strip attaches to looks bent and out of shape to me (in the red outline). But it's hard to tell with the pics. Definitly something is amiss as you shouldn't be able to see light.
The beige stuff is normal....
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
FrickingReallySlow (11-22-2023)
Old 01-03-2024, 08:29 PM   #6
FrickingReallySlow
Drives: 2015 FR-S
So replaced the taillight gaskets and sprayed the back of the car with a water hose to capture with videos where the water is getting in and it looks like the taillight pocket welds. Area where there is a hole on a metal bracket above the tail-light. I know that both quarter panels have been replaced on this vehicle due to minor damage and fixed through insurance. Wondering what I can use to seal that area? JB weld? gasket maker? Below are the pictures, I used some shop towels to indicate where the leak starts.
In the 2nd picture, water is also coming in from the weatherstrip. Left arrow points to where there a big bead of water running down the inside of the trunk
Old 01-03-2024, 08:33 PM   #7
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Originally Posted by FrickingReallySlow View Post
So I capture with videos where the water is getting it and it looks like the taillight pocket welds where there is a hole on a metal bracket above the tail-light. I know that both quarter panels have been replaced on this vehicle due to minor damage and fixed through insurance. Wondering what I can use to seal that area? JB weld? gasket maker? Below are the pictures, I used some shop towels to indicate where the leak starts.
3M Black Super Weatherstrip Adhesive. It's a little goopy though.
Silicone or other RTV would work too. Just need to get in there with finger and make sure it gets into whatever seam you're trying to tidy up.
I wouldn't use a 2-part epoxy or other structural adhesive. Prefer something that can flex and not break/crack-up over time to keep a long lasting seal.
If you want to test and make sure your repair works first with something that's easily reversible, start off with some butyl rubber tape (same stuff that's used on door vapor barrier sheets). I don't recommend it long term for this application cause it's sticky and without a cover layer it will get dirty and dry up fast. It can be a bit messy to work, but cleans up easily with isopropyl alcohol. Duct tape might even work
EndlessAzure is offline   Reply With Quote
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post:
FrickingReallySlow (01-03-2024), x808drifter (01-04-2024)
Old 01-05-2024, 10:53 AM   #8
Opie
Opie's Avatar
Use a body panel seam sealer on both sides of the seam to prevent rust. Like what the factory uses.
https://www.amazon.com/550-Permanent...835805362&th=1
Who did the quarter panel replacement? Seems like a poor repair....
EndlessAzure (07-04-2024)
Old 01-07-2024, 03:56 PM   #9
FrickingReallySlow
Drives: 2015 FR-S
Thanks for all the great feedback, took it back to the original repair shop that did my left quarter panel ( eventhough both quarter panels taillight pockets are leaking) and got them to both knock "up" the metal trunk weatherstrip gap so it meets the trunk now AND use that rubber sealer on the outside and inside. They were really nice diagnosing and trying to find all the leaks for 2 hours and paid them $50 even though they weren't responsible for most of them. Also the yellow grommets in the pictures that hold the bumper were leaking some water and they completely cover it up with rubber sealer lol. No more leaks! Last thing left for me to do is reseal the weatherstrip and use some touchup paint
humfrz (01-13-2024)
Water Leak in Trunk ThatGuyWithAnFRS Issues | Warranty | Recalls / TSB 13 03-29-2023 05:35 PM
Post-accident/trunk water/trunk humming lumbeardjack Issues | Warranty | Recalls / TSB 1 08-04-2020 10:06 PM
Water In Trunk Stevieray Scion FR-S / Toyota 86 GT86 General Forum 2 11-24-2013 08:42 PM
Water in trunk anyone? frsinpa Issues | Warranty | Recalls / TSB 8 11-06-2013 10:58 PM
Water in trunk Spencer BRZ First-Gen (2012+) — General Topics 14 03-15-2013 10:17 PM
