Old 05-22-2023, 04:27 PM   #15
ka-t_240
There is a FA24 short block swap running in MN. Car is using FA20 heads and ECU. Made almost identical HP to a stock GR86 on the same dyno.
I believe the car was on track this weekend too.
ka-t_240 is offline   Reply With Quote
Old 05-23-2023, 01:46 AM   #16
tomm.brz
Drives: brz 2017 hksv2
Still i m not understanding how doable is this swap, fa24 short block into restyling fa20 with fa20 heads?
Did someone here figure out what s really needed?
Old 05-23-2023, 10:36 AM   #17
ka-t_240
Yes - I am sure he wants to do more testing before posting it all up. But, its a shop in MN.
Old 05-23-2023, 10:48 AM   #18
tomm.brz
would be nice to have some details about how to make it work(:
Old 05-23-2023, 11:44 AM   #19
RedReplicant
Drives: None
RSMotors, if you want to creep their FB
RedReplicant is offline   Reply With Quote
Old 05-23-2023, 04:48 PM   #20
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
My concerns would be valve clearance. Are the valves the same diameter and in the same position and angle on both motors? The piston crowns are different between the two motors. I could imagine the valves being larger and maybe further apart on the FA24.
Besides that, the larger bore sleeve might partially block the coolant jackets on the FA20 heads.
Old 05-23-2023, 05:10 PM   #21
tomm.brz
pistons hit the heads, yea but i dont what they did to fix that
Old 05-23-2023, 05:58 PM   #22
RedReplicant
Drives: None
I came across some comments by Ronnie the other day about it, he said that you just gotta get creative and that he used FA20 heads. Can't find them now that I'm looking though.
Old 05-23-2023, 10:21 PM   #23
Sevs753
Sevs753's Avatar
Drives: BRZ, Canyon
The crank position sensor was asked about on their post but they were a big cagey and just said "they made it work". but it was done with a stock 2013 ECU so thats hopeful. We just have to figure out what they did.
Sevs753 is offline   Reply With Quote
Old 05-24-2023, 09:51 AM   #24
ka-t_240
That's why I didn't wanna say who it was, I'm guessing he is going to put something more formal together eventually on the process. But have seen pictures of them doing testing on clearances/etc for a while.
Old 05-24-2023, 11:24 AM   #25
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Probably just stuck the 13' sensor on with a modified mount with the 13' reluctor wheel.
Old 06-23-2023, 11:45 PM   #26
ka-t_240
I believe RS has for sure 3 cars running with FA24 swaps, and another shop(ASM) did one in WI.
I believe one of the FA24 cars will be at Gridlife this weekend running in club TR
Old 10-20-2023, 10:16 AM   #27
Celigts
Celigts's Avatar
Drives: 2014 Toyota FRS
Just remembered I posted this a while ago. Who’s got a guide? I want to pull the trigger on buying a GR86 engine. 😊
Celigts is offline   Reply With Quote
Old 10-21-2023, 02:15 PM   #28
T-Steve
Drives: 2014 BRZ
Same here - the price on used FA24s seem to have cooled off some and I'm interested in swapping to my '14.
I found this guide on NASIOC. It's specific to the FA24DIT, but there is useful information there.
https://docs.google.com/document/d/1...qrl9R-vJA/edit
I'm following this outfit in Japan. There are some more clues there.
Mostly I am looking for information on the FA24 cam sensors, crank position sensor, injectors, and a few other sensors (temp, pressure, etc.) and interfacing them to the FA20 ECU.
T-Steve is offline   Reply With Quote
First autox in my GR86 justinco Tracking / Autocross / HPDE / Drifting 10 05-30-2022 07:52 PM
Why BRZ Over GR86? Lelandjt BRZ Second-Gen (2022+) — General Topics 45 12-26-2021 08:41 AM
TOM'S GR86 Catalogue DeeAich GR86 General Topics (2nd Gen 2022+ Toyota 86) 6 11-15-2021 12:14 AM
GR86 PCD teppey GR86 General Topics (2nd Gen 2022+ Toyota 86) 23 07-29-2021 11:12 PM
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport Blighty GR86 General Topics (2nd Gen 2022+ Toyota 86) 28 07-18-2021 03:38 PM
