Old 10-15-2023, 09:42 PM   #1
FrickingReallySlow
Drives: 2015 FR-S
Collapsed PCV outlet hose to catch can
I installed a catch can from the earlier this year and just noticed that the outlet hose that goes from the back of the block to the catch can has pretty much collapsed (see pictures). This sort of intakes that somehow there vacuum inside the block?! or the heat somehow got to it? The hose from my catch can to the breather port of my Edlebrock SC is fine.
I bought the braided reinforced vacuum hoses at the same time and just cut it into 2 pieces. DID I BUY THE WRONG KIND?! I checked the catch can and there a little bit of oil as expected. When I installed the catch can I removed the bronze filter and replaced with steel scrubbing pad to allow better flow. I don't feel any issues or CEL but something is definitely wrong if the PVC hose collapsed. Previously without the catch can the hose provided by edlebrock worked perfectly.
Let me know if there a specific vacuum hose I need that for this application many thanks
FrickingReallySlow is offline   Reply With Quote
Old 10-15-2023, 10:36 PM   #2
new2subaru
Weight Weenie
Drives: 15 FR-S
I could be wrong but the looks like GP air hose to me. I can make out W P which stands for working pressure.
https://www.gates.com/us/en/fluid-po...l-purpose.html
The Following User Says Thank You to new2subaru For This Useful Post:
FrickingReallySlow (10-16-2023)
Old 10-16-2023, 11:43 AM   #3
FrickingReallySlow
Drives: 2015 FR-S
Thanks for the link looks like it is an Air hose the WP was 300PSI from your data sheet temp was only up to 200F
Old 10-17-2023, 06:19 AM   #4
new2subaru
Weight Weenie
Drives: 15 FR-S
You're going to replace that with PCV hose?
Old 10-20-2023, 01:23 AM   #5
FrickingReallySlow
Drives: 2015 FR-S
Yeah since I never had a problem with either the OEM PCV hose or the one from the edlebrock SC kit I'm guessing PCV hose has a higher temp rating. Are you suggesting something else?
Old 10-20-2023, 07:14 PM   #6
Grady
Grady's Avatar
I would get silicone vacuum tubing.
The Following User Says Thank You to Grady For This Useful Post:
FrickingReallySlow (10-22-2023)
Old 10-21-2023, 09:04 AM   #7
new2subaru
Weight Weenie
Drives: 15 FR-S
I would imagine the GP hose would collapse under vacuum.
I haven't looked specifically for PCV hose/Vacuum hose.
Dual Radium catch can petcock hose routing 86TOYO2k17 Engine, Exhaust, Transmission 1 01-01-2019 03:50 PM
[FS] Mishimoto Oil Catch Can Silicone Hose Laz84 Engine, Exhaust, Bolt-Ons 1 12-20-2018 12:21 PM
FS: OFT/K&N Filter/Perrin Intake Hose/Nameless Cam Plate/Mishimoto Catch Can The Tengu Engine, Exhaust, Bolt-Ons 19 03-02-2016 12:47 AM
Fuel pump outlet hose coming lose phastafrican Issues | Warranty | Recalls / TSB 7 11-04-2014 06:38 PM
where to plug the oil catch can hose... :S dompower Engine, Exhaust, Transmission 29 11-14-2012 01:30 PM
