#4887 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
The ABS and and ECM modules are separate so I wouldn't expect them to be related unless you have a a tear in the harness somewhere and it's grounding out. Have you ever replaced your direct injectors or had them cleaned?
#4888 | |
Drives: 2017 BRZ Limited, White
I did an electrical check a while ago and didn't find a problem. I'm not convinced that the DTCs have anything to do with what's really going on (except perhaps the "Rich" one). |
#4889 |
UPDATE: Cleaned the MAF, and let it dry overnight. For about 90 minutes the car was even WORSE than before... the next day though, it was fine. So, I've had 2 days of perfect driving.
Fingers crossed it stays that way. |
| The Following User Says Thank You to xeroshoes For This Useful Post: | GPhilly (08-30-2023) |
#4890 |
Drives: X5 35d, D90, CX-5 Turbo
Anyone know this (specific) Car/Owner/History?
https://www.preownedexpress.com/used...ZNAA17F9711906 It is modified (Edelbrock SC, suspension, exhaust, wheels & Tires), so thinking someone here may know of it, and its history? DM me if you prefer, looking for the 411 on mods and history if anyone knows the car, thanks.. ![]()
~Scott T.
'95 NAS D-90 ST '13 BMW X5 35d '22 CX-5 Turbo '?? 86 one day soon? |
#4891 |
Drives: Toyota 86
Can anyone help? I feel like I'm going crazy here. I have an '17 with Edelbrock SC, UEL header, DT flex fuel kit and DT tune.
For 4 months the car has been amazing. 0 issues... But now I got the P0507 CEL. Cleaned the throttle body and still got it... so I tried the used one sitting on the shelf and still the CEL came right back on. well I went deeper into this and bought a new one. ( there's a chance both used ones could be bad right?? LOL) I still got the same code within 10 miles of driving. I've rest the throttle learn with all 3 throttle body's. checked the wiring harness with a Multi reader... everything came back the same. nothing seems to fix it! I did see on here people had issues the vacuum leaks so I hose clamped every line and tried an old MAF sensor. nothing seems to change the revving up at stop lights to 2k for a brief second with 0%TPS and setting the CEL. |
#4892 | |
The Stig's African Cousin
Drives: 2014 wrb brz
Did you check the bypass valve on the supercharger? Check to see if you have the updated valve the old ones failed regularly causing a vacuum leak.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386 Flickr: brandonblt567 |
#4893 | |
Drives: Toyota 86
I just ordered a new one tonight from Edelbrock, thanks for the reply! hopefully this helps someone if they have these issues in the future. |
| The Following User Says Thank You to Dann_86 For This Useful Post: | brandonblt2 (10-05-2023) |
#4894 |
Drives: BRZ ts
Does anyone with a 2020 have a carb tune from edelbrock?
#4895 |
Drives: 2015 BRZ, 2005 STI
Requesting some assistance and guidance for rough idling, surging power with low-throttle application (I hate 1st gear from a stop) and lagging/hesitation.
Using a Delicious tune way back in 2016 and went through a couple of revisions from Zach at the time and felt that the tune was "good enough," but then the car sat during the pandemic and I've been trying to get all the jankiness sorted out. Recently, I have been experiencing poor idle. When applying a small amount (~5%) of throttle to get the RPMs up to 1.5k, the RPMs would jump to 1.5k, down to 1.1k, up to 1.5k, down to 1.3k and then finally settle at 1.5k after oscillating for a bit. On some cold starts, the RPMs will spike to 2k, down to 500 RPM (on the verge of stalling, sometimes it does stall) and does this back and forth with absolutely no throttle input. Here's a short datalog, I notice that AFRs are bouncing around and STFT is maxed out at -29.7 at times. https://datazap.me/u/menikmati/10162...0&data=7-11-47 My kit came with the old, 3-screw version of the bypass actuator valve. I pinched the vacuum line coming off the back of the SC into the bypass actuator valve and the valve closes. I did not hear any hissing, but does this indicate a small leak? I plan on attaching a vacuum pump on the line and see if it leaks under vacuum, which I assume it will. I have the newer 2-screw valve coming in. From combing through this thread, I've compiled a list of places to look at:
I reached out to Delicious with some logs (including the one in this post) and welcome any insight, I really want this car to be more enjoyable to drive. Last edited by menikmati; 10-18-2023 at 02:59 PM. |
#4896 |
Drives: brz 2017 hksv2
try to change MAP sensor
#4897 |
I will add this to the list. I took a picture of the sensor and the part number is 0261230042. I'm having difficulty finding this exact part, but PartsBOS says it has been replaced by 0261230283. I'm not familiar with the site so I don't feel like I can trust it 100%.
Looks like I can find 0261230283 at Amazon for around $15....which sounds suspiciously cheap? |
#4898 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
| The Following 2 Users Say Thank You to BirdTRD For This Useful Post: | brandonblt2 (10-19-2023), menikmati (10-19-2023) |
#4899 | |
https://www.autohausaz.com/pn/0261230042 |
| The Following User Says Thank You to B T For This Useful Post: | menikmati (10-19-2023) |
#4900 | |
I called Bosch to verify if PN 0261230283 was a direct replacement and it is not. The updated PN is 0261230302 in case anyone is unable to get 0261230042. |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
