Old 08-15-2023, 09:46 AM   #4887
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Originally Posted by xeroshoes View Post
ENGINE:
P0172 - System Too Rich Bank 1
P050A - Cold Start Idle Air Control System Performance
P117B - Direct Injector Fuel Performance Does Not Come On DTC
ANTILOCK BRAKING SYSTEM:
C1201
The ABS and and ECM modules are separate so I wouldn't expect them to be related unless you have a a tear in the harness somewhere and it's grounding out. Have you ever replaced your direct injectors or had them cleaned?
B T is offline   Reply With Quote
Old 08-15-2023, 11:35 AM   #4888
xeroshoes
Drives: 2017 BRZ Limited, White
Originally Posted by B T View Post
The ABS and ECM modules are separate so I wouldn't expect them to be related unless you have a tear in the harness somewhere and it's grounding out. Have you ever replaced your direct injectors or had them cleaned?
Haven't had the DIs cleaned or replaced. I can look into that.
I did an electrical check a while ago and didn't find a problem.
I'm not convinced that the DTCs have anything to do with what's really going on (except perhaps the "Rich" one).
xeroshoes is offline   Reply With Quote
Old 08-21-2023, 11:24 AM   #4889
xeroshoes
UPDATE: Cleaned the MAF, and let it dry overnight. For about 90 minutes the car was even WORSE than before... the next day though, it was fine. So, I've had 2 days of perfect driving.
Fingers crossed it stays that way.
The Following User Says Thank You to xeroshoes For This Useful Post:
GPhilly (08-30-2023)
Old 08-29-2023, 11:09 PM   #4890
LRNAD90
Drives: X5 35d, D90, CX-5 Turbo
Anyone know this (specific) Car/Owner/History?
https://www.preownedexpress.com/used...ZNAA17F9711906
It is modified (Edelbrock SC, suspension, exhaust, wheels & Tires), so thinking someone here may know of it, and its history?
DM me if you prefer, looking for the 411 on mods and history if anyone knows the car, thanks..
~Scott T.
'95 NAS D-90 ST
'13 BMW X5 35d
'22 CX-5 Turbo
'?? 86 one day soon?
LRNAD90 is offline   Reply With Quote
Old 09-26-2023, 09:04 PM   #4891
Dann_86
Drives: Toyota 86
Can anyone help? I feel like I'm going crazy here. I have an '17 with Edelbrock SC, UEL header, DT flex fuel kit and DT tune.
For 4 months the car has been amazing. 0 issues... But now I got the P0507 CEL. Cleaned the throttle body and still got it... so I tried the used one sitting on the shelf and still the CEL came right back on. well I went deeper into this and bought a new one. ( there's a chance both used ones could be bad right?? LOL) I still got the same code within 10 miles of driving. I've rest the throttle learn with all 3 throttle body's. checked the wiring harness with a Multi reader... everything came back the same. nothing seems to fix it!
I did see on here people had issues the vacuum leaks so I hose clamped every line and tried an old MAF sensor. nothing seems to change the revving up at stop lights to 2k for a brief second with 0%TPS and setting the CEL.
Dann_86 is offline   Reply With Quote
Old 10-04-2023, 12:49 PM   #4892
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
Did you check the bypass valve on the supercharger? Check to see if you have the updated valve the old ones failed regularly causing a vacuum leak.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 10-04-2023, 08:45 PM   #4893
Dann_86
Drives: Toyota 86
dude you are spot on! I was just logging on to say I figured this out. I pinched the bypass valve line with a vice grip and its idiling smoothly again. I made it 2 days with no CEL.
I just ordered a new one tonight from Edelbrock, thanks for the reply! hopefully this helps someone if they have these issues in the future.
The Following User Says Thank You to Dann_86 For This Useful Post:
brandonblt2 (10-05-2023)
Old 10-05-2023, 02:08 AM   #4894
dpfarr
Drives: BRZ ts
Does anyone with a 2020 have a carb tune from edelbrock?
dpfarr is offline   Reply With Quote
Old 10-18-2023, 12:39 PM   #4895
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
Requesting some assistance and guidance for rough idling, surging power with low-throttle application (I hate 1st gear from a stop) and lagging/hesitation.
Using a Delicious tune way back in 2016 and went through a couple of revisions from Zach at the time and felt that the tune was "good enough," but then the car sat during the pandemic and I've been trying to get all the jankiness sorted out.
Recently, I have been experiencing poor idle. When applying a small amount (~5%) of throttle to get the RPMs up to 1.5k, the RPMs would jump to 1.5k, down to 1.1k, up to 1.5k, down to 1.3k and then finally settle at 1.5k after oscillating for a bit.
On some cold starts, the RPMs will spike to 2k, down to 500 RPM (on the verge of stalling, sometimes it does stall) and does this back and forth with absolutely no throttle input.
Here's a short datalog, I notice that AFRs are bouncing around and STFT is maxed out at -29.7 at times.
https://datazap.me/u/menikmati/10162...0&data=7-11-47
My kit came with the old, 3-screw version of the bypass actuator valve. I pinched the vacuum line coming off the back of the SC into the bypass actuator valve and the valve closes. I did not hear any hissing, but does this indicate a small leak? I plan on attaching a vacuum pump on the line and see if it leaks under vacuum, which I assume it will. I have the newer 2-screw valve coming in.
From combing through this thread, I've compiled a list of places to look at:
  1. MAF sensor - Clean sensor and inspect o-ring
  2. Air filter - I think it came with the oiled filter, should I replace it with the updated dry filter, or is degreasing/cleaning the old one sufficient?
  3. Intake manifold gaskets - Inspect for tears
  4. Bypass actuator valve - Perform vacuum test and replace
  5. Upstream oxygen sensor - Inspect
  6. MAP sensor - Replace
I reached out to Delicious with some logs (including the one in this post) and welcome any insight, I really want this car to be more enjoyable to drive.
menikmati is offline   Reply With Quote
Old 10-18-2023, 01:32 PM   #4896
tomm.brz
Drives: brz 2017 hksv2
try to change MAP sensor
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
menikmati (10-18-2023), Teseo (10-18-2023)
Old 10-18-2023, 02:52 PM   #4897
menikmati
I will add this to the list. I took a picture of the sensor and the part number is 0261230042. I'm having difficulty finding this exact part, but PartsBOS says it has been replaced by 0261230283. I'm not familiar with the site so I don't feel like I can trust it 100%.
Looks like I can find 0261230283 at Amazon for around $15....which sounds suspiciously cheap?
Old 10-19-2023, 06:57 AM   #4898
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
I wouldn't spend any more time, energy or money until that bypass valve is replaced. They are notorious for leaking, especially the old style.
BirdTRD is offline   Reply With Quote
The Following 2 Users Say Thank You to BirdTRD For This Useful Post:
brandonblt2 (10-19-2023), menikmati (10-19-2023)
Old 10-19-2023, 02:17 PM   #4899
B T
That is indeed suspiciously cheap but they go on sale here and there. I would ensure its a Bosch part and not some knockoff. AutoHausAZ currently has one on sale for $27.99 plus shipping. That's in line with what I've been paying for replacements.
https://www.autohausaz.com/pn/0261230042
The Following User Says Thank You to B T For This Useful Post:
Old 10-19-2023, 03:01 PM   #4900
menikmati
Thanks for the link.
I called Bosch to verify if PN 0261230283 was a direct replacement and it is not. The updated PN is 0261230302 in case anyone is unable to get 0261230042.
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
