Drives: 2012 Toyota 86 GT
Car acting like battery disconnected after parking
Hey everyone, I had an extremely odd thing happen to my '12 86 today.
I pulled up into a car park, got out and It wouldn't lock from the key remote. It also wouldn't unlock/flash indicators etc.i just thought the key was dead - but the little red light in it was turning in? So I then tried to the lock switch by the window switches, and it didn't work. So I thought maybe the ignition had to be on for the switch to work, and to my surprise nothing turned on when I turned the key, no dash lights - nothing. But then... All of a sudden everything came back on? Like it was just acting up for some reason? All the symptoms of a battery terminal being disconnected are present - the radio memory reset for example, and the throttle calibration has been forgotten/needs to relearn again. It also now seems super inconsistent with the throttle - it stalled almost every time returning to idle after releasing the throttle, but would drive 100% normally otherwise. I have disconnected the battery many times and it would never stall itself after the throttle is trying to re-learn, although I admit maybe I didn't give it enough time before I started driving. I of course checked the battery and nothing seems out of place. The terminals are tight, there are no obvious loose wires anywhere or anything like that. I have no idea what went wrong or where to start looking for issues, anybody hear of anything like this before? How could the electronics like just disconnect and reconnect themselves like that? |
#2 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
After a decade or so, it's possible for corrosion to be a problem in various electrical connectors.
Under the hood, dash, seats, trunk - there's tons of them. Chasing which one can be frustrating. I've had it on a motorcycle where they route through the headlight to the ignition key. Usually re-plugging works short term, but doesn't keep the existing corrosion from progressing again. Giving the pins/plugs a light coating of di-electric grease will slow it down by keeping free ions in the air isolated. The ECU/BCU/TCU modules would be the places to start. No guarantees. Some are convinced it could be juju too.
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | euniqe (09-24-2023) |
#3 |
ProCrastinationConsultant
time to start checking fuses, as well as any modifications made to the car. especially the fuses on the top of the battery.
#4 |
Have you taken off and cleaned the battery terminals?
Have you load tested the battery? |
#5 | |
I haven't taken them off, no. Nor have I load tested it, but the engine starts completely normally and voltage levels both 12v and 14v are all normal. I'll try that though if nothing else comes up, but I don't feel that they'd be 'bad' enough to cause this issue. |
#6 | |
| The Following User Says Thank You to humfrz For This Useful Post: | blsfrs (09-24-2023) |
| Battery disconnected for several months now power locks don't work. | irax | Issues | Warranty | Recalls / TSB | 4 | 10-17-2021 04:11 PM |
| 2013 FRS wont start unless battery is disconnected first | KN0W | Electronics | Audio | NAV | Infotainment | 5 | 07-21-2021 09:44 AM |
| Disconnected battery with tune, throttle response weakened. | azynneo | Software Tuning | 8 | 01-16-2016 06:57 AM |
| Battery Acting Strange | mrxchris | Issues | Warranty | Recalls / TSB | 8 | 05-07-2015 10:27 PM |
| battery disconnected/reconnected -- runs like shtako | jonbonazza | Issues | Warranty | Recalls / TSB | 2 | 06-19-2013 10:56 AM |
