#15 |
I work for NASA National and can help with rules! Let me know!
#16 | |
Drives: 2015 FRS
The only sphericals I use in the front control arm are the big front lower that locates the arm and deflects the most under load. The other is OE. It adds a ton of feel and precision to the steering. For the rear, I have SPC rear lower control arms, and SPC toe links (with lockout plates), and STI trailing arms (with sealed OE bearing), and they work beautifully, hold alignment like a beast, and are cheap if you need to replace them. I recently had somebody hit my rear wheel in the rain and it broke my toe link. $100 on amazon next day delivery.
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos |
| The Following User Says Thank You to prandelia For This Useful Post: | Hades (10-16-2020) |
#17 | |
-0.7 is a massive hit to take.
Kyle H. - #89 STX
| The Following User Says Thank You to M0nk3y For This Useful Post: | Hades (10-16-2020) |
#18 | |
Drives: 2015 FRS
Wait a minute, the FRS takes an A-arm penalty? Why? It has Mcpherson strut front, and multi-link rear (not A-Arm). And the reality is virtually every car these days is a trailing/multi-link rear, so the only advantage (if you can even call it that) is if you have A-arm front suspension, which is indeed more rare. A-Arm front is the only real advantage over Mcpherson, because typically you can fit more tire/wheel, and you gain camber through motion range....the rear is no advantage. That's a f-ing ridiculous rule, it literally makes zero sense if I am understanding that correctly....
'15 FRS - GLTC spec
#19 | ||
Pretty much the only car that doesn't get hit is the E36. Yet, an S2000 takes the same penalty and has A-Arm up front, so they benefit.
Kyle H. - #89 STX
#20 | |
Drives: 2015 FRS
Not to get off topic, but you should come run a weekend with GLTC next season.
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos Last edited by prandelia; 10-19-2020 at 08:14 AM. |
| The Following User Says Thank You to prandelia For This Useful Post: | Pat (10-17-2020) |
#21 | |
It looks like youre in Ohio. Have you spoken to your ST group leader there? or have you brought it up with the Greg that National ST director? I handle all of the Marketing and Contingencies for everyone so I don't have too much influence on rules, but I can definitely help point in the right direction |
#22 | ||
Still a summer car for me/no cage or anything Quote:
Not looking for ME classing, just trying to understand the intent at why some point penalties are there
Kyle H. - #89 STX
#23 |
Drives: 2022 GR86 (was 2013 BRZ)
Prandelia,
Where did you get the spherical for the front lower control arm (the big one)? Thanks. Great info!
#24 |
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Sorry to dig up an old thread, but this thread was super helpful. I was reading the rules about "wishbone" and thought, surely not. But yup... about as silly as bigger brakes being a penalty when you have to run street tires.
Anyway I'm thinking of getting into NASA TT5. Any idea what a bolt on (intake, EL headers, catback, tune, 93octane) 2014 will make for average hp under the rules? Roughly? Also, do we have a preferred tire? Or at least a class (+1.6 or +1.0 category). Thanks!
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. |
#25 |
Drives: None
NASA AirTable will be a good way to get an idea, for some reason (I assume sponsor agreements) they don't list what tire brand you chose on on the sheet.
https://airtable.com/appERehieevbzLk...gWtC3AQ0QAJPI0 You'll likely end up in the mid 170s average WHP wise. The PP Brembos are your no-points BBK since they were available from the factory. Tire will probably lead to arguments, but the fastest laps in ST5 and TT5 at Nationals were done on an RC1. Taking the points for an A052/CRS/etc might be worth it but why bother given Maxxis contingency. I am curious what rules will change for 2024, I pitted with Greg earlier this year for a two day event and asked him about some stuff. He sold his race setup off and was retiring from his real job to be a dive instructor, so he will be based out of Florida instead of living in Arizona and mostly sticking to SoCal events.
#26 | |
At the track
Drives: '14 FRS - Former e92 M3
https://drive.google.com/file/d/1LF_...ujfFPvy7A/view https://drive.google.com/file/d/1dB4...d3Svsgw0J/view I know there has been success with the Maxxis tires, but I still lean towards the Hoosier being the better choice although it can be track dependent. All of the current Texas Region track records to my knowledge are on R7's, I can confirm the Eagles Canyon record was since it was my car ![]() Grassroots motorsport Tire Table is probably the best place to decide what tire you might want in the 1.0-1.6 categories: https://grassrootsmotorsports.com/ar...-buyers-guide/ The airtable is a great place to pickup trends on what people are taking on points. BUT, take power numbers with a little grain of salt as some cars may be flat tuned, have engine swaps, different fuel, etc and those things arent obvious on the forms. You can get a ballpark, but at the end of the day you own dyno is going to determine your final weight and points. TT5 in TX region is a great place right now though, LOTS of opportunity to win tires with the number of participants right now.
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
| The Following 2 Users Say Thank You to Kelse92 For This Useful Post: | GrandSport (09-19-2023) |
#27 |
Drives: None
Hehe, see, Hoosier vs Maxxis is region and car dependent. I mostly think they work for me since I have the K24 power.
I've set five NASA AZ TT5 records on the RC1, as well as another two NASA TT5 SoCal records on them. TT5 is where it is at.
#28 |
Drives: Tacoma
Engine swaps ruin NASA and SCCA....Change my mind
| The Following User Says Thank You to justnutsandbolts For This Useful Post: | RT-BRZ (10-12-2023) |
| FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | Engine, Exhaust, Bolt-Ons | 8 | 10-30-2015 06:36 AM |
| Why a balanced setup is better than a "understeery" setup. | CSG Mike | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 52 | 07-01-2015 04:36 PM |
| KW V3 Setup | Magiclow | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 03-21-2015 03:29 AM |
| FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | NY / NJ / CT / PA | 0 | 10-20-2014 10:48 AM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
