Drives: 2013 Scion FRS
NASA TT5/ST5 setup
I see most are running wings with a lower average whp number. I wonder if shooting for a higher average whp and running without the aero would be better (due to the point disadvantage). ~190whp average should be doable with long tube headers + e85.
Has anybody tested the setups or have any insight here? Also, does anybody know if toe arms/endlinks cause a point hit? I think swapping out LCAs are a no-no, which is unfortunate, but I'm wondering what else can be swapped out in the suspension without taking point hits since we need more adjustability from factory. EDIT: Actually, after doing some quick calculating I was a little off the mark... it seems we would need ~2750 min comp weight to max out p/w with 190 avg. whp. Probably not going to happen without more serious gutting. I wonder if somebody could get a higher average whp with ace headers or something
It'll depend on the venue and driver skill/balls!
What Mike said.
Personally, for me, tracks like NCM, Mid-Ohio, Pitt Race all benefit from having a rear wing. I saw substantial time drop from no-wing to wing testing. Rear end stability being the biggest net benefit. Gingerman on the other hand is kind of meh, everything is "low speed" with the exception of 8/9 You take a -0.5 point hit for "Replace, modify, or remove control arms, camber arms/links, toe arms/links" On top of that, if you make any of those spherical it's another -0.2 hit. I think you're missing out on A-Arm/Wishbone control arm penalty which all FRS/BRZs need to take a hit on which is -0.7 (and very stupid hit if I may add) So, at 2850 comp weight (with driver) you're AVG HP would be 199. If you add a rear wing, it's 193 For 6 avg hp, I think it's very much worth it. For what it's worth, a lot of guys around here are ditching their front splitters and just running with a rear wing. https://form.jotform.com/drivenasa/s...ification-form
Kyle H. - #89 STX
#4 | |
Drives: 2015 FRS
My question is, who is making 199 avg. hp, and if so, how? I'm at 200whp now with E85, ACE350, TRD intake, 3"exhaust, Toda big throttle body. It's a nice curve, but a long way from 199 avg. hp. I ordered a JUN GT surge tank (intake manifold) and will post up the dyno gains after I get it.
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos |
Thanks monkey & Mike. Yea, I know about that dumb a arm penalty (who does that not apply to even? E36...?).
I also didn't realize when I made the post the wing hit only applies to TT6. So, we just can't take the BTM aero bonus if we run a wing. Makes sense ditching the splitter since that is a -0.5 penalty, I will have to research that some more. That doesn't unbalance the car too much? From what I understand, our cars' aero is very neutral from factory. |
Nice dyno prandelia! That looks almost 195 whp avg. just eyeballing it. Have you done the calculations for that?
EDIT: did a very rough guestimate (eyeballing the points) and it comes out to ~191 whp. Last edited by Hades; 10-15-2020 at 03:02 PM. |
#7 | |
Drives: 2015 FRS
The problem is this car falls on it's face at 7200 RPM. The manifold I bought is shown to increase power, up to 8K !
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos Last edited by prandelia; 10-14-2020 at 11:03 PM. |
Drives: 2013 BRZ Sport-Tech
That's quite the torque... line? lol
#9 | |
Drives: 2015 FRS
'15 FRS - GLTC spec
#10 |
JHerbert Racing
I am not part of this TT5/St5 world but this idea has merit. Especially in wheel to wheel. There is currently a competitor in GLTC with this same idea. His idea is that it is easier to pass on the straights than the corners, so he sides with power over aero. In doing this he slightly holds ppl up in the corners but powers away in the straights. However his car is K powered. There is more potential to make power with a K than an FA20 so the results are better in his case. But if you can figure out a strong FA20 setup and trade aero points for power points, I think you may have something.
#11 | |
Drives: 2015 FRS
Sure, you can run less aero and build a straight-line bullet and it may work a a track like Road America, but for most tracks, the cars that are aero prepared and well balanced are the best, which is what we all race, and why at almost every race the front runners in the top 10 are all aero prepared cars. Sure, you will have a well driven non-aero car slide in from time to time, but it just doesn't hold up over the coarse a season. I have to concede, K24's have the edge because light cars can de-tune from ~220hp, and run a flat 180-200hp powerband for a few thousand RPM, so when we are both on a slow 3rd gear corner, they are making all 180-200hp at 5500 RPM, and I am nowhere near my peak 200hp at the same relative RPM. That's the advantage. They have to carry a little more weight, but it's still an advantage, not huge, but just enough that they can squirt off a corner here and there and then I'll never get back around them. I certainly don't out-drag race anybody in the top-10 in GLTC. I have to do it in quali and in the corners. This is typically the same for any series the FRS/BRZ runs in, whether it's GLTC, NASA, SCCA, etc. etc. If I can make enough power with this manifold, between that bit of detune, and the additional 6% of torque/hp that 4.556 gearing will put the ground, it should be enough to bridge that gap that exists between my FA20 and the K24 and other detuned motors like S54, S52, etc. etc. There are plenty of ways to skin a cat, but yeah, there is no denying the ability and ease of using a K24. That said, I'm sticking with the FA20.
'15 FRS - GLTC spec
#12 |
Also for GTLC rules, see the hidden message that favors K24 builds over anything else...
Kyle H. - #89 STX
#13 | |
Drives: 2015 FRS
I was not happy about that when I found out....nobody will be getting away with that BS this year....
'15 FRS - GLTC spec
#14 | |
I can see why you run the ACE |
| FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | Engine, Exhaust, Bolt-Ons | 8 | 10-30-2015 06:36 AM |
| Why a balanced setup is better than a "understeery" setup. | CSG Mike | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 52 | 07-01-2015 04:36 PM |
| KW V3 Setup | Magiclow | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 03-21-2015 03:29 AM |
| FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | NY / NJ / CT / PA | 0 | 10-20-2014 10:48 AM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
