Old 09-19-2023, 12:53 AM   #1
nico_rsx
Drives: BRZ 2017 Pure Red, MT
OEM muffler heat-shield/metal sheet
Hi,
Is there really an important function for the metal sheet (heat shield?) above the OEM muffler? Mine is starting to come loose (rust), and I'm wondering if I'll have problems if I remove it entirely. I sometime track the car, so higher exhaust temperature.
Thanks
nico_rsx is offline   Reply With Quote
Old 09-19-2023, 05:34 AM   #2
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Originally Posted by nico_rsx View Post
Hi,
Thanks
From what I have read after a few years here, battery leakage and electronics failures such as coilpacks seem to occur more frequently due to the excessive heat build up, especially during track use.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 09-19-2023, 08:39 AM   #3
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Hi,
Thanks
Taking the shield off shouldn't be a problem. None of the aftermarket headers have them and folks run them without problems.
The are some batteries that have an open vent (Everstart, ask me how I know) that will leak acid went used on the track.
The #3 coil pack can get hot and fail. Heat wrapping that part of the exhaust can help. I always open my hood after a session and, knock on wood, haven't had a problem with coil packs.
Old 09-19-2023, 11:27 AM   #4
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I believe he's talking about the metal plate that resides above the rear muffler section under the trunk, not the OEM header, overpipe, or front pipe heat shields.
Originally Posted by humfrz
I'm old and lazy
Old 09-19-2023, 12:22 PM   #5
blsfrs
blsfrs's Avatar
You are correct. I need to get through my 3rd cup of coffee before I post.
I would at least want to keep the shield over the Cat. The one over the muffler, not so much.
Old 09-20-2023, 12:58 AM   #6
nico_rsx
Yes, it's the shield between the trunk and muffler.
Heat shield above muffler question oldlostcory Engine, Exhaust, Transmission 1 12-23-2020 04:20 PM
FS: OEM Heat Shield MicheleAbbate Engine, Exhaust, Bolt-Ons 11 10-24-2018 06:24 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
