Old 09-18-2023, 12:27 AM   #15
rosawilliam0926
Drives: Toyota 86
Originally Posted by Qwimby1 View Post
I knew I could count on another ESC user! Looks like a lot of others have dead center-console outlets. Wonder if that was a common problem?
I bought a door stay from my local dealer. Can't recall the cost, but it was worth every penny and the 15-minute install time. Highly recommended.
Okay
rosawilliam0926 is offline   Reply With Quote
Old 09-18-2023, 10:51 AM   #16
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Originally Posted by tarzan_nojane View Post
The connector to the center console socket disconnects fairly easily. This happened to my 2014. It us easy to remove the socket from inside of the console box. Remove it VERY slowly and confirm that the wire is or is not connected. If you are real lucky, you may find the connecter close to the opening and be able to fish it out.
continuing with my dumb question routine, I can't figure out how the socket comes out of the center console. Looks like there's a hinge on the bottom of a plastic connector that snaps around it but I can't figure how to pull or pry it loose without breaking something.
Qwimby1 is offline   Reply With Quote
Old 09-18-2023, 04:28 PM   #17
tarzan_nojane
tarzan_nojane's Avatar
Drives: 2014 FR-S
Have you checked out the DIY section for console removal How-To's?
I did this more than 4 years ago - sorry that I don't remember how.
tarzan_nojane is offline   Reply With Quote
The Following User Says Thank You to tarzan_nojane For This Useful Post:
humfrz (09-23-2023)
Old 09-23-2023, 10:52 PM   #18
Soon ....... your long term memory will kick in, then you will remember -
soundman98 (09-24-2023), tarzan_nojane (09-26-2023)
A dumb question ckilburn_ Electronics | Audio | NAV | Infotainment 9 06-05-2018 08:45 AM
Dumb Question 22R Software Tuning 3 10-30-2017 05:19 PM
Turn Signal Relay Question (Dumb Question) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 3 06-23-2017 01:58 AM
Dumb First Question FlamingRectumSyndrome Software Tuning 4 04-05-2014 11:29 PM
Dumb question ExWhyZer0 Electronics | Audio | NAV | Infotainment 2 01-25-2013 06:44 PM
